been using SME/Koozali at various sites since version 4. It’s been very solid, but as many will know is lagging seriously at the moment, especially where Windows 10/Samba4/Centos7 support is concerned.
Consequently, I’m looking at options including Nethserver
I have questions about whether I’d encounter migration issues. Here’s the system configuration of the largest candidate for migration:
2xSME Server 9.2 with minimal add-ons (admin, out-of-office, easily removed)
Virtualised, running on Proxmox
14Tib filesystem and 7TiB filesystem iSCSI mounted exported by separate storage server
One email domain, about 60 users
No hosted websites
Server-only with separate perimeter firewalls etc.
The iSCSI mount of /home/e-smith/files means that it is easy to move the large f/s to another virtual or physical SME-server machine in the event of hardware failure or compromise.
However, as I understand it the ‘ibay’ equivalent paths are all different and revised in Nethserver.
Unmounting the f/s, there’s only a minimal vm image (30MB or so) to backup and restore to Nethserver – but how would I remount the iSCSI export? Changed paths? Permissions?
A 21TiB backup and restore could cause interesting issues I suspect using the migration tool? (Like, days of downtime).
I should add as this is commercial-use area, we’ll be happy to pay for support if the move is chosen and feasible…!
Just talked to the sales department: Nethesis could provide such service.
The prerequisite is a subscription on the server (see https://my.nethserver.com/login).
I guess you will need at least a couple of tickets to get the migration done: one for the analysis and one (ore more, depending on the analysis findings) for the actual work.
Thank you for the replies and advice. I will be having a technical
meeting with staff in the next couple of days: we will probably migrate
a small system that’s less complex over to Nethserver and give that a
bit of a kicking around to see how we get on before making further
plans. However after that we may well be interested in proceeding as
discussed.
For a small migration (i.e., my home), I found the rsync-migrate script to work really well with minimal downtime. You should see documentation for it at the page linked above.
