Something I’m not clear about is that with NC 23 it’s said Collabra is integrated… I assume it doesn’t actually auto install Collabra but I’m not clear on that, so if ones install is 22 with onlyoffice, what happens when you run the upgrade to 23, just an upgrade to NC without messing with onlyoffice or…?
That’s right.
Both Onlyoffice and Collabora work here with NC 23 after upgrade.
