NS 7 beta1 is just around the corner (we’re waiting for SourceForge which is down since yesterday ),
in the meanwhile I would like to hear your opinion on the next steps.
Of course, we will be busy on catching and fixes bugs, but probably we also have time to develop some missing features.
That’s Collabra / Libreoffice online and it’s still got a ways to go before we should consider a module for it, but I’ve got my eye on it. I hate downloading, editing and re-uploading files.
I checked out their online demo, and installed their client on my smartphone. It’s amazing. It seems like it’s a web-port of a desktop application. It’s a bit slow, but you have Libreoffice, GIMP and other apps into your web browser!
I don’t mean to hijack this thread but this Open365 looks amazing. I know it’s still in beta but adding this to Nethserver would be quite the useful addition.
My brother @josean7link is proving NextCloud under Proxmox and Debian. (I think he has not done in NethServer by problems with the proxy of his office)
Some details Collabora / NextCloud the software warns:
We’ll describe how to get Collabora Online running on your server and how to integrate it into your Nextcloud using the docker image Nextcloud and Collabora built.
Requirements
To install it the following dependencies are required:
A host that can run a Docker container
A subdomain or a second domain that the Collabora Online server can run on
An Apache server with some enabled modules (NGNIX instructions in a blog here)
A valid SSL certificate for the domain that CollaboraOnline should run on
A valid SSL certificate for your Nextcloud
Note: This guide does NOT cover self-signed certificates. If you use a self-signed certificate then you’re mostly on your own
Yeah, I having a lot of problems with the proxy in the office because the new boss in database, they will need three to six month to answer to every problem the building had. Or that I hope so. Only the time will tell.
