We have improved ActiveSync support for big email accounts and fixed some bugs:
http://dev.nethserver.org/issues/3123
http://dev.nethserver.org/issues/3122
http://dev.nethserver.org/issues/3116
Do you wanna try the new version?
Click on SoGo Groupware on Software Center to install or the upgrade button for existing installation
Changes from the last version
- allow including or not freebusy info from subscribed calendars
- now possible to set an autosave timer for draft messages
- now possible to set alarms on event invitations
- updated CKEditor to version 4.4.6 and added the ‘Source Area’ plugin
- sogo-tool can now be used to manage EAS metadata for all devices
- added support for multiple calendars and address books over ActiveSync
(Spain) translationsupdated Brazilian Portuguese, Czech, Dutch, Finnish, French, German, Hungarian, Polish, Russian, Spanish (Argentina), and Spanish
support for recurrent tasks
support for alarms on recurrent events / tasks
alarms can now be snoozed for 1 day
new user settings for threads collapsing
IMAP global search support
printing calendars in colors is now possible in all views; list, daily, weekly and multicolumns
new option to print calendars events and tasks with a background color or with a border color
all modules can now be automatically refreshed
new user preference to prevent event invitations
now possible to DnD events in the calendar list
add new 'multi-columns' calendar view (#1948)
contacts photos are now synchronized using ActiveSync (#2807)
now display the active tasks next to calendar names (#2760)
new print option in Calendar module
now able to save unknown recipient emails to address book on send (#1496)
SOGo version is now displayed in preferences window (#2612)
report Sieve error when saving preferences (#1046)
addressbooks properties are now accessible from a popup window
extended events and tasks searches
it's now possible to set a default reminder for calendar components using SOGoCalendarDefaultReminder
select multiple files to attach to a message or drag'n'drop files onto the mail editor; will also now display progress of uploads
new popup menu to download all attachments of a mail
move & copy messages between different accounts
support for the Sieve 'body' extension (mail filter based on the body content)
