yum update sogo\* sope\* ytnef\* --enablerepo=nethforge-testing
or for a first installation
yum install nethserver-sogo --enablerepo=nethforge-testing
I needed to add nethserver-sogo to update it too.
The update worked without errors in messages log, contacts still there, mailing works.
Fresh install on a VM worked as expected.
For me it works without adding it. I only use calendar, they are still there.
It may work but is the new nethserver-sogo version from nethserver-testing installed?
[root@server2 ~]# rpm -q nethserver-sogo
nethserver-sogo-1.8.5-1.6.g0122ef1.ns7.noarch
normally you do not need to update nethserver-sogo, I suggest in your case to downgrade nethserver-sogo from stable
yum downgrade nethserver-sogo
If we might have more people to test and verify we have no issue we could release it
Updated without issue and confirmed to send/receive email and calendar sync between Outlook client and SOGo.
released, thank mates
Thanks for your work
