it’s been a long and productive week for dev team, so there are new work for testing team and for all who want contribute
@vcc, @Adam, @medworthy, @fasttech, @GG_jr, @mabeleira, @dz00te
WebTop: images upload doesn’t work from admin section:@lucag
http://dev.nethserver.org/issues/3297 -
WebTop: upgrade to up 033: http://dev.nethserver.org/issues/3296@lucag -
Log smtp traffic rejection: http://dev.nethserver.org/issues/3295@giacomo -
Add unbound as DNS resolver for DNSBLs: http://dev.nethserver.org/issues/3294@dz00te -
Avoid squid restart after squidguard log rotation: http://dev.nethserver.org/issues/3293@dz00te -
vsftpd logging too verbose by default: http://dev.nethserver.org/issues/3292@giacomo -
squid log file rotation: http://dev.nethserver.org/issues/3290@Adam -
Configure forward_max_tries for Squid: http://dev.nethserver.org/issues/3288@giacomo -
PPPoE default route overrides multi WAN configuration : http://dev.nethserver.org/issues/3287@filippo_carletti -
dhcp lease has wrong netmask: http://dev.nethserver.org/issues/3286@dz00te -
spamd for pop3 scan: http://dev.nethserver.org/issues/3285@dz00te -
port forward not working with sNAT and multiWAN: http://dev.nethserver.org/issues/3280@giacomo -
Roaming profile doesn’t work with W8,W8.1,W10: http://dev.nethserver.org/issues/3277@dz00te -
amavisd default log_level: http://dev.nethserver.org/issues/3274@dz00te -
Rotate /var/log/sid_changes.log: http://dev.nethserver.org/issues/3273@Adam -
DB key name clash in networks db: http://dev.nethserver.org/issues/3272@dz00te -
Automatic group email addresses creation: http://dev.nethserver.org/issues/3267@dz00te -
ip /mac binding blocks dhcp server requests: http://dev.nethserver.org/issues/3257@dz00te -
Use DNSBL to fight spam: http://dev.nethserver.org/issues/3302@alefattorini -
Update to owncloud 7.0.11: http://dev.nethserver.org/issues/3307@alefattorini -
MultiWAN: remove static routes for checkip: http://dev.nethserver.org/issues/3289@Adam
the same list but on redmine: http://dev.nethserver.org/projects/nethserver/issues?query_id=27
if you are new to test/qa read here: QA/Testing Team basic HOWTO
tnx
edit: updated list
they are still there for the fortunate member.
