Block ports Nethserver
Hello
How I configures witch port I accep and wich port I block it
In NS7.3 you will go to Firewall Objects, then to services to create the service and associated Port you wish to open it close. Then go to Firewall rules and create a rule for the firewall object you just created. .
Remember that ports are closed by default :wink:
