mrmarkuz
(Markus Neuberger)
October 26, 2017, 9:01am
61
Haha language challenge!
I translated the post of @Valeriy to English with Google:
Valeriy:
Google Chrome browsers, opera, firefox
Windows 10
Windows 2016 DHCP, DNS
Nethserver proxy
ports are not blocked.
Content filter and dpi is not used.
On a computer where proxy bypass is enabled, there are no problems with access.
If you disable the proxy, there are no problems on all computers.
If you turn on transparent mode without SSL, there is no problem on all computers.
If you enable transparent mode with SSL delay of about 20 seconds, the computers that are included in the proxy bypass are not affected.
Is it possible to reset all settings to NS in the NS (like a clean installation)? Or try to make a new installation?
mrmarkuz
(Markus Neuberger)
October 26, 2017, 9:10am
62
Yes, with backup/restore procedure AFAIK. You may make a full backup and then setup a new Nethserver and start with disaster recovery:
http://docs.nethserver.org/en/v7/backup.html
http://docs.nethserver.org/en/v7/backup.html#disaster-recovery
m.traeumner
(Michael Träumner)
October 26, 2017, 9:35am
63
I would test proxy before recovery, if there are config problems you get them back with recovery.
Valeriy
(Valeriy)
October 26, 2017, 10:14am
64
I meant reset to the original settings like in windows 10.
mrmarkuz
(Markus Neuberger)
October 26, 2017, 10:17am
65
Sorry, that way it is not possible AFAIK.
I have one issue with the IPS module… I have solve with disabling “INFO” block.
Valeriy
(Valeriy)
October 26, 2017, 5:30pm
67
I conducted the experiment. Installed the virtualbox and installed NethServer 7.4.1708 Final. The Web proxy with the SSL is working fine.
m.traeumner
(Michael Träumner)
October 27, 2017, 7:14am
68
So I think there is an configuration error or perhaps a hardware error at your production server.
Could you do a snapshot at virtual box and after that try to recover your backup at virtual box image.
