Hi all,
can you check if also you see these strange buttons to sort tables after the last Cockpit update?
Update and then clean cache.
Hi all,
Yes, after the update I get the same.
@giacomo, @davidep and @edoardo_spadoni can you take a look at it?
Me two. Sorting can be done only clicking on that small rectagles. I found that into application page.
It seems the problem affects all the pages of nethserver-cockpit page, but bot the pages of the other modules.
Confirmed, @andre8244 is looking into it.
the issue is ready to be tested: https://github.com/NethServer/dev/issues/6390
I will test it in the afternoon
