Hello Giacomo,
Thank you for your quick response. I have been busy since then in trying to improve with my objective. I failed to reset according to the nethserver samba reset procedure as indicated by fasttech. I found differences in directory structure, directory names, file names etc in my system compared with the document given. Therefore I redid everything from scratch several times, changing domain names etc. But it ended up always with the same errors as shown hereafter.
Sorry for using mail as communication means. That was more flexible and more convenient to handle.
Given a solution will become available, I am prepared to describe this publicly for the Nethserver community.
Many regards
Karl
1 Creation of Virtual Machine for Nethserver with Virtual Box
Create Virtual Machine
Typ : Linux
Version Red Hat (64 bit)
Memory Size: 1024MB
Create Hard Disk
Controller: Nethserver 7.2.1511-alpha3-x86_64
Controller SATA: Nethserver. vdihost
Network: Adapter 1 only, Networkbridge, Raltek RTL8168, Type Intel PRO/1q000 MT, MAC-Address: 0800279F972E
2 Configuration of Nethserver
Host name. server3.samba.local
IP Address of Nethserver: 192.168.201.109/24
Dashboard of Nethserver shows one Interface enp0s3Dashboard of Nethserver
3 Software configuration and Updates
Packages: Account Provider Samba Active directory, Basic Firewall, Fileserver
Updates: Installed Software is up to date.
Configuration of Account provider: IP Address 192.168.201.141, Create Network Bridge, LOCALDOMAIN (given by the System and could not be changed)
4 DC failure
5 Some additional information (config show nsdc, ifconfig, /var/log/messages)
[root@server3 ~]# config show nsdc
nsdc=service
IpAddress=192.168.201.141
bridge=br0
status=enabled
[root@server3 ~]#
[root@server3 ~]# ifconfig
br0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.201.109 netmask 255.255.255.0 broadcast 192.168.201.255
inet6 fe80::a00:27ff:febd:23fa prefixlen 64 scopeid 0x20<link>
ether 08:00:27:bd:23:fa txqueuelen 1000 (Ethernet)
RX packets 544 bytes 72895 (71.1 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 112 bytes 13905 (13.5 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp0s3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
RX packets 1175 bytes 216156 (211.0 KiB)
TX packets 121 bytes 16693 (16.3 KiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1 (Local Loopback)
RX packets 70 bytes 4820 (4.7 KiB)
TX packets 70 bytes 4820 (4.7 KiB)
[root@server3 ~]# ^C
Parts of /var/log/messages
First significant part:
eb 26 17:40:08 server3 network: Bringing up interface enp0s3:
Feb 26 17:40:08 server3 kernel: IPv6: ADDRCONF(NETDEV_UP): enp0s3: link is not ready
Feb 26 17:40:08 server3 kernel: e1000: enp0s3 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
Feb 26 17:40:08 server3 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): enp0s3: link becomes ready
Feb 26 17:40:08 server3 dhclient[751]: DHCPDISCOVER on enp0s3 to 255.255.255.255 port 67 interval 7 (xid=0x690b7ebd)
Feb 26 17:40:09 server3 kernel: IPv6: enp0s3: IPv6 duplicate address fe80::a00:27ff:febd:23fa detected!
Feb 26 17:40:09 server3 dhclient[751]: DHCPREQUEST on enp0s3 to 255.255.255.255 port 67 (xid=0x690b7ebd)
Feb 26 17:40:09 server3 dhclient[751]: DHCPOFFER from 192.168.201.1
Feb 26 17:40:09 server3 dhclient[751]: DHCPACK from 192.168.201.1 (xid=0x690b7ebd)
Feb 26 17:40:11 server3 NET[800]: /usr/sbin/dhclient-script : updated /etc/resolv.conf
Feb 26 17:40:11 server3 dhclient[751]: bound to 192.168.201.109 – renewal in 363055 seconds.
Feb 26 17:40:11 server3 network: Determining IP information for enp0s3… done.
