yes, I reboot the server and returned in group:
MailFieldNames = ("userPrincipalName");
Thanks
Thanks
You can use a custom template for it, if you do so it doesnât change after restartâŠ
https://docs.nethserver.org/projects/nethserver-devel/en/v7/templates.html
copy
/etc/e-smith/templates/etc/sogo/sogo.conf/45user_source
to
/etc/e-smith/templates-custom/etc/sogo/sogo.conf/45user_source
Do your change here and expand the template
expand-template /etc/sogo/sogo.conf
I push an update
EDIT: @xalex77 what is the ldap attribute for the user email in AD ?
I introduced a vars to change it manually
sogod{'CustomEmailField'}
config setprop sogod CustomEmailField mail
signal-event nethserver-sogo-update
this will change for the user and the group the ldap attribute
thank you, lets drop the CL I given above
could you test in few minute the rpms in the PR
yum install http://packages.nethserver.org/nethserver/7.7.1908/nethforge-autobuild/x86_64/Packages/nethserver-sogo-1.7.7-1.3.pr35.g349253a.ns7.noarch.rpm
delete â/etc/e-smith/templates-custom/etc/sogo/sogo.conf/45user_sourceâ and I run?
After deleting the custom-template you have to expand it again with
Iâve tried, but itâs not good
you have changed in AD group:
displayName = "mail";
while you have to change
MailFieldNames = ("mail");
the change to do is:
to
how can i remove the patch? or do you make a new ?
thanks
yum downgrade nethserver-sogo
Sorry I will change my error
this is the change this time @xalex77
yum install http://packages.nethserver.org/nethserver/7.7.1908/nethforge-autobuild/x86_64/Packages/nethserver-sogo-1.7.7-1.3.pr35.g250131d.ns7.noarch.rpm
in AD users:
filter = "(objectClass='user')";
can be changed to
filter = "(objectClass='user') AND (sAMAccountType=805306368)";
otherwise in the user list you also see the names of the PCs added to the domain in AC
you can make the change with an rpms?
okâŠneed to check also if we have no drawbacks
please @quality_team @support_team could you valid this, After the installation I can login, use the addressbook with the internal sambaADâŠdoes it is the same with your server and with a remote SambaAD or AD
