Weird clamd has less than 1M of used memory
NethServer Version: 7.5.1804
Module: clamav
I recently create a Proxmox KVM template of NS7.5 and decided to reinstall my two working NS7, I used the [ Backup/Restore of system configuration ] feature to accomplish this task, which by the way is great, good work, everything seems to work fine except for ClamAV. AFAIK, ClamAV uses quite a chunk of memory, before reinstalling it used up to 700MB, now it never goes beyond 1M, which is weird because it suppose to load the DB virus signature right?
Any thoughts?
Solved, I disable/enable the Anti-Virus feature, and it went to normal
