Hello @support_team ,
A couple of years back I installed libreoffice on my Nethserver to assist me with being able to convert docx or xlsx files into PDF using a Nextcloud workflow.
I’m thinking it might be a good idea to occasionally upgrade my libreoffice. When I installed libreoffice I issued the following:
yum install libreoffice
Can support suggest what command I would use to upgrade my libreoffice on my Nethserver?
Also, I plan on testing the new Nextcloud Office and move away from OnlyOffice on my Nextcloud. Will having libreoffice on my Nethserver collide with using Nextcloud Office or Collabora?
Thank you.
