No problem,but I need to test voor @davidep and need to describe a bunch of other things as well … feel free to rip it and put it there
no credit needed.
OMG
OMG
OMG ![]()
I finally got in webinterface ![]()
I used the command scrip below using enp4s0 instead of enp0s8:
Thank you Thank you
Glad it works!
Please mark the answer that helped you (the answer of @dnutan in this case) as solution:
https://community.nethserver.org/t/howto-mark-a-topic-as-solved/1750
This way others with similar problems will be able to find a solution quickly.
Have fun with Nethserver … you’ll probably be happy you went the extra mile! Welcome on board
If I can make a small suggestion. Would be ideal if Nethserver can show a network console after first reboot. This is how I got clearos 7.4 to work the first time without needing to use command line.
Usually you get to network config after first setup wizard.
What about this solution?
