WPAD, DHCP, DNS, etc
Maybe :smile:
What IP do you want to put inside the WPAD? If the template puts the green IP, clients from blue will not work and the other way around.
Instead, you can create a DNS pointing to multiple IP, but from your tests it doesn’t seems to work correctly even with the DNS name.
I don’t see any clear solution, except of configuring the proxy in transparent mode.
Am I wrong? Any other suggestion?
I thought the same thing, but it still routes properly from the blue network and works perfectly. Here’s a screenshot of a Ubuntu VM in my test environment to illustrate:
Even though it’s on the blue network (192.168.10.0), it can still route to, contact, and download the wpad.dat from the router on its green IP (192.168.1.1). You can see Google and Yahoo HTTPS sites open in the background too.
Here’s another screenshot showing the current wpad.dat and the browser proxy settings. It’s using transparent proxy for http and manual for https. wpad is working beautifully with this setup.
I took testing a step further and added a second green zone with a Windows 7 VM and everything also works well there.
I’m just going to bump this again because I just had to manually modify another wpad.dat because hostname was causing problems. Setting it to the IP of the first green zone instead would be a wonderful solution. :smile:
Just opened a new issue: http://dev.nethserver.org/issues/3266
I think the development will be delayed after the release of 6.7.
That’s awesome! Thanks!
I’ll be switching my test VMs over to 6.7 later today. :smiley:
this issue was mantioned few month ago :
I did some testing with the new wpad setup to verify it functions how it should before I update my production NethServer instances.
With NS providing DHCP and DNS:
With a Server 2012 R2 AD DC providing DHCP and DNS:
From what testing I’ve done, everything appears to work great! Thank you devs!!
