1/ SOGo is not in Cockpit after installation.
2/ When we try to disable SOGo from nethgui:
Task completed with errors
Adjust service httpd #52 (exit status 1)
reload service httpd failed!
Could you post logs?
XXX XX XX:XX:XX sogod [XXXXX]: <XXXXXXXXXXXXXXXX[WOWatchDog]> Terminating with SIGINT or SIGTERM
XXX XX XX:XX:XX sogod [XXXXX]: <XXXXXXXXXXXXXXXX[WOWatchDogChild]> sending terminate signal to pid XXXXX
XXX XX XX:XX:XX sogod [XXXXX]: <XXXXXXXXXXXXXXXX[WOWatchDogChild]> child XXXXX exited
XXX XX XX:XX:XX sogod [XXXXX]: <XXXXXXXXXXXXXXXX[WOWatchDog]> all children exited. We now terminate.
Well netgui is now in maintenance mode but I could check for the bug of course, for the cockpit module it won’t be a NethServer project but community project and I need time to make it happen. (could try to start it this wk)
Eventually if you have skills on vuejs, I made a tool to scaffold a new rpm inside cockpit, after that you have just to code the web part of the menu and obviously the api written in perl.
As ever I am available.
It is important to have twice:
Cockpit is still beta, like you and others pointed there are still some bugs and features to cover. Cockpit needed quite one year and the work of all developers to be created…it is a nice project
in /var/log/messages you have all related messages of event triggered by the UI
Nov 23 08:42:42 prometheus httpd: AH00526: Syntax error on line 9 of /etc/httpd/conf.d/zzz_SOGo.conf:
trivial to fix, thank
