What version of NS? NS 6.7?
@GG_jr yes 6.7
Just installed without any other settings?
Can you adjust the mail layout for 3 horizontal panes?
Just Add repo like @stephdl said.
yum --enablerepo=sogo-rhel6 update
They say here that •horizontal 3-pane view for a better experience on large desktop screens;
maybe Developers in Horizontal but WEBUI is in Vertical 3 pane
Anyway, nice work! You too!
looks like it missed some features that are in v. 2, for example in the demo drag & drop of emails doesn’t work…
@nas: can you try on your setup?
It could be a consequence of Material Design: touch screens do not work well with drag and drop.
Maybe, but it’s a must in an email client
BTW, it seems that it lacks a “move” feature too… you can only copy an then delete a message
thank you…
the issue is (seems to be) that you can’t just drag an email and drop it into a another folder… can you test please?
TIA
Yes, Drag and drop email is not working. It is not an issue it is an enhancement for dummies.
I disagree
In a full featured webmail/workgroup app that aims to be a desktop email client replacement thi si a big limitation
Can you confirm me that there’s no “move” action available for emails?
I can confirm this limitation, I have not found Move option in email.
BTW I should report the BUG )
I think it’s not a bug, but by design
Thanks for the tests guys, it will released directly into the NethServer 7 alpha 2
