Cloud or on premises?
On premise.
I have already tested with another S3 backup software (Iperius backup) from the outside and it works fine. I also tried with the following command and everything works.
db backups set [nome-backup] restic VFSType s3 BackupTime ‘15 7 * * *’ CleanupOlderThan never Notify error NotifyTo root@localhost status enabled Prune always S3AccessKey [utente] S3Bucket [bucket] S3Host https://[host] S3SecretKey ‘[password]’ status enabled
Unfortunately it doesn’t work as a cockpit.
Maybe I need to reconfigure min.io to be more like AmazonS3? I didn’t quite understand how to do it.
Yes, it’s just the check that does not work in some cases.
If you find a way to reconfigure it, it would be great.
Former problems were about bad certificate.
