VPN UI implementation on NS8
should be
firewall-cmd --permanent --add-port=51822/udp
is corrected
not quite true. Number 3. modprobe ip_tables has to be done also.
hint/suggestion: a command (which could be translated into a button) for generate a tunnel and a comand (also translable into button) to download keys/config file for wireguard?
Most of the code should be the same currently available for “container related” wiregard config generation.
@mz05er looks like our prayers have been answerd stephdl · GitHub
Il be patient and wait for the module officially, no need to begin tinkering on my server, and potentially break things.
49 posts were split to a new topic: Ns8-wg-easy App (WireGuard VPN)
