If you change something there, shows error. than all folders are gone, after you writeback nothing .
And i also noticed that when i make a new folder in Outlook 2016 it’s not shown in Webtop5.
Alternate root folder is the problem.
Try to delete User in Nethserver, reboot, zhan create user again, all setting are there in Webtop, again with the same error, no folder except inbox.
Sogo does not rewrite Mail Adresses wenn sending like user@domain.local to user@domain.com, and in Webtop 5 can’t see created folders in Outlook.
I’ll try with android…
Hi @stojovski,
i believe that this option is only available for compatibility with other mail servers other than Nethservice.
Certainly @gabriele_bulfon will have some more information on how to use this “Alternate root folder” option.
To resolve this issue and return to the default setting, just delete the straight line directly on the db as follows:
su - postgres -c 'psql webtop5'
delete from core.user_settings where key='defaultfolder';
\q
I recommend that you leave from WebTop5 avoiding going back with WebTop4
To reinstall WebTop5 you must remove the WebTop4 packages:
OK, THX, but consider that this does not to be there when does not work right.
I think that this option is a MailLocation for Dovecot?
And why the Folders that i make in Outlook 2016 are not shown in Webtop5?Is this a Z-Push problem or?
This works with SOgo.But Sogo has now a problem rewriting Mail adresses with Smarthost, from domain.local to domain.tld.
This has worked before.You can make an Alias, Domain etc, Sogo ignores all of that and sends the mail always as username domain.local.
