Block access to web sites using ip address
NS 7.3.1611 (rc3) + last upd
Web Content filter
How to except web sites using ip address?
I create Custom Categories and add IP addresses
but if checked "Block access to web sites using ip address"
sites is blocked.
How to add to “Custom Categories” IP addresses?
I’m sorry, I can’t understand this request.
If you absolutely need to access remote websites through the proxy using IP addresses (this is really uncommon), you should not check Block access to web sites using ip address.
If you have only one website with IP, you can add it to the Sites without proxy tab.
You want to block access to ip addresses from the browser and also place an ip in the white list of access?
[quote=“jgjimenezs, post:3, topic:5416”]@filippo_carletti
[/quote]
Yes :slight_smile:
