I can not get the gui running. It appears to be a screen resolution problem. How can I change my resolution to something useable and not continual command line?
Web UI works even on phone small screens. Can you show us a picture of your problem?
Only thing I have is the command line. I can get into root, but that is as far as it goes. I can also command line through the file system as well. My screen can do 1024X768, but it is at 720X400.
On the system where Nethserver is installed, you have only the command line.
There’s no X windows systen and no graphical environment.
You must connect to the Nethserver system with another computer/tablet with a web browser…
Look at this:
http://docs.nethserver.org/en/latest/access.html
It’s really odd, could you explain better your problem? Screenshot or pics might be helpful
Sorry for the late reply.
When I install the distro I have a GUI installation and I’m able to get a successful installation. However, after I reboot into the operating system I no longer have a desktop GUI. I can use the command line as normal, but no GUI. The monitor and screen resolution are fine and display correctly. It appears to be a driver issue, however I would think I would have the same problem during installation. Like I said the GUI during installation is there, but not after re-booting into the operating system.
It’s normal.
Now to access the Nethserver webgui, in another computer, with a web browser, go
http://ip_of_your_nethserver:980.
Read the link I put above… The only thing I can tell to be clearer:Tthe access is from another computer, not from the Nethserver itself.
