pfinardi
(Paolo Finardi)
February 19, 2017, 2:19pm
1
NethServer Version: Nethserver 7
Module: virtual host
how can manage many virtual hosts each one with different Let’s Encrypt certificate?
In Let’s Encrypt module I can request the certificate for each domain but in virtual host configuration I can’t choose them. I can only choose “Default certificate” or other certificates I uploaded.
Is it possible?
Thanks in advance
Paolo
stephdl
(Stéphane de Labrusse)
February 20, 2017, 2:07pm
2
Good idea, it needs time of developer, can you have a go ?
pfinardi
(Paolo Finardi)
February 20, 2017, 2:28pm
3
I’d like to develop it but I have no skill to do it.
I can test it
giacomo
(Giacomo Sanchietti)
February 20, 2017, 3:00pm
4
pfinardi:
Is it possible?
Not at this time, but you could workaround the problem doing this:
request a LE certificate with all needed domains
set LE certificate as default
select Default certificate in virtual hosts configuration
The certificate should be valid for all domains since it uses SNI (Server Name Indication - Wikipedia )
pfinardi
(Paolo Finardi)
February 21, 2017, 7:41am
5
Thanks @giacomo , the workaround works
