Thanks, I did that, and I am still getting rejections. Following is an excerpt from the maillog:
Nov 14 12:42:52 juliet postfix/smtp[7063]: 4982A6005B82B: to=valthernielsen@gmail.com, relay=smtp.comcast.net[96.114.157.81]:587, delay=6917, delays=6886/0.07/31/0.15, dsn=5.1.0, status=bounced (host smtp.comcast.net[96.114.157.81] said: 550 5.1.0 vnielsen@deltaecho.lan sender rejected : invalid sender domain (in reply to MAIL FROM command))
Nov 14 12:42:52 juliet postfix/cleanup[7100]: 8F04D6005B826: message-id=20171114204252.8F04D6005B826@juliet.deltaecho.lan
Nov 14 12:42:52 juliet postfix/bounce[7099]: 4982A6005B82B: sender non-delivery notification: 8F04D6005B826
How do you check the response to helo command? and would that be different from ‘mail from’?
Finally I realized that defining a virtual server was not enough to receive mail from Internet, so I also created mail aiiases for individual users. Since Comcast blocks port 25 I am using a forwarder to send the mail to port 587. I appears that mail is rejected unless I enter the forwarder’s IP in ‘SMTP Access’. Is that correct?
