Redhat made a documentation on this, this should be nicer
I will add it to our software collection modules in the wiki
Wow, this is great. Canāt wait to test it.
Do you know if thereās another ISO release planned any time soon?
tl;dr
The 7.5.1804 ISO
that I used to install had an installer that kept failing, so I wasnāt able to install any other way than the automated installer, and somehow I borked my LVM so now itās not booting.
Iād like to modify partition strategy during installation just to be a plain XFS, EXT4 or BTRFS installation (preferably the latter so I can take snapshots easily for testing purposes).
I could submit another thread or bug report if you would like, but itās an old ISO so Iām not sure itās relevant anymore.
Specifically, anaconda
wouldnāt recognize any changes I made to the partition structure, I kept trying over and over and each time it would revert back to the structure existing on the SSD until finally after the 5th time the installer crashed entirely.
Btw, in case it matters, the test env Iāve been using this time is bare-metal:
Supermicro X9SCL-F BIOS v2.3 IPMI v3.3
Xeon E3-1230v2 socket 1155
32GB DDR3 1600MHz ECC UDIMM
LSI 9207-4i4e 2008 chipset SAS
300GB Intel S3500 SSD (G3)
1G NICs:
Intel 82574L and 82579LM
10G NIC:
Chelsio S320E-CXA
The Nethserver 7.6 ISO was released a few weeks back; IIRC. Itās on the download page:
https://www.nethserver.org/getting-started-with-nethserver/
PHP SCL is not an ISO or included in the ISO, it is a module from the stephdl repo. As @stephdl said, please see php-scl [NethServer Wiki]
Yep the link is
https://sourceforge.net/projects/nethserver/files/nethserver-7.6.1810-x86_64.iso/download
Great, Iāll try it - do you know if anyone else was complaining about the installer? (Iāll do a forum search ASAP)
Sounds good, thanks
