WordPress loopback error
Updated to 1.3.1-dev.2
# This systemd unit starts a webserver instance using Podman.
# Most parts of this file come from podman-generate-systemd.
[Unit]
Description=Podman webserver.service
Requires=nginx.service
Before=nginx.service
[Service]
Environment=PODMAN_SYSTEMD_UNIT=%n
EnvironmentFile=-%S/state/environment
Restart=always
TimeoutStopSec=70
ExecStartPre=/bin/rm -f %t/webserver.pid %t/webserver.pod-id
ExecStartPre=/usr/bin/podman pod create --infra-conmon-pidfile %t/webserver.pid \
    --pod-id-file %t/webserver.pod-id \
    --name webserver \
    --publish 127.0.0.1:${NGINX_TCP_PORT}:80 \
    --publish  ${SFTP_TCP_PORT}:2022 \
    --publish  127.0.0.1:${SFTPGO_TCP_PORT}:8080 \
    --replace \
    --network=slirp4netns:allow_host_loopback=true
ExecStart=/usr/bin/podman pod start --pod-id-file %t/webserver.pod-id
ExecStop=/usr/bin/podman pod stop --ignore --pod-id-file %t/webserver.pod-id -t 10
ExecStopPost=/usr/bin/podman pod rm --ignore -f --pod-id-file %t/webserver.pod-id
PIDFile=%t/webserver.pid
Type=forking
[Install]
WantedBy=default.target
I am the pilot :smiley:
Does it fix your issue ?
Yes, no more loopback errors!
Can you try to upgrade or install another kind of webapp to be sure we have no regression
Updated normal PHP webserver (no WordPress) and all seems to be ok
