having a slight issue with installing the proxy server with AD integration. It seems to work for 80% of the time but then randomly it will reject the credentials and the follow error occurring the cache file.
“ERROR: Negotiate Authentication validating user. Result: {result=BH, notes={message: received type 1 NTLM token; }}”
I’m running Windows 2008 Server and the clients are all Windows and running IE 11.
Well kind of, the error still appears periodically but most clients seem to be able to connect. New issue I’m facing is the WPAD file updating to an IP address rather than host name. Anyway around this or have a solution for forcing domain computers to use the proxy. GP has removed the proxy settings I believe
