I have had a veiw uses abusing the internet, I used LightSquid to see who it was. It gave me a few uses that were streaming/downloading videos.
My question is; What does LightSquid monitor? If i look at the month it give me a total of apporx. 75Gb used but the ISP says I have used 180G. Would like to know which of the monitors on NethServer will give me a very close result to theusage of the unternet?
As far as I understand it monitors port 80 http and port 443 https.
Other gigabytes like you have could be used in other ports maybe 22 ssh, 3389 rdp and other many ports …
Monitors and parses squid access.log
Install the ntopng package, this will give you realtime monitoring and you’ll be able to catch even the smarty ones bypassing squid.
Best regards,
Thank you guys… That is understood. What can I add to my NS server to track everything that flows throught it and give me some kind of daily report. Like Lightsquid days. ClearOS has something like that but I dont know what they using.
I’d take a look at Ntop, bandwidth monitoring module.
@alefattorini I did take a look at Ntop, maybe I am using it wrong. Ntop doesnt start at midnight to midnight and give you a report, when I open Ntop its starts reporting. For example if I wanted usage for a certain date last week. amount data used that day and who was the highest user. Like LightSquid is doing but capture all traffic through the gateway.
Ntop doesn’t have persistent data but it can give you a good overview on your realtime traffic
Thank you, I noticed that, I use it and like the output. Do you know of any plugin/addon I can install on my NS gateway/firewall that will give me a report of how much data in traffic Gb/Mb went through the gateway… I need to generate a report every morning for the boss. It would be nice if it also give me the high IP users.
