NethServer Version: 7
Module: System
I have a question… is it advantageous to reboot every night the server with a cron setting or I have to leave the server up?
Thanks.
Federico Ballarini
Module: System
Thanks.
Federico Ballarini
there’s no reason to reboot a server (but for kernel update or other kind of updates)
moreover, reboot is the most critical status for your hw from many points of view
What kind of problem are you trying to resolve?
My server use about 10% of swap… is it normal?
I have 8GB of RAM…
[root@ns7dev9 ~]# cat /proc/sys/vm/swappiness
30
when you use about 70% of your ram then you start to play with your swap
On my server the response is “60” when I launch the command cat /proc/sys/vm/swappiness
then when you have used 40% of your ram you start to use the swap memory. It is a standard usage of swappiness. You can also look after with google how to change it, one example https://www.hostingstuff.net/tweak-swap-centos-7/
may I ask you to adjust your topic to something relevant on swap settings
But, in your idea… to which number I have to set this value?
You can start by a setting to 30-40
