I think the same, in the next release i change this name.
For other problem… i don’t know ![]()
BTW: it works just fine!
I just updated to the new version without any problems. Great work @gecco
Installed without problems, works as expected!
@gecco I’m thinking about designing the File server Cockpit UI. I’d like to see the smbstatus output in the File server dashboard page …What do you think? Do you already have some plans for Samba Status on Cockpit?
yes… but i have to understand cockpit ![]()
i read some documentation but, for my skill, are a little complicated
What is causing trouble?
If you have any question about the cockpit UI or anything else, please ask!
I’d like also to catch some ideas from you or the Samba status users to improve the core Samba and AD accounts provider module!
Functions and json objects, yes it is a little strange at the beginning but this is what is the web development. However once you caught it, or you admitted the general behavior, my general feeling is that it could be quite simple.
I am sure you will have some troubles until you find the way to save/read your first property, then after you will go further and faster…at least this is what I experienced.
but how can i exec a command the print the output?
The log output we made for applications could be a good example, but I would prefer that @edoardo_spadoni answers
If you prefer a full js example you could look to nethserver-ejabberd
Obviously I will need the answer for nethserver-diagtools, so thank to ask it first
Hi, you have different kind of API to exec a command and get an output. In this file: NethServer Lib you can use one of the methods listed to get an output.
exec: is used to call a script in /usr/libexec/nethserver/api/... JSON is used for input and output, you can see many examples in the nethserver-cockpit module, the core one.
Es. echo '{"action":"list"}' | /usr/libexec/nethserver/api/system-network/read | jq: print network intefaces list
execRaw: is used to output a command without using JSON, it’s like calling a command from bash and get the output, probably what you searching for. Example here.
execHints: used to get system hints like: Backup: You should configure at least one data backup, Company: Change the default company. Example here
readLogs: used to get the logs output in dump o follow mode. Example here
A recap to written API o UI guidelines is here.
thank you @edoardo_spadoni
Just to be clear, the samba status is already implemented inside the new UI: File server Cockpit UI
But currently it doesn’t include the list of joined machines along with their last logon because that should be part of the AD acount provider
hello - latest rpm seems to not be able to install
any ideas?
I had to download the file first. It’s not possible to download with yum.
wget http://minucci.net/nethserver/nethserver-sambastatus-7.3-1.noarch.rpm
yum install nethserver-sambastatus-7.3-1.noarch.rpm
This module is for the stable server manager. You may have a look at the new server manager.
