Try out NethServer 7 alpha 3!
Works oke :slight_smile:;
EDIT: my bad, no dependencies reintroduced.
It reintroduces the Cracklib dep :hushed:
(as said before it’s not a big deal)
It is a big deal, it should not reintroduce anything.
I will do a new clean installation, but in the meanwhile, can you please post the output of this command?
rpm -e --test perl-Crypt-Cracklib-1.7-1.ns7.x86_64
EDIT WAIT, wrong machine
Right machine:
I    nstalled Packages
    nethserver-lib.noarch                           2.1.5-1.18.gda59209.ns7                           @nethserver-updates
    [root@neth7a3 ~]# rpm -e --test perl-Crypt-Cracklib-1.7-1.ns7.x86_64
    error: Failed dependencies:
            perl-Crypt-Cracklib is needed by (installed) nethserver-directory-2.3.0-1.71.gc8592dd.ns7.noarch
dependency is solved in nethserver-directory-2.3.0-1.72
Sorry, my bad :hushed: nothing is reintroduced…
On armv7:
rpm -e --test perl-Crypt-Cracklib-1.7-5.ns7.armv7hl.rpm
error: package perl-Crypt-Cracklib-1.7-5.ns7.armv7hl.rpm is not installed
I have install Nethserver 7 a3 and I have noticeds two, unrelated, issues :
  1. with OpenVPN, installed through Software Center and configured as RoadWarrior + routed config :
    I can’t use system users, they won’t appear in the dropdwon list.
    If I create a “vpn only” user, the conf file generated is empty (even though the service is active and configured).
    As a result I am unable to connect clients to the server.
  2. with mail server :
    I have create a group successfully, with 2 users in it. When I want to create a shared email address, related to that group, the creation process seems to “do something” and then, no shared addresses appear in the UI panel.
Am I doing something wrong?
Anyway, beside that this is a great release, everything else I have tried (including Virtmanager) work great !
Thank you.
@Stll0 can you please investigate it?
You must create the related alias. @davidep, can you please describe the process (I don’t have an installation to check right now).
About OpenVPN :
I have tried to set things in different ways :
1st way, I :
  • create the user first
  • activate roadwarrior mode (checkbox)
  • set it (I have used custom settings and settings from the example given in Help)
  • confirm the settings
When i went back to “user” tab, I have download the conf file which size was 0 bit. Trying to open it confirmed that it was empty.
2nd way, I :
  • then create the user
File was empty as well.
It both cases, openvpn “host-to-net” service was, of course, started.
About shared mailboxes :
  • I set up my regular users (2 of them).
  • I create a group (called for ex. “group01” to which they both belong.
  • I create an alias that redirects to the 2 regular email addresses. This alias address has the same name as the group, ex: group01@domain.tld
  • I set a shared mailbox (name, ex : “Group_01”) that belongs to “group01@domain.tld”.
After submitting it, the shared maibox is not listing in the UI… but ! I have noticed since my previous post that it appears in mail client (roundcube or thunderbird).
The thing is that I can’t manage them (edit or delete) in mail client.
Am I missing something ?
You’re right, I’m able to reproduce the error. OpenVpn still needs some fixes.
This should be fixed by
http://packages.nethesis.it/nethserver/7.2.1511/testing/x86_64/Packages/nethserver-mail-server-1.9.1-1.95.g217a1f2.ns7.noarch.rpm
