NethServer Version: NethServer release 7.3.1611 (Final)
Module: squid, lightsquid
Hi all,
I’ve been trying to get web proxy and filter to work but have so far been unsuccessful.
I’ve configured NS with LDAP. Installed squid web proxy and web filter. Enabled web proxy in transparent mode. Also, nethserver is installed on a remote VPS and the only network interface is green (ens3).
When I go to web proxy stats i get the following error:
Error : report folder ‘/var/lightsquid’ not contain any valid data! Please run lightparser.pl (and check ‘report’ folder content)
Please check config file !
Variable value
$tplpatph /usr/share/lightsquid/tpl
$templatename nethesis
$langpatph /usr/share/lightsquid/lang
$langname eng
$reportpath /var/lightsquid
Access to ‘/var/lightsquid’ folder yes
$graphreport 1
When I run lightparser.pl from shell there is no output. Also, the /var/lightsquid folder is empty.
I’ve also run check-setup.pl from /etc/lightsquid/ and it gives me an error:
LightSquid Config Checker, © 2005-9 Sergey Erokhin GNU GPL
can’t access to /etc/lightsquid/lightsquid.cfg !!!
Even though lightsquid.cfg is present in /etc/lightsquid.
I’m trying to use a windows 10 pc to use proxy going to settings>network & Internet>proxy and enabling “manual proxy setup”; as proxy server i’m using the FQDN, i.e., nethesis.mydomain.co.uk, port 3128.
output of config show dns and sssd:
[root@nethesis ~]# config show dns
dns=configuration
NameServers=8.8.8.8,8.8.4.4
[root@nethesis ~]# config show sssd
sssd=service
AdDns=
LdapURI=ldap://127.0.0.1
Provider=ldap
Realm=
Workgroup=
status=enabled
I’ve tried finding a solution in the manual and forum but can’t find any solution. Any help would be greatly appreciated.
Thanks.
