Use versioning of ownCloud for Shared Folder (Samba)
#1
I have the following scenario: I have shared folder configured and I can see the shared folder in ownCloud thorugh External Storage Support. When somebody changes a document in ownCloud in this folder, then ownCloud saves the old version of the document. I would like this to happen also when someone changes a document in the shared folder directly (through the net drive). So if someone changes a document in the shared folder on the net drive then the older version is saved in the ownCloud.
I guess there is no direct way to make this happen. Maybe through a script that gets triggered every time someone changes a document? Maybe someone from you has a idea how to implement/realise something like this?
Thanks!
Data from shared folder and owncloud in one place
(Alessio Fattorini) #2
I think this isn’t the proper place where to put such request, I suggest you open a new issue upstream:
