gerald_FS
(Gerald)
January 16, 2017, 8:39pm
1
Help!
I’ve shot my DC!
I wanted to test something in the area of networks and went to nothing more!
Currently I have no Samba DC to run, and the brigde is gone!
That is, I have a physical red and green interface, but no users or groups more!
I can not create a new brigade in the menu, no hook is settable. In the user area, no DC controller is active! …
What can I do?
Gerald
gerald_FS
(Gerald)
January 16, 2017, 9:25pm
2
How to reset the DC?
In the GUI gehts unfortunately not, I have now a werkreset according to the instructions, but it does not work.
I created the brigade.
Otherwise, I have to rebuild everything tomorrow!
gerald_FS
(Gerald)
January 16, 2017, 9:48pm
4
Thanks, exactly this statement I’ve already worked through it, it comes then the message:
Configure Samba Active Directory
The Domain Controller (DC) container must be configured before being started
However, I can not make below details, all input fields are gray background …
[root@openzwo ~]# config show nsdc
nsdc=service
IpAddress=192.168.1.9
bridge=br0
status=enabled
[root@openzwo ~]#
most of that is from worked from the, preferably, console or shell.
davidep
(Davide Principi)
January 16, 2017, 9:53pm
6
gerald_FS:
bridge=br0
You could create a green bridge with “new logical interface” button to restore br0.
gerald_FS
(Gerald)
January 16, 2017, 10:02pm
7
Brigde I have created but no change, unfortunately …
Property after the creation of the brigade, still a DC Factory reset.
Unfortunately nothing
irgendwo hat er noch alte Daten gefunden nur wo?
habe jetzt zweimal einen Factory Reset gemacht
davidep
(Davide Principi)
January 16, 2017, 10:04pm
8
gerald_FS:
nothing
Could you find anything relevant in system logs?
gerald_FS
(Gerald)
January 16, 2017, 10:06pm
9
NSDC is running
SSSD is not running
Which log should I look at the best?
SSSD.log
(Mon Jan 16 22:34:01:345984 2017) [sssd] [sss_ini_get_config] (0x0010): Failed to parse configuration. Error 5. (Mon Jan 16 22:34:01:361247 2017) [sssd] [sss_ini_get_config] (0x0010): Errors detected while parsing: /etc/sssd/sssd.conf (Mon Jan 16 22:34:01:361464 2017) [sssd] [sss_ini_config_print_errors] (0x0010): Error (8) on line 1: Failed to read line. (Mon Jan 16 22:34:01:361513 2017) [sssd] [confdb_init_db] (0x0010): Failed to load configuration (Mon Jan 16 22:34:01:361579 2017) [sssd] [confdb_setup] (0x0010): ConfDB initialization has failed [5]: Input/output error (Mon Jan 16 22:34:01:361666 2017) [sssd] [load_configuration] (0x0010): Unable to setup ConfDB [5]: Input/output error (Mon Jan 16 22:34:01:361698 2017) [sssd] [main] (0x0020): SSSD couldn't load the configuration database.
sssd.conf in etc is empty
davidep
(Davide Principi)
January 16, 2017, 10:44pm
10
This is a consequence of the factory reset.
Try with:
signal-event nethserver-sssd-save
…and see the logs
gerald_FS
(Gerald)
January 17, 2017, 6:56pm
11
So, I now have the NS7 reinstalled.
Thanks, all who helped me!
@davidep , @fasttech
dj_marian
(Marcin)
January 18, 2017, 8:28pm
12
Hi, I’m new on this forum with 2nd post. I also faced problem from this topic. If You made Fatory Reset as mentioned above and You have Start DC unclickable, probably:
config show nsdc
gives You:
nsdc=service
IpAddress=1.2.3.4
bridge=br0
status=enabled
then try:
config setprop nsdc status disabled
this will set nsdc status to disabled then new start is possible.
I hope this will help others. Cheers
davidep
(Davide Principi)
January 18, 2017, 10:21pm
13
davidep
(Davide Principi)
January 19, 2017, 8:13am
14
Sorry @dj_marian I directed you to the wrong place! My mistake!
The right documentation file to modify was
https://github.com/NethServer/nethserver-dc/blob/master/README.rst
Anyway, I finally applied your patch to both files. It’s fine for me! Thank you!
