hi,
can it run in virtual enviroment like vmware esxi or citrix xen server or virtualbox as testing enviroments?
i tried it on virtualbox and no luck to install it.
hope to hear from you soon.
thanks.
Regards,
James
hi,
thanks.
Regards,
James
Ehi James,
you can flawlessly run it in Virtualbox following this great guide:
http://wiki.nethserver.org/doku.php?id=howto:create_a_nethserver_virtualbox_instance&s[]=virtualbox
You can even install it on esx, kvm or xen
I run it on Hyper-V in multiple environments (Gen1-VM)
Some howtos for ESX and Hyper-V would be super helpful for newcomers.
I ran it successfully in VirtualBox while I was evaluating the current version before committing it to bare metal.
And I’m running the Alpha in ESXi.
What issue did you run into. If you describe it, then perhaps we can help.
Cheers.
I installed it on esxi and virtualbox . no problem.
For 64bit version must be active on the bios (real machine) Intel Virtualization Technology ( vt-x ) and amd-v
Hi James,
I am running NethServer in a production environment using ESXi, no problems whatsoever.
Would you mind to take some screenshot for a simple howto? Installing NethServer on ESXi
I think I can do this Alessio…
Just give me a few days…
Screenshots of the steps to install Nethserver 6.7 using ESXi (using vSphere Client on OS X 10.11 - with the assistance of CodeWeavers CrossOver/Wine since the vSphere Client is only available for Windows). Those running a Windows system can disregard the OS X window frames the content of the windows are what matters!:
First of all, select the host you will use for Nethserver and click the menu File - New - Virtual Machine . . ..
##1
Select Custom and click Next.
##2
##3
##4
Select the most recent virtual Machine Version (in my case 8) supported by your ESXi host and click Next.
##5
##6
##7
##8
##9
##10
##11
##12
##13
##14
##15
##16
Your VM is now ready to be booted for installation.
Start the VM (in my case using VMWare Fusion for Mac and open the console. No actions needed Nethserver automatically boots into the interactive install.
##18
That’s it!
Awesome. Thanks for your time
Uhm, copy/paste on wiki seems not working properly
http://wiki.nethserver.org/doku.php?id=howto:install_nethserver_on_vmware_esxi
You can try converting it using http://pandoc.org/ (either the web service or the command-line utility)
Noticed an error in Step 14. Is corrected in my earlier post.
@alefattorini, @jaapvdv, I’ve uploaded the images to the wiki. Feel free to add any information you think is missing (vmware tools…)
Instructions on installing Open VM Tools are added.
Added Hyper-V-Howto to the Wiki:
http://wiki.nethserver.org/doku.php?id=howto:install_nethserver_on_hyper-v
Awesome! how did you do that?
Added additional information!
Hi all!
We have 4 NS running on KVM (Proxmox 4.2 and 3.2). Good performance!
If you need any help, just ask. It’s simple, and works very good!
