Testing from ssh with speedtest-cli binding on the public ip address of the pppoe interface, works without issue:
[root@rt01 ~]# ip a |grep ppp
20: ppp0: <POINTOPOINT,MULTICAST,NOARP,UP,LOWER_UP> mtu 1492 qdisc pfifo_fast state UNKNOWN group default qlen 3
link/ppp
inet 93.xxx.xxx.x1 peer 79.98.41.5/32 scope global ppp0
[root@rt01 ~]# speedtest-cli --source 93.xxx.xxx.x1
Retrieving speedtest.net configuration...
Testing from Ehinet Srl (93.xxx.xxx.x1)...
Retrieving speedtest.net server list...
Selecting best server based on ping...
Hosted by Telecom Italia S.p.A. (Perugia) [23.00 km]: 23.448 ms
Testing download speed................................................................................
Download: 159.67 Mbit/s
Testing upload speed....................................................................................................
Upload: 18.10 Mbit/s
I do not know why is not working, maybe the interface ppp0 was not ready yet?
We could eventually perform the test without specifying the interface if the IP address is not found.
Of course, the command will give useful information only if there are no other red interfaces.
App.vue:312 Console was cleared
App.vue:313 ███╗ ██╗███████╗████████╗██╗ ██╗███████╗███████╗██████╗ ██╗ ██╗███████╗██████╗ ████╗ ██║██╔════╝╚══██╔══╝██║ ██║██╔════╝██╔════╝██╔══██╗██║ ██║██╔════╝██╔══██╗██╔██╗ ██║█████╗ ██║ ███████║███████╗█████╗ ██████╔╝██║ ██║█████╗ ██████╔╝██║╚██╗██║██╔══╝ ██║ ██╔══██║╚════██║██╔══╝ ██╔══██╗╚██╗ ██╔╝██╔══╝ ██╔══██╗██║ ╚████║███████╗ ██║ ██║ ██║███████║███████╗██║ ██║ ╚████╔╝ ███████╗██║ ██║╚═╝ ╚═══╝╚══════╝ ╚═╝ ╚═╝ ╚═╝╚══════╝╚══════╝╚═╝ ╚═╝ ╚═══╝ ╚══════╝╚═╝ ╚═╝
nethserver.js:41 API exec: system-authorization/read$ /usr/libexec/nethserver/api/system-authorization/read | jq
nethserver.js:41 API exec: system-task/read$ /usr/bin/setsid /usr/bin/sudo /usr/libexec/nethserver/api/system-task/read | jq
nethserver.js:41 API exec: system-settings/read$ echo '{"action":"hints"}' | /usr/bin/sudo /usr/libexec/nethserver/api/system-settings/read | jq
App.vue:451 tasks undefined
App.vue:451 tasks no running tasks
nethserver.js:41 API exec: system-apps/read$ echo '{"action":"info","name":"nethserver-firewall-base"}' | /usr/libexec/nethserver/api/system-apps/read | jq
nethserver.js:41 API exec: system-network/read$ echo '{"action":"list"}' | /usr/bin/sudo /usr/libexec/nethserver/api/system-network/read | jq
nethserver.js:41 API exec: nethserver-firewall-base/dashboard/read$ /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/dashboard/read | jq
nethserver.js:41 API exec: nethserver-firewall-base/settings/read$ echo '{"action":"status"}' | /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/settings/read | jq
nethserver.js:41 API exec: nethserver-firewall-base/wan/read$ echo '{"action":"providers"}' | /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/wan/read | jq
nethserver.js:41 API exec: nethserver-firewall-base/wan/read$ echo '{"action":"rules","expand":true}' | /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/wan/read | jq
nethserver.js:41 API exec: nethserver-firewall-base/objects/read$ echo '{"action":"hosts"}' | /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/objects/read | jq
nethserver.js:41 API exec: nethserver-firewall-base/objects/read$ echo '{"action":"host-groups"}' | /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/objects/read | jq
nethserver.js:41 API exec: nethserver-firewall-base/objects/read$ echo '{"action":"ip-ranges"}' | /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/objects/read | jq
nethserver.js:41 API exec: nethserver-firewall-base/objects/read$ echo '{"action":"cidr-subs"}' | /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/objects/read | jq
nethserver.js:41 API exec: nethserver-firewall-base/objects/read$ echo '{"action":"zones"}' | /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/objects/read | jq
nethserver.js:41 API exec: nethserver-firewall-base/objects/read$ echo '{"action":"time-conditions"}' | /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/objects/read | jq
nethserver.js:41 API exec: nethserver-firewall-base/objects/read$ echo '{"action":"services"}' | /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/objects/read | jq
nethserver.js:41 API exec: nethserver-firewall-base/rules/read$ echo '{"action":"roles"}' | /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/rules/read | jq
Dashboard.vue:554 Uncaught TypeError: Cannot read property 't' of null
at Dashboard.vue:554
at Function.<anonymous> (nethserver.js:108)
at s (cockpit.min.js:963)
at cockpit.min.js:975
at n (cockpit.min.js:881)
(anonymous) @ Dashboard.vue:554
(anonymous) @ nethserver.js:108
s @ cockpit.min.js:963
(anonymous) @ cockpit.min.js:975
n @ cockpit.min.js:881
setTimeout (async)
L @ cockpit.min.js:886
f @ cockpit.min.js:974
l @ cockpit.min.js:998
e @ cockpit.min.js:1025
(anonymous) @ cockpit.min.js:2071
se @ cockpit.min.js:77
e @ cockpit.min.js:206
p @ cockpit.min.js:591
m @ cockpit.min.js:600
v @ cockpit.min.js:494
a.onmessage.o.dispatch_data @ cockpit.min.js:424
nethserver.js:41 API exec: nethserver-firewall-base/wan/read$ echo '{"action":"speedtest","interface":"ppp0"}' | /usr/bin/sudo /usr/libexec/nethserver/api/nethserver-firewall-base/wan/read | jq
WAN.vue:2224 B {problem: null, exit_status: 1, exit_signal: null, message: "/usr/bin/sudo exited with code 1", toString: ƒ}
(anonymous) @ WAN.vue:2224
(anonymous) @ nethserver.js:119
setTimeout (async)
u @ cockpit.min.js:1004
e @ cockpit.min.js:1030
Well i think, it won’t be very usefull, like in my example if i have 2 wan 1 eth and 1 pppoe, you will have the value of the eth instead of the pppoe one
btw, how the ui fetch the ip here since it’s the correct one…?
my $ip = $addr->{'ipaddr'} || $addr->{'cidr'}; I don’t know if we should add also || ‘’ at the end and it will become: my $ip = $addr->{'ipaddr'} || $addr->{'cidr'} || '';
With pppoe interfaces cidr is initialized and ipaddr not.
