Zitadel module for NS8?
Hello
help me test
ghcr.io/geniusdynamics/zitadel:dev
test back up and restore
hopefully to be able to impliment login-v2 soon
It can be installed, but cannot be used.
Bad Gateway
can you share your logs
2025-11-15T23:59:21+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:21Z" level=info msg="setup started" caller="/home/runner/work/zitadel/zitadel/cmd/setup/setup.go:99"
2025-11-15T23:59:21+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:21Z" level=info msg="verify migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:43" name=14_events_push
2025-11-15T23:59:21+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:21Z" level=info msg="verify migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:43" name=01_tables
2025-11-15T23:59:21+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:21Z" level=info msg="verify migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:43" name=02_assets
2025-11-15T23:59:22+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:22Z" level=info msg="verify migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:43" name=28_add_search_table
2025-11-15T23:59:22+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:22Z" level=info msg="verify migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:43" name=31_add_aggregate_index_to_fields
2025-11-15T23:59:22+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:22Z" level=info msg="verify migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:43" name=03_default_instance
2025-11-15T23:59:22+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:22Z" level=info msg="starting migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:66" name=03_default_instance
2025-11-15T23:59:22+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:22Z" level=error msg="migration failed" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:68" error="ID=INST-mruNY Message=Errors.Invalid.Argument" name=03_default_instance
2025-11-15T23:59:22+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:22Z" level=fatal msg="migration failed" caller="/home/runner/work/zitadel/zitadel/cmd/setup/setup.go:239" error="ID=INST-mruNY Message=Errors.Invalid.Argument" name=03_default_instance
2025-11-15T23:59:22+08:00 [1:zitadel1:systemd] libpod-9fbd4be584b99880a57c7b6355f3434d95680c87c98cbd657c0db3032cd15c62.scope: Consumed 1.261s CPU time.
2025-11-15T23:59:22+08:00 [1:zitadel1:systemd] zitadel-app.service: Main process exited, code=exited, status=1/FAILURE
2025-11-15T23:59:22+08:00 [1:zitadel1:zitadel1] 9fbd4be584b99880a57c7b6355f3434d95680c87c98cbd657c0db3032cd15c62
2025-11-15T23:59:22+08:00 [1:zitadel1:systemd] zitadel-app.service: Failed with result 'exit-code'.
2025-11-15T23:59:22+08:00 [1:zitadel1:systemd] zitadel-app.service: Consumed 1.211s CPU time.
2025-11-15T23:59:23+08:00 [1:zitadel1:systemd] zitadel-app.service: Scheduled restart job, restart counter is at 4367.
2025-11-15T23:59:23+08:00 [1:zitadel1:systemd] Stopped Podman  zitadel-app.service.
2025-11-15T23:59:23+08:00 [1:zitadel1:systemd] zitadel-app.service: Consumed 1.211s CPU time.
2025-11-15T23:59:23+08:00 [1:zitadel1:systemd] Stopping Podman postgresql-app.service...
2025-11-15T23:59:23+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:23.287 UTC [1] LOG:  received fast shutdown request
2025-11-15T23:59:23+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:23.297 UTC [1] LOG:  aborting any active transactions
2025-11-15T23:59:23+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:23.302 UTC [1] LOG:  background worker "logical replication launcher" (PID 27) exited with exit code 1
2025-11-15T23:59:23+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:23.302 UTC [22] LOG:  shutting down
2025-11-15T23:59:23+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:23.312 UTC [22] LOG:  checkpoint starting: shutdown immediate
2025-11-15T23:59:23+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:23.364 UTC [22] LOG:  checkpoint complete: wrote 17 buffers (0.1%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.002 s, sync=0.022 s, total=0.062 s; sync files=11, longest=0.010 s, average=0.002 s; distance=82 kB, estimate=82 kB; lsn=0/1725EF10, redo lsn=0/1725EF10
2025-11-15T23:59:23+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:23.375 UTC [1] LOG:  database system is shut down
2025-11-15T23:59:23+08:00 [1:zitadel1:zitadel1] ecbfdfb9bdf93e6ba39c595e84350ed6f74cc5e9c14e713f97580f6f83db3637
2025-11-15T23:59:23+08:00 [1:zitadel1:systemd] Stopped Podman postgresql-app.service.
2025-11-15T23:59:23+08:00 [1:zitadel1:systemd] Stopping Podman zitadel.service...
2025-11-15T23:59:24+08:00 [1:zitadel1:systemd] Removed slice cgroup user-libpod_pod_c456a168449fc84df5723b8ba5044ff971870a1bb4596a9cd6c2748ba60b9b7e.slice.
2025-11-15T23:59:24+08:00 [1:zitadel1:systemd] user-libpod_pod_c456a168449fc84df5723b8ba5044ff971870a1bb4596a9cd6c2748ba60b9b7e.slice: Consumed 2.106s CPU time.
2025-11-15T23:59:24+08:00 [1:zitadel1:podman] zitadel
2025-11-15T23:59:24+08:00 [1:zitadel1:podman] c456a168449fc84df5723b8ba5044ff971870a1bb4596a9cd6c2748ba60b9b7e
2025-11-15T23:59:24+08:00 [1:zitadel1:systemd] Stopped Podman zitadel.service.
2025-11-15T23:59:24+08:00 [1:zitadel1:systemd] Starting Podman zitadel.service...
2025-11-15T23:59:24+08:00 [1:zitadel1:systemd] Created slice cgroup user-libpod_pod_652c7ae945ec913ccf05dd3fa8507e61e40d1bc45839b7a74d80a83aaba3993f.slice.
2025-11-15T23:59:24+08:00 [1:zitadel1:podman] 652c7ae945ec913ccf05dd3fa8507e61e40d1bc45839b7a74d80a83aaba3993f
2025-11-15T23:59:24+08:00 [1:zitadel1:systemd] Started libcrun container.
2025-11-15T23:59:24+08:00 [1:zitadel1:systemd] Started Podman zitadel.service.
2025-11-15T23:59:24+08:00 [1:zitadel1:systemd] Starting Podman postgresql-app.service...
2025-11-15T23:59:25+08:00 [1:zitadel1:systemd] Started libcrun container.
2025-11-15T23:59:25+08:00 [1:zitadel1:zitadel1] 224c74fed183d52766619c22bf0e75b0c4f406fa76cce3a2a416b4ee940e9ee4
2025-11-15T23:59:25+08:00 [1:zitadel1:systemd] Started Podman postgresql-app.service.
2025-11-15T23:59:25+08:00 [1:zitadel1:systemd] Starting Podman  zitadel-app.service...
2025-11-15T23:59:25+08:00 [1:zitadel1:postgresql-app]
2025-11-15T23:59:25+08:00 [1:zitadel1:postgresql-app] PostgreSQL Database directory appears to contain a database; Skipping initialization
2025-11-15T23:59:25+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:25.374 UTC [1] LOG:  starting PostgreSQL 16.11 on x86_64-pc-linux-musl, compiled by gcc (Alpine 14.2.0) 14.2.0, 64-bit
2025-11-15T23:59:25+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:25.375 UTC [1] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2025-11-15T23:59:25+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:25.375 UTC [1] LOG:  listening on IPv6 address "::", port 5432
2025-11-15T23:59:25+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:25.395 UTC [1] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2025-11-15T23:59:25+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:25.418 UTC [24] LOG:  database system was shut down at 2025-11-15 15:59:23 UTC
2025-11-15T23:59:25+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:25.437 UTC [1] LOG:  database system is ready to accept connections
2025-11-15T23:59:26+08:00 [1:zitadel1:systemd] Started libcrun container.
2025-11-15T23:59:26+08:00 [1:zitadel1:zitadel1] 677417433d346fcebbd48f57d4edc2ebb99b250dcde38af214f6b0bbbbd94695
2025-11-15T23:59:26+08:00 [1:zitadel1:systemd] Started Podman  zitadel-app.service.
2025-11-15T23:59:26+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:26Z" level=info msg="initialization started" caller="/home/runner/work/zitadel/zitadel/cmd/initialise/init.go:75"
2025-11-15T23:59:26+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:26Z" level=info msg="verify user" caller="/home/runner/work/zitadel/zitadel/cmd/initialise/verify_user.go:39" username=postgres
2025-11-15T23:59:26+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:26.903 UTC [30] ERROR:  role "postgres" already exists
2025-11-15T23:59:26+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:26.903 UTC [30] STATEMENT:  CREATE USER "postgres" WITH PASSWORD 'a64f651bcce5a525'
2025-11-15T23:59:26+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:26Z" level=info msg="verify database" caller="/home/runner/work/zitadel/zitadel/cmd/initialise/verify_database.go:39" database=zitadel
2025-11-15T23:59:26+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:26.909 UTC [31] ERROR:  database "zitadel" already exists
2025-11-15T23:59:26+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:26.909 UTC [31] STATEMENT:  CREATE DATABASE "zitadel"
2025-11-15T23:59:26+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:26Z" level=info msg="verify grant" caller="/home/runner/work/zitadel/zitadel/cmd/initialise/verify_grant.go:34" database=zitadel user=postgres
2025-11-15T23:59:26+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:26Z" level=info msg="verify zitadel" caller="/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:78" database=zitadel
2025-11-15T23:59:26+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:26Z" level=info msg="verify system" caller="/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:39"
2025-11-15T23:59:26+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:26Z" level=info msg="verify encryption keys" caller="/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:44"
2025-11-15T23:59:26+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:26Z" level=info msg="verify projections" caller="/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:49"
2025-11-15T23:59:26+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:26Z" level=info msg="verify eventstore" caller="/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:54"
2025-11-15T23:59:26+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:26Z" level=info msg="verify events tables" caller="/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:59"
2025-11-15T23:59:27+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:27Z" level=info msg="verify system sequence" caller="/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:64"
2025-11-15T23:59:27+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:27Z" level=info msg="verify unique constraints" caller="/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:69"
2025-11-15T23:59:27+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:27Z" level=info msg="setup started" caller="/home/runner/work/zitadel/zitadel/cmd/setup/setup.go:99"
2025-11-15T23:59:27+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:27Z" level=info msg="verify migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:43" name=14_events_push
2025-11-15T23:59:27+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:27Z" level=info msg="verify migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:43" name=01_tables
2025-11-15T23:59:27+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:27Z" level=info msg="verify migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:43" name=02_assets
2025-11-15T23:59:27+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:27Z" level=info msg="verify migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:43" name=28_add_search_table
2025-11-15T23:59:27+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:27Z" level=info msg="verify migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:43" name=31_add_aggregate_index_to_fields
2025-11-15T23:59:27+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:27Z" level=info msg="verify migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:43" name=03_default_instance
2025-11-15T23:59:27+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:27Z" level=info msg="starting migration" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:66" name=03_default_instance
2025-11-15T23:59:27+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:27Z" level=error msg="migration failed" caller="/home/runner/work/zitadel/zitadel/internal/migration/migration.go:68" error="ID=INST-mruNY Message=Errors.Invalid.Argument" name=03_default_instance
2025-11-15T23:59:27+08:00 [1:zitadel1:zitadel-app] time="2025-11-15T15:59:27Z" level=fatal msg="migration failed" caller="/home/runner/work/zitadel/zitadel/cmd/setup/setup.go:239" error="ID=INST-mruNY Message=Errors.Invalid.Argument" name=03_default_instance
2025-11-15T23:59:27+08:00 [1:zitadel1:systemd] libpod-677417433d346fcebbd48f57d4edc2ebb99b250dcde38af214f6b0bbbbd94695.scope: Consumed 1.243s CPU time.
2025-11-15T23:59:28+08:00 [1:zitadel1:systemd] zitadel-app.service: Main process exited, code=exited, status=1/FAILURE
2025-11-15T23:59:28+08:00 [1:zitadel1:zitadel1] 677417433d346fcebbd48f57d4edc2ebb99b250dcde38af214f6b0bbbbd94695
2025-11-15T23:59:28+08:00 [1:zitadel1:systemd] zitadel-app.service: Failed with result 'exit-code'.
2025-11-15T23:59:28+08:00 [1:zitadel1:systemd] zitadel-app.service: Consumed 1.204s CPU time.
2025-11-15T23:59:28+08:00 [1:zitadel1:systemd] zitadel-app.service: Scheduled restart job, restart counter is at 4368.
2025-11-15T23:59:28+08:00 [1:zitadel1:systemd] Stopped Podman  zitadel-app.service.
2025-11-15T23:59:28+08:00 [1:zitadel1:systemd] Stopping Podman postgresql-app.service...
2025-11-15T23:59:28+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:28.516 UTC [1] LOG:  received fast shutdown request
2025-11-15T23:59:28+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:28.524 UTC [1] LOG:  aborting any active transactions
2025-11-15T23:59:28+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:28.532 UTC [1] LOG:  background worker "logical replication launcher" (PID 27) exited with exit code 1
2025-11-15T23:59:28+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:28.532 UTC [22] LOG:  shutting down
2025-11-15T23:59:28+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:28.541 UTC [22] LOG:  checkpoint starting: shutdown immediate
2025-11-15T23:59:28+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:28.596 UTC [22] LOG:  checkpoint complete: wrote 17 buffers (0.1%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.002 s, sync=0.026 s, total=0.065 s; sync files=11, longest=0.010 s, average=0.003 s; distance=83 kB, estimate=83 kB; lsn=0/17273D78, redo lsn=0/17273D78
2025-11-15T23:59:28+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:28.607 UTC [1] LOG:  database system is shut down
2025-11-15T23:59:28+08:00 [1:zitadel1:zitadel1] 224c74fed183d52766619c22bf0e75b0c4f406fa76cce3a2a416b4ee940e9ee4
2025-11-15T23:59:28+08:00 [1:zitadel1:systemd] Stopped Podman postgresql-app.service.
2025-11-15T23:59:28+08:00 [1:zitadel1:systemd] Stopping Podman zitadel.service...
2025-11-15T23:59:29+08:00 [1:zitadel1:systemd] Removed slice cgroup user-libpod_pod_652c7ae945ec913ccf05dd3fa8507e61e40d1bc45839b7a74d80a83aaba3993f.slice.
2025-11-15T23:59:29+08:00 [1:zitadel1:systemd] user-libpod_pod_652c7ae945ec913ccf05dd3fa8507e61e40d1bc45839b7a74d80a83aaba3993f.slice: Consumed 2.109s CPU time.
2025-11-15T23:59:29+08:00 [1:zitadel1:podman] zitadel
2025-11-15T23:59:29+08:00 [1:zitadel1:podman] 652c7ae945ec913ccf05dd3fa8507e61e40d1bc45839b7a74d80a83aaba3993f
2025-11-15T23:59:29+08:00 [1:zitadel1:systemd] Stopped Podman zitadel.service.
2025-11-15T23:59:29+08:00 [1:zitadel1:systemd] Starting Podman zitadel.service...
2025-11-15T23:59:29+08:00 [1:zitadel1:systemd] Created slice cgroup user-libpod_pod_61e3c15f7737d19ccbc29a8509b63c8d93a755be3e83cd027118e84e06ae0e4b.slice.
2025-11-15T23:59:29+08:00 [1:zitadel1:podman] 61e3c15f7737d19ccbc29a8509b63c8d93a755be3e83cd027118e84e06ae0e4b
2025-11-15T23:59:29+08:00 [1:zitadel1:systemd] Started libcrun container.
2025-11-15T23:59:29+08:00 [1:zitadel1:systemd] Started Podman zitadel.service.
2025-11-15T23:59:29+08:00 [1:zitadel1:systemd] Starting Podman postgresql-app.service...
2025-11-15T23:59:30+08:00 [1:zitadel1:systemd] Started libcrun container.
2025-11-15T23:59:30+08:00 [1:zitadel1:zitadel1] 2bbadb6d4a76b1b826d76928cc2edf3b81b9f0ba1e7cf87063142d5a9a359348
2025-11-15T23:59:30+08:00 [1:zitadel1:systemd] Started Podman postgresql-app.service.
2025-11-15T23:59:30+08:00 [1:zitadel1:systemd] Starting Podman  zitadel-app.service...
2025-11-15T23:59:30+08:00 [1:zitadel1:postgresql-app]
2025-11-15T23:59:30+08:00 [1:zitadel1:postgresql-app] PostgreSQL Database directory appears to contain a database; Skipping initialization
2025-11-15T23:59:30+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:30.428 UTC [1] LOG:  starting PostgreSQL 16.11 on x86_64-pc-linux-musl, compiled by gcc (Alpine 14.2.0) 14.2.0, 64-bit
2025-11-15T23:59:30+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:30.428 UTC [1] LOG:  listening on IPv4 address "0.0.0.0", port 5432
2025-11-15T23:59:30+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:30.428 UTC [1] LOG:  listening on IPv6 address "::", port 5432
2025-11-15T23:59:30+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:30.452 UTC [1] LOG:  listening on Unix socket "/var/run/postgresql/.s.PGSQL.5432"
2025-11-15T23:59:30+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:30.475 UTC [25] LOG:  database system was shut down at 2025-11-15 15:59:28 UTC
2025-11-15T23:59:30+08:00 [1:zitadel1:postgresql-app] 2025-11-15 15:59:30.492 UTC [1] LOG:  database system is ready to accept connections
2025-11-15T23:59:31+08:00 [1:zitadel1:systemd] Started libcrun container.
2025-11-15T23:59:31+08:00 [1:zitadel1:zitadel1] 59877675453ad1ac5dd96780580a4cd6283ac0d495c37290adb611a15e5d7abe
is this the dev
We have no developers.
Ohh Sorry for that
Let me do a release so that you can install in the software center
Is that okay
Besides thank you, I still want to thank you.
You are welcome
Hopefully will try to check if i can impliment login version 2 currently using v1
eagerly awaiting
You can now install ns8-zitadel version 1
To install it run
add-module ghcr.io/geniusdynamics/zitadel:latest 1
Incase of any issues feel free to inquire
I reinstalled it, but it still doesn’t work
2025-11-16T17:32:02+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:02Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=40_init_push_func_v4
2025-11-16T17:32:02+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:02Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=01_tables
2025-11-16T17:32:02+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:02Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=02_assets
2025-11-16T17:32:02+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:02Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=28_add_search_table
2025-11-16T17:32:02+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:02Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=31_add_aggregate_index_to_fields
2025-11-16T17:32:02+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:02Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=46_init_permission_functions
2025-11-16T17:32:02+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:02Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=03_default_instance
2025-11-16T17:32:02+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:02Z” level=info msg=“starting migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:69” name=03_default_instance
2025-11-16T17:32:02+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:02Z” level=error msg=“migration failed” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:71” error=“ID=INST-mruNY Message=Errors.Invalid.Argument” name=03_default_instance
2025-11-16T17:32:02+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:02Z” level=error msg=“migration failed” caller=“/home/runner/work/zitadel/zitadel/cmd/setup/setup.go:372” error=“ID=INST-mruNY Message=Errors.Invalid.Argument” name=03_default_instance
2025-11-16T17:32:02+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:02Z” level=fatal msg=“setup failed, skipping cleanup” caller=“/home/runner/work/zitadel/zitadel/cmd/setup/setup.go:124” error=“migration failed: ID=INST-mruNY Message=Errors.Invalid.Argument”
2025-11-16T17:32:02+08:00 \[1:zitadel1:conmon\] conmon 508b1d5944fb40faf369 : Failed to open cgroups file: /sys/fs/cgroup/user.slice/user-1013.slice/user@1013.service/user.slice/user-libpod_pod_7b91a6c19b804dce5a41d7cb5acf8b28aa76b013aceb89f879fd547ea74945f4.slice/libpod-508b1d5944fb40faf369f85f2afae82d24e671517aa4f5ab15be40582fd1a326.scope/container/memory.events
2025-11-16T17:32:02+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Main process exited, code=exited, status=1/FAILURE
2025-11-16T17:32:02+08:00 \[1:zitadel1:zitadel1\] 508b1d5944fb40faf369f85f2afae82d24e671517aa4f5ab15be40582fd1a326
2025-11-16T17:32:02+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Failed with result ‘exit-code’.
2025-11-16T17:32:02+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Consumed 1.336s CPU time.
2025-11-16T17:32:03+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Scheduled restart job, restart counter is at 51.
2025-11-16T17:32:03+08:00 \[1:zitadel1:systemd\] Stopped Podman  zitadel-app.service.
2025-11-16T17:32:03+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Consumed 1.336s CPU time.
2025-11-16T17:32:03+08:00 \[1:zitadel1:systemd\] Stopping Podman postgresql-app.service…
2025-11-16T17:32:03+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:03.138 UTC \[1\] LOG:  received fast shutdown request
2025-11-16T17:32:03+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:03.147 UTC \[1\] LOG:  aborting any active transactions
2025-11-16T17:32:03+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:03.150 UTC \[1\] LOG:  background worker “logical replication launcher” (PID 27) exited with exit code 1
2025-11-16T17:32:03+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:03.155 UTC \[22\] LOG:  shutting down
2025-11-16T17:32:03+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:03.169 UTC \[22\] LOG:  checkpoint starting: shutdown immediate
2025-11-16T17:32:03+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:03.227 UTC \[22\] LOG:  checkpoint complete: wrote 14 buffers (0.1%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.002 s, sync=0.022 s, total=0.072 s; sync files=11, longest=0.010 s, average=0.002 s; distance=62 kB, estimate=62 kB; lsn=0/1C529C0, redo lsn=0/1C529C0
2025-11-16T17:32:03+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:03.237 UTC \[1\] LOG:  database system is shut down
2025-11-16T17:32:03+08:00 \[1:zitadel1:zitadel1\] 332568dad247917f55afbc8cdcb5045783c1cbf9b4fd2d4557cdaf0291f705f6
2025-11-16T17:32:03+08:00 \[1:zitadel1:systemd\] Stopped Podman postgresql-app.service.
2025-11-16T17:32:03+08:00 \[1:zitadel1:systemd\] Stopping Podman zitadel.service…
2025-11-16T17:32:03+08:00 \[1:zitadel1:systemd\] Removed slice cgroup user-libpod_pod_7b91a6c19b804dce5a41d7cb5acf8b28aa76b013aceb89f879fd547ea74945f4.slice.
2025-11-16T17:32:03+08:00 \[1:zitadel1:systemd\] user-libpod_pod_7b91a6c19b804dce5a41d7cb5acf8b28aa76b013aceb89f879fd547ea74945f4.slice: Consumed 1.233s CPU time.
2025-11-16T17:32:03+08:00 \[1:zitadel1:podman\] zitadel
2025-11-16T17:32:04+08:00 \[1:zitadel1:podman\] 7b91a6c19b804dce5a41d7cb5acf8b28aa76b013aceb89f879fd547ea74945f4
2025-11-16T17:32:04+08:00 \[1:zitadel1:systemd\] Stopped Podman zitadel.service.
2025-11-16T17:32:04+08:00 \[1:zitadel1:systemd\] Starting Podman zitadel.service…
2025-11-16T17:32:04+08:00 \[1:zitadel1:systemd\] Created slice cgroup user-libpod_pod_c0f67ce5e80b763558e6e507eed9485e47821ab33f117aaf07eab191b2bbd302.slice.
2025-11-16T17:32:04+08:00 \[1:zitadel1:podman\] c0f67ce5e80b763558e6e507eed9485e47821ab33f117aaf07eab191b2bbd302
2025-11-16T17:32:04+08:00 \[1:zitadel1:systemd\] Started libcrun container.
2025-11-16T17:32:04+08:00 \[1:zitadel1:podman\] zitadel
2025-11-16T17:32:04+08:00 \[1:zitadel1:systemd\] Started Podman zitadel.service.
2025-11-16T17:32:04+08:00 \[1:zitadel1:systemd\] Starting Podman postgresql-app.service…
2025-11-16T17:32:05+08:00 \[1:zitadel1:systemd\] Started libcrun container.
2025-11-16T17:32:05+08:00 \[1:zitadel1:zitadel1\] c0bb6cfd335e2211d0b5df684cc85f880ea05919f3a37b532e54c81caeaf6ce8
2025-11-16T17:32:05+08:00 \[1:zitadel1:systemd\] Started Podman postgresql-app.service.
2025-11-16T17:32:05+08:00 \[1:zitadel1:systemd\] Starting Podman  zitadel-app.service…
2025-11-16T17:32:05+08:00 \[1:zitadel1:postgresql-app\]
2025-11-16T17:32:05+08:00 \[1:zitadel1:postgresql-app\] PostgreSQL Database directory appears to contain a database; Skipping initialization
2025-11-16T17:32:05+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:05.280 UTC \[1\] LOG:  starting PostgreSQL 17.7 (Debian 17.7-3.pgdg13+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 14.2.0-19) 14.2.0, 64-bit
2025-11-16T17:32:05+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:05.281 UTC \[1\] LOG:  listening on IPv4 address “0.0.0.0”, port 5432
2025-11-16T17:32:05+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:05.281 UTC \[1\] LOG:  listening on IPv6 address “::”, port 5432
2025-11-16T17:32:05+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:05.302 UTC \[1\] LOG:  listening on Unix socket “/var/run/postgresql/.s.PGSQL.5432”
2025-11-16T17:32:05+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:05.333 UTC \[23\] LOG:  database system was shut down at 2025-11-16 09:32:03 UTC
2025-11-16T17:32:05+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:05.350 UTC \[1\] LOG:  database system is ready to accept connections
2025-11-16T17:32:06+08:00 \[1:zitadel1:systemd\] Started libcrun container.
2025-11-16T17:32:06+08:00 \[1:zitadel1:zitadel1\] f11cb1dd7badce29e22fa788b9bb531edb7c3defce78b0d86fa8177ed9b1f35b
2025-11-16T17:32:06+08:00 \[1:zitadel1:systemd\] Started Podman  zitadel-app.service.
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“initialization started” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/init.go:70”
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify user” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_user.go:40” username=zitadel
2025-11-16T17:32:07+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:07.042 UTC \[27\] ERROR:  role “zitadel” already exists
2025-11-16T17:32:07+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:07.042 UTC \[27\] STATEMENT:  – replace zitadel with the name of the user
2025-11-16T17:32:07+08:00 \[1:zitadel1:postgresql-app\] 	CREATE USER “zitadel” WITH PASSWORD ‘4e2274557791e5cd’
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify database” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_database.go:40” database=zitadel
2025-11-16T17:32:07+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:07.043 UTC \[27\] ERROR:  database “zitadel” already exists
2025-11-16T17:32:07+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:07.043 UTC \[27\] STATEMENT:  – replace zitadel with the name of the database
2025-11-16T17:32:07+08:00 \[1:zitadel1:postgresql-app\] 	CREATE DATABASE “zitadel”
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify grant” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_grant.go:35” database=zitadel user=zitadel
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify zitadel” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:80” database=zitadel
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify system” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:46”
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify encryption keys” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:51”
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify projections” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:56”
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify eventstore” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:61”
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify events tables” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:66”
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify unique constraints” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:71”
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“setup started” caller=“/home/runner/work/zitadel/zitadel/cmd/setup/setup.go:108”
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=14_events_push
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=40_init_push_func_v4
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=01_tables
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=02_assets
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=28_add_search_table
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=31_add_aggregate_index_to_fields
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=46_init_permission_functions
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=03_default_instance
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=info msg=“starting migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:69” name=03_default_instance
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=error msg=“migration failed” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:71” error=“ID=INST-mruNY Message=Errors.Invalid.Argument” name=03_default_instance
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=error msg=“migration failed” caller=“/home/runner/work/zitadel/zitadel/cmd/setup/setup.go:372” error=“ID=INST-mruNY Message=Errors.Invalid.Argument” name=03_default_instance
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:07Z” level=fatal msg=“setup failed, skipping cleanup” caller=“/home/runner/work/zitadel/zitadel/cmd/setup/setup.go:124” error=“migration failed: ID=INST-mruNY Message=Errors.Invalid.Argument”
2025-11-16T17:32:07+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Main process exited, code=exited, status=1/FAILURE
2025-11-16T17:32:07+08:00 \[1:zitadel1:zitadel1\] f11cb1dd7badce29e22fa788b9bb531edb7c3defce78b0d86fa8177ed9b1f35b
2025-11-16T17:32:07+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Failed with result ‘exit-code’.
2025-11-16T17:32:07+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Consumed 1.261s CPU time.
2025-11-16T17:32:08+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Scheduled restart job, restart counter is at 52.
2025-11-16T17:32:08+08:00 \[1:zitadel1:systemd\] Stopped Podman  zitadel-app.service.
2025-11-16T17:32:08+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Consumed 1.261s CPU time.
2025-11-16T17:32:08+08:00 \[1:zitadel1:systemd\] Stopping Podman postgresql-app.service…
2025-11-16T17:32:08+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:08.141 UTC \[1\] LOG:  received fast shutdown request
2025-11-16T17:32:08+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:08.153 UTC \[1\] LOG:  aborting any active transactions
2025-11-16T17:32:08+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:08.158 UTC \[1\] LOG:  background worker “logical replication launcher” (PID 26) exited with exit code 1
2025-11-16T17:32:08+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:08.159 UTC \[21\] LOG:  shutting down
2025-11-16T17:32:08+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:08.171 UTC \[21\] LOG:  checkpoint starting: shutdown immediate
2025-11-16T17:32:08+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:08.241 UTC \[21\] LOG:  checkpoint complete: wrote 14 buffers (0.1%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.002 s, sync=0.022 s, total=0.082 s; sync files=11, longest=0.010 s, average=0.002 s; distance=64 kB, estimate=64 kB; lsn=0/1C629E0, redo lsn=0/1C629E0
2025-11-16T17:32:08+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:08.250 UTC \[1\] LOG:  database system is shut down
2025-11-16T17:32:08+08:00 \[1:zitadel1:zitadel1\] c0bb6cfd335e2211d0b5df684cc85f880ea05919f3a37b532e54c81caeaf6ce8
2025-11-16T17:32:08+08:00 \[1:zitadel1:systemd\] Stopped Podman postgresql-app.service.
2025-11-16T17:32:08+08:00 \[1:zitadel1:systemd\] Stopping Podman zitadel.service…
2025-11-16T17:32:09+08:00 \[1:zitadel1:systemd\] Removed slice cgroup user-libpod_pod_c0f67ce5e80b763558e6e507eed9485e47821ab33f117aaf07eab191b2bbd302.slice.
2025-11-16T17:32:09+08:00 \[1:zitadel1:systemd\] user-libpod_pod_c0f67ce5e80b763558e6e507eed9485e47821ab33f117aaf07eab191b2bbd302.slice: Consumed 1.216s CPU time.
2025-11-16T17:32:09+08:00 \[1:zitadel1:podman\] zitadel
2025-11-16T17:32:09+08:00 \[1:zitadel1:podman\] c0f67ce5e80b763558e6e507eed9485e47821ab33f117aaf07eab191b2bbd302
2025-11-16T17:32:09+08:00 \[1:zitadel1:systemd\] Stopped Podman zitadel.service.
2025-11-16T17:32:09+08:00 \[1:zitadel1:systemd\] Starting Podman zitadel.service…
2025-11-16T17:32:09+08:00 \[1:zitadel1:systemd\] Created slice cgroup user-libpod_pod_54a889ec22e83da4b9f903828199d7f14bcfbb01a7968964e357b8c44a92188a.slice.
2025-11-16T17:32:09+08:00 \[1:zitadel1:podman\] 54a889ec22e83da4b9f903828199d7f14bcfbb01a7968964e357b8c44a92188a
2025-11-16T17:32:09+08:00 \[1:zitadel1:systemd\] Started libcrun container.
2025-11-16T17:32:09+08:00 \[1:zitadel1:systemd\] Started Podman zitadel.service.
2025-11-16T17:32:09+08:00 \[1:zitadel1:systemd\] Starting Podman postgresql-app.service…
2025-11-16T17:32:10+08:00 \[1:zitadel1:systemd\] Started libcrun container.
2025-11-16T17:32:10+08:00 \[1:zitadel1:zitadel1\] a22b511638ac1a109b1ece87a0b86dc2303a5d2f44dd11fb19860a81724150fc
2025-11-16T17:32:10+08:00 \[1:zitadel1:systemd\] Started Podman postgresql-app.service.
2025-11-16T17:32:10+08:00 \[1:zitadel1:systemd\] Starting Podman  zitadel-app.service…
2025-11-16T17:32:10+08:00 \[1:zitadel1:postgresql-app\]
2025-11-16T17:32:10+08:00 \[1:zitadel1:postgresql-app\] PostgreSQL Database directory appears to contain a database; Skipping initialization
2025-11-16T17:32:10+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:10.506 UTC \[1\] LOG:  starting PostgreSQL 17.7 (Debian 17.7-3.pgdg13+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 14.2.0-19) 14.2.0, 64-bit
2025-11-16T17:32:10+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:10.507 UTC \[1\] LOG:  listening on IPv4 address “0.0.0.0”, port 5432
2025-11-16T17:32:10+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:10.507 UTC \[1\] LOG:  listening on IPv6 address “::”, port 5432
2025-11-16T17:32:10+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:10.526 UTC \[1\] LOG:  listening on Unix socket “/var/run/postgresql/.s.PGSQL.5432”
2025-11-16T17:32:10+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:10.550 UTC \[25\] LOG:  database system was shut down at 2025-11-16 09:32:08 UTC
2025-11-16T17:32:10+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:10.569 UTC \[1\] LOG:  database system is ready to accept connections
2025-11-16T17:32:11+08:00 \[1:zitadel1:systemd\] Started libcrun container.
2025-11-16T17:32:11+08:00 \[1:zitadel1:zitadel1\] 1577519d485f1b0e4f37da9cd081ef01e057a8c06d100ddcfcb6b725cd07d54b
2025-11-16T17:32:11+08:00 \[1:zitadel1:systemd\] Started Podman  zitadel-app.service.
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“initialization started” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/init.go:70”
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify user” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_user.go:40” username=zitadel
2025-11-16T17:32:12+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:12.274 UTC \[29\] ERROR:  role “zitadel” already exists
2025-11-16T17:32:12+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:12.274 UTC \[29\] STATEMENT:  – replace zitadel with the name of the user
2025-11-16T17:32:12+08:00 \[1:zitadel1:postgresql-app\] 	CREATE USER “zitadel” WITH PASSWORD ‘4e2274557791e5cd’
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify database” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_database.go:40” database=zitadel
2025-11-16T17:32:12+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:12.275 UTC \[29\] ERROR:  database “zitadel” already exists
2025-11-16T17:32:12+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:12.275 UTC \[29\] STATEMENT:  – replace zitadel with the name of the database
2025-11-16T17:32:12+08:00 \[1:zitadel1:postgresql-app\] 	CREATE DATABASE “zitadel”
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify grant” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_grant.go:35” database=zitadel user=zitadel
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify zitadel” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:80” database=zitadel
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify system” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:46”
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify encryption keys” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:51”
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify projections” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:56”
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify eventstore” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:61”
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify events tables” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:66”
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify unique constraints” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_zitadel.go:71”
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“setup started” caller=“/home/runner/work/zitadel/zitadel/cmd/setup/setup.go:108”
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=14_events_push
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=40_init_push_func_v4
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=01_tables
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=02_assets
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=28_add_search_table
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=31_add_aggregate_index_to_fields
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=46_init_permission_functions
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“verify migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:46” name=03_default_instance
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=info msg=“starting migration” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:69” name=03_default_instance
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=error msg=“migration failed” caller=“/home/runner/work/zitadel/zitadel/internal/migration/migration.go:71” error=“ID=INST-mruNY Message=Errors.Invalid.Argument” name=03_default_instance
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=error msg=“migration failed” caller=“/home/runner/work/zitadel/zitadel/cmd/setup/setup.go:372” error=“ID=INST-mruNY Message=Errors.Invalid.Argument” name=03_default_instance
2025-11-16T17:32:12+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:12Z” level=fatal msg=“setup failed, skipping cleanup” caller=“/home/runner/work/zitadel/zitadel/cmd/setup/setup.go:124” error=“migration failed: ID=INST-mruNY Message=Errors.Invalid.Argument”
2025-11-16T17:32:12+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Main process exited, code=exited, status=1/FAILURE
2025-11-16T17:32:13+08:00 \[1:zitadel1:zitadel1\] 1577519d485f1b0e4f37da9cd081ef01e057a8c06d100ddcfcb6b725cd07d54b
2025-11-16T17:32:13+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Failed with result ‘exit-code’.
2025-11-16T17:32:13+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Consumed 1.199s CPU time.
2025-11-16T17:32:13+08:00 \[1:zitadel1:systemd\] zitadel-app.service: Scheduled restart job, restart counter is at 53.
2025-11-16T17:32:13+08:00 \[1:zitadel1:systemd\] Stopped Podman  zitadel-app.service.
2025-11-16T17:32:13+08:00 \[1:zitadel1:systemd\] Stopping Podman postgresql-app.service…
2025-11-16T17:32:13+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:13.390 UTC \[1\] LOG:  received fast shutdown request
2025-11-16T17:32:13+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:13.399 UTC \[1\] LOG:  aborting any active transactions
2025-11-16T17:32:13+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:13.403 UTC \[1\] LOG:  background worker “logical replication launcher” (PID 28) exited with exit code 1
2025-11-16T17:32:13+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:13.411 UTC \[23\] LOG:  shutting down
2025-11-16T17:32:13+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:13.421 UTC \[23\] LOG:  checkpoint starting: shutdown immediate
2025-11-16T17:32:13+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:13.473 UTC \[23\] LOG:  checkpoint complete: wrote 14 buffers (0.1%); 0 WAL file(s) added, 0 removed, 0 recycled; write=0.002 s, sync=0.022 s, total=0.062 s; sync files=11, longest=0.010 s, average=0.002 s; distance=65 kB, estimate=65 kB; lsn=0/1C72E30, redo lsn=0/1C72E30
2025-11-16T17:32:13+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:13.483 UTC \[1\] LOG:  database system is shut down
2025-11-16T17:32:13+08:00 \[1:zitadel1:zitadel1\] a22b511638ac1a109b1ece87a0b86dc2303a5d2f44dd11fb19860a81724150fc
2025-11-16T17:32:13+08:00 \[1:zitadel1:systemd\] Stopped Podman postgresql-app.service.
2025-11-16T17:32:13+08:00 \[1:zitadel1:systemd\] Stopping Podman zitadel.service…
2025-11-16T17:32:14+08:00 \[1:zitadel1:systemd\] Removed slice cgroup user-libpod_pod_54a889ec22e83da4b9f903828199d7f14bcfbb01a7968964e357b8c44a92188a.slice.
2025-11-16T17:32:14+08:00 \[1:zitadel1:systemd\] user-libpod_pod_54a889ec22e83da4b9f903828199d7f14bcfbb01a7968964e357b8c44a92188a.slice: Consumed 1.185s CPU time.
2025-11-16T17:32:14+08:00 \[1:zitadel1:podman\] zitadel
2025-11-16T17:32:14+08:00 \[1:zitadel1:podman\] 54a889ec22e83da4b9f903828199d7f14bcfbb01a7968964e357b8c44a92188a
2025-11-16T17:32:14+08:00 \[1:zitadel1:systemd\] Stopped Podman zitadel.service.
2025-11-16T17:32:14+08:00 \[1:zitadel1:systemd\] Starting Podman zitadel.service…
2025-11-16T17:32:14+08:00 \[1:zitadel1:systemd\] Created slice cgroup user-libpod_pod_9794cde04edddf2dfe376d0f54df2e3868324844f4ab4f24c024e09c3e11fa30.slice.
2025-11-16T17:32:14+08:00 \[1:zitadel1:podman\] 9794cde04edddf2dfe376d0f54df2e3868324844f4ab4f24c024e09c3e11fa30
2025-11-16T17:32:14+08:00 \[1:zitadel1:systemd\] Started libcrun container.
2025-11-16T17:32:14+08:00 \[1:zitadel1:systemd\] Started Podman zitadel.service.
2025-11-16T17:32:14+08:00 \[1:zitadel1:systemd\] Starting Podman postgresql-app.service…
2025-11-16T17:32:15+08:00 \[1:zitadel1:systemd\] Started libcrun container.
2025-11-16T17:32:15+08:00 \[1:zitadel1:zitadel1\] 18377f43f09665375fc5693a7787de52ee13b34be5c922ae4d7bb756d39bd309
2025-11-16T17:32:15+08:00 \[1:zitadel1:systemd\] Started Podman postgresql-app.service.
2025-11-16T17:32:15+08:00 \[1:zitadel1:systemd\] Starting Podman  zitadel-app.service…
2025-11-16T17:32:15+08:00 \[1:zitadel1:postgresql-app\]
2025-11-16T17:32:15+08:00 \[1:zitadel1:postgresql-app\] PostgreSQL Database directory appears to contain a database; Skipping initialization
2025-11-16T17:32:15+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:15.447 UTC \[1\] LOG:  starting PostgreSQL 17.7 (Debian 17.7-3.pgdg13+1) on x86_64-pc-linux-gnu, compiled by gcc (Debian 14.2.0-19) 14.2.0, 64-bit
2025-11-16T17:32:15+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:15.447 UTC \[1\] LOG:  listening on IPv4 address “0.0.0.0”, port 5432
2025-11-16T17:32:15+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:15.448 UTC \[1\] LOG:  listening on IPv6 address “::”, port 5432
2025-11-16T17:32:15+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:15.484 UTC \[1\] LOG:  listening on Unix socket “/var/run/postgresql/.s.PGSQL.5432”
2025-11-16T17:32:15+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:15.533 UTC \[24\] LOG:  database system was shut down at 2025-11-16 09:32:13 UTC
2025-11-16T17:32:15+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:15.567 UTC \[1\] LOG:  database system is ready to accept connections
2025-11-16T17:32:16+08:00 \[1:zitadel1:systemd\] Started libcrun container.
2025-11-16T17:32:16+08:00 \[1:zitadel1:zitadel1\] 054994a6dce5a9d21cc943f9b873378dc95932cf432006797e69f55e7dc168f0
2025-11-16T17:32:16+08:00 \[1:zitadel1:systemd\] Started Podman  zitadel-app.service.
2025-11-16T17:32:17+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:17Z” level=info msg=“initialization started” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/init.go:70”
2025-11-16T17:32:17+08:00 \[1:zitadel1:zitadel-app\] time=“2025-11-16T09:32:17Z” level=info msg=“verify user” caller=“/home/runner/work/zitadel/zitadel/cmd/initialise/verify_user.go:40” username=zitadel
2025-11-16T17:32:17+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:17.473 UTC \[28\] ERROR:  role “zitadel” already exists
2025-11-16T17:32:17+08:00 \[1:zitadel1:postgresql-app\] 2025-11-16 09:32:17.473 UTC \[28\] STATEMENT:  – replace zitadel with the name of the user
2025-11-16T17:32:17+08:00 \[1:zitadel1:postgresql-app\] 	CREATE USER “zitadel” WITH PASSWORD ‘4e2274557791e5cd’
hello @EXING_LEE am unable to recreate the error can you email me a meet link so that i can be able to assist you
@EXING_LEE were you able yo get zitadel running
