Blocked by my provider
I opened a ticket
Thanks for your informations . In fact my server slowed down a lot in showing me the list of applications and loading updates.
rpm -e --nodeps nethserver-stephdl
you remove my repository, then reinstall it later
yum --disablerepo=stephdl,stephdl-roundcubemail update
it should be good but I needed to move my repository to another host, we need to wait dns propagation. For what I tested it is good.
Still waiting that my provider release my main host⊠joyeuse saint valentin
Hi I tried and at the moment it started working again
Ahh that is why I can no longer see anything loading in my application center⊠I also tried to do a âyum updateâ because I thought something was wrong and it kept on trying that address over and over. So when a mirror is not responding it could block everything else. Is there a way to put a timeout on mirrors that are not responding to prevent blocking ? Literally my applicationâs page is not loading anymore. Applications and Software Center actually.
yep this is something I found too⊠i am fixing it on my side
Cool Stephane! And thank you! It literally happened right after I downloaded the email server⊠Bad timing lol.
fixed timeout2 seconds maximum time 5 seconds
How much GB is your repo?
Have a simple vps01.havak.nl serving a tiny development repo with 60+ GB free space.
No clue how to setup an mirror but could (repo)sync your repo if it fitsâŠ
Ditto, on both counts.
Patience, everyone!
Thereâs NO way to speed up DNS, much less on a weekend.
A new Repo entry? Will also need to be replicated within DNSâŠ
Transfer the Registrar? Takes even longer than DNS replication!
Sure itâs a PITA, shows how many use Stephdlâs cool stuff!
But patience, and trust that Steph will give his provider a tough time!
Iâm not being in the least impatientâthese things happen, and Iâm not waiting on anything critical (I actually donât think Iâm waiting on anything at all ATM). But I think this shows that a mirror would be a good thing, and if someone can explain how to do it, Iâd be happy to host one.
There are docs how to provide a mirror for NethServer, but not for individual Repos. But it IS a good idea!
And Iâd host one to! Depending on space requirements, I could do 1 or 2âŠ
[nethserver-base]
name=NethServer-$nsrelease - Base
mirrorlist=http://mirrorlist.nethserver.org/?release=$releasever&repo=base&arch=$basearch&nsrelease=$nsrelease
#baseurl=http://mirror.nethserver.org/nethserver/$releasever/base/$basearch/
gpgcheck=1
repo_gpgcheck=1
gpgkey=file:///etc/pki/rpm-gpg/RPM-GPG-KEY-NethServer-$releasever
enabled=1
enablegroups=0
To make it efficient we should have something like this, make a repository list on a host that we are sure that it wonât never fail, because I simply do not know if yum keeps it in cache, if my main host with the list of mirrors does not answer, what it occurs ?
Of course it fails
so it doesnât help. When my server was on a SME Server, I got a rsync server, If I find time I could put one up, like this you can mirror, however it will be the same. I think wget can do the same too
of course if needed my mirror is yourâŠ
Of course it fails
I suppose a cloud load balancer would be needed, but I donât know if there are any for free
As a start a simple dual entry in DNS would be better than nothing⊠A dual or multile DNS entry results in a round robinâŠ
This was often done, before the advent of automatic multiple mirrors.
