Domain trust update question for Nextcloud
Hello Team,
Do changes to the config.php file in /usr/share/nextcloud/config/ to add a trusted domain survive updates to Nextcloud or will this file be overwritten when Nextcloud updates so I’ll need to add in the trusted domain again?
Thanks!
AFAIK it survives updates, and backups of it are saved when using the regular Nethserver’s backup module.
Thanks @dnutan! Much appreciated.
You can also use the built-in prop:
