NethServer Version: latest
Module: zammad
i have installed zamamd, and on the settings of virtualhost, i used the server default hostname for zammad,
challenge is, when i try to access the url, zamadd does not load on that link
Module: zammad
You need a separate virtualhost domain. You can’t use the default hostname.
https://wiki.nethserver.org/doku.php?id=zammad#zammad_installation
so, now that i have already installed, will running config setprop zammad VirtualHost zammad.domain.local
with the new subdomain fix the issue, or do i have to reinstall
signal-event nethserver-zammad-update
should be enough…
