i set up a Nethserver 7.7 on a VPS with RoadWarrior configured. I managed to link all my nodes (mostly openwrt routers) and i can now access those from the VPN. The problem is that with the former VPN i was able to route the packages to a remote LAN and now, with the same firewall configuration on the VPN endpoint supposed to act as gateway for the remote LAN that’s no longer working.
The network is more or less this:
VPN client (10.191.1.x)
VPN server ----- Remote lan gw (10.191.1.42)
(10.189.0.10) |
Remote lan (10.190.30.0/24)
but even creating the route manually won’t have the task done:
# route add 10.191.1.42 dev tun0
# route add -net 10.190.30.0/24 gw 10.191.1.42
# ping 10.190.30.1
PING 10.190.30.1 (10.190.30.1): 56 data bytes
^C
--- 10.190.30.1 ping statistics ---
6 packets transmitted, 0 packets received, 100% packet loss
Roadwarrior is configured in routed mode.
Thanks in advance,
-mmaridev
