Terminal in Servermanager Cockpit is not working anymore
Good day,
I have some updates installed yesterday. Now I can no longer call in the Server Manager (Alpha) terminal.
After pressing the terminal always only the home page (Dashboard) appears.
thank you very much
Gottfried
Did you clear the browser cache after update?
For windows client you also should run ipconfig /flushdns at the commandline.
Is the same problem as reported here?
Hello Mr. Dreamer,
Thanks for your help. I did, unfortunately oh…
Could you try with a different browser?
The issue seems solved in Cockpit terminal problem.
Is that true @Amort_Gottfried? If yes, please mark this support thread as solved:
Hello Mr. Neuberger
The cockpit terminal problem is fixed
