I have a week trying to make work the OCS and it rocks trought the web client but the agent gives me this error:
Starting OCS Inventory NG Agent on Monday, July 24, 2017 16:48:42.
AGENT => Running OCS Inventory NG Agent Version 2.3.0.0
AGENT => Using OCS Inventory NG FrameWork Version 2.3.0.0
AGENT => Loading plug-in(s)
DLL PLUGIN => Searching for Plug-in DLL(s) in folder <C:\Program Files (x86)\OCS Inventory Agent\plugins>
DLL PLUGIN => 0 DLL Plug-in(s) successfully loaded on 0 DLL(s) found
AGENT => Using network connection with Communication Server
COM PROVIDER => Loading Communication Provider <C:\Program Files (x86)\OCS Inventory Agent\ComHTTP.dll>
AGENT => Using Communication Provider Version <2.3.0.0>
AGENT => Sending Prolog
DID_CHECK => Read DeviceID <001-PC-2017-07-18-16-52-26> and MACs <0A:00:27:00:00:0B00:24:E8:19:4D:A000:24:E8:19:4D:A0> in file <ocsinventory.dat>
COM SERVER => Initializing cURL library for sendRequest
COM SERVER => Using cURL with server authentication
COM SERVER => Disabling cURL proxy support
COM SERVER => Enabling cURL SSL server validation support using CA Bundle <NSRV.crt>
COM SERVER => Sending HTTP Post request to URL https://192.168.3.200/ocsreports
WARNING *** COM SERVER => Failed to send HTTP Post request
COM SERVER => Cleaning cURL library
ERROR *** AGENT => Failed to send Prolog
AGENT => Unloading communication provider
AGENT => Unloading plug-in(s)
AGENT => Execution duration: 00:00:01.
I convert the NSRV.crt to NSRV.pem an locate inside the windows folder.
Don’t know what to do, Any one can help me.
Thanks.