Feb 26 17:40:12 server3 NET[881]: /etc/sysconfig/network-scripts/ifup-post : updated /etc/resolv.conf
Feb 26 17:40:12 server3 network: [ OK ]
Part 2
Feb 26 20:07:36 server3 kernel: ll header: 00000000: ff ff ff ff ff ff 08 00 27 bd 23 fa 08 06 …’.#…
Feb 26 20:07:36 server3 kernel: br0: received packet on enp0s3 with own address as source address
Feb 26 20:07:37 server3 kernel: br0: received packet on enp0s3 with own address as source address
Feb 26 20:07:37 server3 kernel: IPv4: martian source 192.168.201.141 from 192.168.201.109, on dev br0
Feb 26 20:07:37 server3 kernel: ll header: 00000000: ff ff ff ff ff ff 08 00 27 bd 23 fa 08 06 …’.#…
Feb 26 20:07:41 server3 kernel: br0: received packet on enp0s3 with own address as source address
Feb 26 20:07:45 server3 kernel: br0: received packet on enp0s3 with own address as source address
Feb 26 20:07:45 server3 journal: Suppressed 2443 messages from /system.slice/httpd-admin.service
Feb 26 20:07:45 server3 esmith::event[7067]: [ERROR] could not connect to Samba Domain Controller
Feb 26 20:07:45 server3 esmith::event[7067]: Action: /etc/e-smith/events/nethserver-dc-save/S95nethserver-dc-waitstart FAILED: 1 [1201.17001]
Feb 26 20:07:45 server3 /sbin/e-smith/db[23163]: /var/lib/nethserver/db/configuration: OLD sssd=service|AdDns||LdapURI||Provider|none|status|disabled
Feb 26 20:07:45 server3 /sbin/e-smith/db[23163]: /var/lib/nethserver/db/configuration: NEW sssd=service|AdDns|192.168.201.141|LdapURI||Provider|none|status|disabled
Feb 26 20:07:45 server3 dbus[585]: [system] Activating via systemd: service name=‘org.freedesktop.timedate1’ unit=‘dbus-org.freedesktop.timedate1.service’
Feb 26 20:07:45 server3 dbus-daemon: dbus[585]: [system] Activating via systemd: service name=‘org.freedesktop.timedate1’ unit=‘dbus-org.freedesktop.timedate1.service’
Feb 26 20:07:45 server3 systemd: Cannot add dependency job for unit microcode.service, ignoring: Unit is not loaded properly: Invalid argument.
Part 3
07 server3 esmith::event[7067]: Invalid argument
Feb 26 20:09:07 server3 esmith::event[7067]: Failed to create bus connection: Host is down
Feb 26 20:09:07 server3 esmith::event[7067]: [ERROR] User admin creation failed
Feb 26 20:09:07 server3 esmith::event[7067]: Action: /etc/e-smith/events/nethserver-dc-save/S98nethserver-dc-createadmins FAILED: 3 [21.094766]
Feb 26 20:09:07 server3 esmith::event[7067]: Event: nethserver-dc-save FAILED
Feb 26 20:09:07 server3 kernel: net_ratelimit: 1 callbacks suppressed
Feb 26 20:09:07 server3 kernel: br0: received packet on enp0s3 with own address as source address
Feb 26 20:09:07 server3 kernel: IPv4: martian source 192.168.201.141 from 192.168.201.109, on dev br0
Feb 26 20:09:07 server3 kernel: ll header: 00000000: ff ff ff ff ff ff 08 00 27 bd 23 fa 08 06 …’.#…
Feb 26 20:09:08 server3 kernel: br0: received packet on enp0s3 with own address as source address
Feb 26 20:09:08 server3 kernel: IPv4: martian source 192.168.201.141 from 192.168.201.109, on dev br0
Feb 26 20:09:08 server3 kernel: ll header: 00000000: ff ff ff ff ff ff 08 00 27 bd 23 fa 08 06 …’.#…
Feb 26 20:09:09 server3 kernel: br0: received packet on enp0s3 with own address as source address
