Should a user be able to share a folder with an LDAP group??
Perhaps these issues only appear when using external account providers?
Creating sub-folders are seen on all IMAP clients within each account ( eg … account1 sees folders created on any device)
Anything I can provide for troubleshooting, please let me know.
Could you check the file of users into /var/lib/nethserver/vmail/user@domain/subscriptions and check if there is the folder? If not could you try add the shared folder into this file with correct path?
Then restart dovecot and logout/login into SOGo and check.
Long story short… For what i am able to understand LDAP-fetched groups are entities that allow postfix to deliver messages.
But for what i can understand, dovecot (or SOGo?) is not using the same data for create an access control list.
That’s what I am thinking. Works for many thing, but as a complete solution to exchange it’s not quite there yet. Maybe in time. All aside, very happy with nethserver as a whole
Well… Exchange, Domino and other products are not monolythic, but they are created to achieve a goal, payed also by licensing.
Any OpenSource projects who try to mimic them is most about integration and connection of different softwares. This is a strenght, because it’s possible switch parts or extend capabilities in many ways, but makes a bit harder to get gears run from top to the bottom.
I hope that someone will be able to find will tell me how wrong i am explaining how to help you, @SGVFR
