acsel10
(Alessio Orizio)
March 14, 2016, 9:09am
1
Hi all,
my Nethserver can’t reach the Blacklists from the sites designed in the /etc/cron.daily/squidGuard…
It says can’t resolve “ftp.teledanmark.no ”. And for the other wget, which is related to “ftp://ftp.univ-tlse1.fr/pub/reseau/cache/squidguard_contrib/adult.tar.gz ” it stucks in some operations and doesn’t downloaded the package.
With other sites no problem, it works!!!
How can i have the blacklists back to work ? I ask you DEV a check, please.
Thank you !
giacomo
(Giacomo Sanchietti)
March 14, 2016, 11:05am
2
The script you’re talking about is disabled in NS installation.
Have you enabled it by setting ENABLED
option to 1?
acsel10
(Alessio Orizio)
March 14, 2016, 11:38am
3
OK…the option is 0 so it’s not the right script.
Otherwise i’ve a problem, when i’ve tried to download and install a new blacklist the UI stuks in the 50% phase and doesn’t finish the process.
In this way the filter that i’ve configured seems doesn’t work.
What i’ve to do ?
Thx
giacomo
March 14, 2016, 12:23pm
4
Just execute this script and check where it hangs /etc/cron.daily/update-squidguard-blacklists.
You can execute also with debug:
sh -x /etc/cron.daily/update-squidguard-blacklists
acsel10
(Alessio Orizio)
March 14, 2016, 1:08pm
5
This is the output:
BLPATH=/var/squidGuard/blacklists
BLFILE=/var/squidGuard/blacklists/blacklists.tar.gz
URLFILE=/etc/squid/blacklists
DEBUG=0
++ date +%s
tot=1457960623
‘[’ ‘’ == -d ‘]’
++ pwd
curdir=/etc/squid
‘[’ -d /var/squidGuard/blacklists ‘]’
‘[’ -d /var/squidGuard/blacklists.old ‘]’
rm -rf /var/squidGuard/blacklists.old
mv /var/squidGuard/blacklists /var/squidGuard/blacklists.old
mkdir /var/squidGuard/blacklists
‘[’ 0 -eq 1 ‘]’
++ /bin/grep -v -e ‘^#’ -e ‘^$’ /etc/squid/blacklists
for url in ‘/bin/grep -v -e '\''^#'\'' -e "^$" /etc/squid/blacklists
download_extract http://www.shallalist.de/Downloads/shallalist.tar.gz
‘[’ 0 -eq 1 ‘]’
verbose=–quiet
wget --quiet -O /var/squidGuard/blacklists/blacklists.tar.gz http://www.shallalist.de/Downloads/shallalist.tar.gz
In fact shallalist.de is not reachable…i’ve just only to wait ???
acsel10
(Alessio Orizio)
March 14, 2016, 2:44pm
6
I’ve solved using urlblacklist ( commerical ).
Shalla doesn’t work at moment, just a notice.
Thx for the help
