The default route on the Nethserver is to RED (eth2 in my case) which makes sense:
# ip route
default via WW.XXX.YYY.ZZZ dev eth2
WWW.XXX.YYY.0/24 dev eth2 proto kernel scope link src WWW.XXX.YYY.ZZZ
10.0.9.0/24 dev br0 proto kernel scope link src 10.0.9.100
192.168.99.0/24 dev eth3 proto kernel scope link src 192.168.99.1
Thank you all for your input and help!
We have managed to get it running, both in the test and and production environment.
The problem was that I needed to have the gateway set on all the clients to the nethserver. I don’t know why it’s required, when it’s not required in our current network Zyxel solution.
Our next challenge is to change the gateway on all our clients and servers.
We would like to be able to reach our different networks without setting our gateway, like it works when you set all interfaces to RED.
