I have updated to 6.7 yesterday, I found it too fast but why not. I have tried to use Activesync from WebTop but without success. Today, I have 214 updates available, but could not get through with the following error:
"[YumTestTransactionError] Erreurs de la transaction de test : file /usr/share/nethesis/NethServer/Language/it/NethServer_Module_DdClient.php from install of nethserver-lang-it-1.0.14-1.ns6.noarch conflicts with file from package nethserver-ddclient-1.0.1-3.ns6.noarch"
Any idea to solve that?
Thank you
Loïc
yes, confirmed. i’ve tried to install nethserver-ddclient on a 6.7rc1 before the final release and it worked so i don’t know…
if you don’t need ddclient
$ yum remove nethserver-ddclient
$ yum update
if you need ddclient give me some time to understand what’s changed from rc1…
I need ddclient because my server is at home behind a dynamic dns.
And thank you for your time and work.
This caused by this issue: http://dev.nethserver.org/issues/3265
The fix is already in place, but the packaged didn’t released a new package.
Also the package has been never published in nethforge-testing repo, and even worst there isn’t a nethforge-testing repository for 6.7.
Sadly the guy who is handling this stuff is not available at the moment, but give few days and I will try to fix it.
I will let you know.
For now, you just have to remove the package, but don’t worry, the configuration remain in place and ddclient should continue to work
ok, it seems to work now… if you want to test it:
if you don’t have dz00te repo configured:
add the repo:cat << ‘EOF’ > /etc/yum.repos.d/dz00te.repo
[dz00te]
name=dz00te repository for nethserver $releasever - $basearch
baseurl=http://mirror.framassa.org/NethServer/$releasever
enabled=0
gpgcheck=1
gpgkey=http://mirror.framassa.org/NethServer/RPM-GPG-KEY-dz00te
EOF$ yum --enablerepo=dz00te update nethserver-ddclient
if you already have have dz00te repo configured:
$ yum clean all --enablerepo=*
then
$ yum update
you should see the new package installed nethserver-ddclient-1.0.1-4.el6.noarch.rpm
[Do I have to unistall ddclient first?]
Update running…
no you should first update nethserver-ddclient and then update to 6.7
but removing nethserver-ddclient > update to 6.7 > reinstall new nethserver-ddclient should also work
Everything seems to have worked allright. Thank you.
After reboot, Jabber does not work, any advice?
sorry i don’t use jabber, but open a new thread to discuss details about it and mark this as solved
tnx
