Samba is not working (SSSD accountsprovider error)
Nope, I was avaiable to update from 7.3 to 7.4 from 7.4 to 7.5 when this happens.
[root@nethserver ~]# config show proxy
proxy=configuration
host=
password=
port=
user=
We need a working DNS enviroment to proceed. I want to be sure all packages are at their latest version!
Anybody who wants to help to troubleshoot this DNS is welcome! /cc @support_team
Format the machine!!! in few words :smiley: for 20 days I can’t move it, now is serving a web applicatión for information with public clients, 20 days and I can disable the machine and setup NethServer 7.5.1804 to fix this strange hijack.
This machine is so important, It Will show the benefits of NethServer to future clients, i Will demmand Crostino plan for support them.
Do what you want with your server, but if the origin of the problem is not found it will beat you again :wink:
Ok, 20 days to find the solution, Hands on!!!
Let’s try
 dig www.nethserver.org
 dig www.nethserver.org @8.8.8.8
[root@nethserver ~]# dig www.nethserver.org
; <<>> DiG 9.9.4-RedHat-9.9.4-61.el7 <<>> www.nethserver.org
;; global options: +cmd
;; connection timed out; no servers could be reached
[root@nethserver ~]# dig www.nethserver.org @8.8.8.8
; <<>> DiG 9.9.4-RedHat-9.9.4-61.el7 <<>> www.nethserver.org @8.8.8.8
[root@nethserver ~]# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8) 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=59 time=1.88 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=59 time=1.83 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=59 time=7.29 ms
Is it possible that your firewall blocks DNS tcp/udp port 53 from nethserver?
Can you attach the complete list of RPMs? I want to be sure we’re not missing some important update…
 rpm -qa | sort
It’s Full Opened for pfsense ports, it was working Until 2 weeks ago.
[root@nethserver ~]# rpm -qa | sort
acl-2.2.51-14.el7.x86_64
adcli-0.8.1-4.el7.x86_64
aic94xx-firmware-30-6.el7.noarch
alsa-firmware-1.0.28-2.el7.noarch
alsa-lib-1.1.4.1-2.el7.x86_64
alsa-tools-firmware-1.1.0-1.el7.x86_64
altermime-0.3.10-10.el7.x86_64
amavisd-new-2.11.0-3.el7.noarch
apache-commons-collections-3.2.1-22.el7_2.noarch
apache-commons-daemon-1.0.13-7.el7.x86_64
apache-commons-dbcp-1.4-17.el7.noarch
apache-commons-logging-1.1.2-7.el7.noarch
apache-commons-pool-1.6-9.el7.noarch
apr-1.4.8-3.el7_4.1.x86_64
apr-util-1.5.2-6.el7.x86_64
arj-3.10.22-22.el7.x86_64
arp-scan-1.9.2-1.el7.x86_64
at-3.1.13-23.el7.x86_64
atk-2.22.0-3.el7.x86_64
attr-2.4.46-13.el7.x86_64
audit-2.8.1-3.el7.x86_64
audit-libs-2.8.1-3.el7.i686
audit-libs-2.8.1-3.el7.x86_64
audit-libs-python-2.8.1-3.el7.x86_64
augeas-libs-1.4.0-5.el7_5.1.x86_64
authconfig-6.2.8-30.el7.x86_64
autogen-libopts-5.18-5.el7.x86_64
automysqlbackup-3.0.RC6-6.ns7.sdl.noarch
avahi-libs-0.6.31-19.el7.x86_64
avalon-framework-4.3-10.el7.noarch
avalon-logkit-2.1-14.el7.noarch
basesystem-10.0-7.el7.centos.noarch
bash-4.2.46-30.el7.x86_64
bind-libs-9.9.4-61.el7.x86_64
bind-libs-lite-9.9.4-61.el7.x86_64
bind-license-9.9.4-61.el7.noarch
bind-utils-9.9.4-61.el7.x86_64
binutils-2.27-27.base.el7.x86_64
biosdevname-0.7.3-1.el7.x86_64
boost-regex-1.53.0-27.el7.x86_64
boost-system-1.53.0-27.el7.x86_64
boost-thread-1.53.0-27.el7.x86_64
bridge-utils-1.5-9.el7.x86_64
btrfs-progs-4.9.1-1.el7.x86_64
bzip2-1.0.6-13.el7.x86_64
bzip2-debuginfo-1.0.6-13.el7.x86_64
bzip2-libs-1.0.6-13.el7.i686
bzip2-libs-1.0.6-13.el7.x86_64
cabextract-1.5-1.el7.x86_64
ca-certificates-2018.2.22-70.0.el7_5.noarch
cairo-1.14.8-2.el7.x86_64
c-ares-1.10.0-3.el7.x86_64
celt051-0.5.1.3-8.el7.x86_64
centos-logos-70.0.6-3.el7.centos.noarch
centos-release-7-5.1804.el7.centos.2.x86_64
centos-release-scl-2-2.el7.centos.noarch
centos-release-scl-rh-2-2.el7.centos.noarch
certbot-0.24.0-1.el7.noarch
checkpolicy-2.5-6.el7.x86_64
chkconfig-1.7.4-1.el7.x86_64
chrony-3.2-2.el7.x86_64
c-icap-0.5.2-1.ns7.x86_64
c-icap-libs-0.5.2-1.ns7.x86_64
cifs-utils-6.2-10.el7.x86_64
clamav-0.99.4-1.el7.x86_64
clamav-data-0.99.4-1.el7.noarch
clamav-filesystem-0.99.4-1.el7.noarch
clamav-lib-0.99.4-1.el7.x86_64
clamav-server-0.99.4-1.el7.x86_64
clamav-server-systemd-0.99.4-1.el7.noarch
clamav-unofficial-sigs-3.7.2-1.el7.noarch
clamav-update-0.99.4-1.el7.x86_64
clucene-core-2.3.3.4-11.el7.x86_64
compat-libtidy-0.99.0-37.20091203.el7.x86_64
composer-1.6.5-1.el7.noarch
copy-jdk-configs-3.3-10.el7_5.noarch
coreutils-8.22-21.el7.x86_64
cpio-2.11-27.el7.x86_64
cracklib-2.9.0-11.el7.i686
cracklib-2.9.0-11.el7.x86_64
cracklib-dicts-2.9.0-11.el7.x86_64
cronie-1.4.11-19.el7.x86_64
cronie-anacron-1.4.11-19.el7.x86_64
crontabs-1.11-6.20121102git.el7.noarch
cryptsetup-1.7.4-4.el7.x86_64
cryptsetup-libs-1.7.4-4.el7.x86_64
cups-libs-1.6.3-35.el7.x86_64
curl-7.29.0-46.el7.x86_64
cyrus-sasl-2.1.26-23.el7.x86_64
cyrus-sasl-gssapi-2.1.26-23.el7.x86_64
cyrus-sasl-lib-2.1.26-23.el7.x86_64
cyrus-sasl-md5-2.1.26-23.el7.x86_64
cyrus-sasl-plain-2.1.26-23.el7.x86_64
davfs2-1.4.7-6.el7.x86_64
dbus-1.10.24-7.el7.x86_64
dbus-glib-0.100-7.el7.x86_64
dbus-libs-1.10.24-7.el7.x86_64
dbus-python-1.1.1-9.el7.x86_64
dejavu-fonts-common-2.33-6.el7.noarch
dejavu-sans-fonts-2.33-6.el7.noarch
dejavu-sans-mono-fonts-2.33-6.el7.noarch
deltarpm-3.6-3.el7.x86_64
device-mapper-1.02.146-4.el7.x86_64
device-mapper-event-1.02.146-4.el7.x86_64
device-mapper-event-libs-1.02.146-4.el7.x86_64
device-mapper-libs-1.02.146-4.el7.x86_64
device-mapper-persistent-data-0.7.3-3.el7.x86_64
dhclient-4.2.5-68.el7.centos.1.x86_64
dhcp-common-4.2.5-68.el7.centos.1.x86_64
dhcp-libs-4.2.5-68.el7.centos.1.x86_64
dialog-1.2-4.20130523.el7.x86_64
diffutils-3.3-4.el7.x86_64
dmidecode-3.0-5.el7.x86_64
dnsmasq-2.76-5.el7.x86_64
dosfstools-3.0.20-9.el7.x86_64
dovecot-2.2.10-8.el7.x86_64
dovecot-antispam-0.0.49-3.ns7.x86_64
dovecot-deleted-to-trash-0.6-3.ns7.x86_64
dovecot-pigeonhole-2.2.10-8.el7.x86_64
dracut-033-535.el7.x86_64
dracut-config-rescue-033-535.el7.x86_64
dracut-network-033-535.el7.x86_64
duc-1.4.2-1.ns7.x86_64
duplicity-0.7.17-1.el7.x86_64
e2fsprogs-1.42.9-12.el7_5.x86_64
e2fsprogs-debuginfo-1.42.9-12.el7_5.x86_64
e2fsprogs-libs-1.42.9-12.el7_5.x86_64
ebtables-2.0.10-16.el7.x86_64
ecj-4.5.2-3.el7.x86_64
ejabberd-16.01-0.x86_64
elfutils-default-yama-scope-0.170-4.el7.noarch
elfutils-libelf-0.170-4.el7.i686
elfutils-libelf-0.170-4.el7.x86_64
elfutils-libs-0.170-4.el7.i686
elfutils-libs-0.170-4.el7.x86_64
enchant-1.6.0-8.el7.x86_64
environment-modules-3.2.10-10.el7.x86_64
epel-release-7-11.noarch
erlang-asn1-R16B-03.18.el7.x86_64
erlang-compiler-R16B-03.18.el7.x86_64
erlang-crypto-R16B-03.18.el7.x86_64
erlang-erts-R16B-03.18.el7.x86_64
erlang-hipe-R16B-03.18.el7.x86_64
erlang-inets-R16B-03.18.el7.x86_64
erlang-kernel-R16B-03.18.el7.x86_64
erlang-mnesia-R16B-03.18.el7.x86_64
erlang-os_mon-R16B-03.18.el7.x86_64
erlang-otp_mibs-R16B-03.18.el7.x86_64
erlang-public_key-R16B-03.18.el7.x86_64
erlang-runtime_tools-R16B-03.18.el7.x86_64
erlang-sasl-R16B-03.18.el7.x86_64
erlang-sd_notify-0.1-1.el7.x86_64
erlang-snmp-R16B-03.18.el7.x86_64
erlang-ssl-R16B-03.18.el7.x86_64
erlang-stdlib-R16B-03.18.el7.x86_64
erlang-syntax_tools-R16B-03.18.el7.x86_64
erlang-tools-R16B-03.18.el7.x86_64
erlang-xmerl-R16B-03.18.el7.x86_64
ethtool-4.8-7.el7.x86_64
expat-2.1.0-10.el7_3.x86_64
expect-5.45-14.el7_1.x86_64
file-5.11-33.el7.x86_64
file-libs-5.11-33.el7.x86_64
filesystem-3.2-25.el7.x86_64
findutils-4.5.11-5.el7.x86_64
fipscheck-1.4.1-6.el7.x86_64
fipscheck-lib-1.4.1-6.el7.x86_64
firehol-3.1.5-1.el7.centos.noarch
firewalld-0.4.4.4-14.el7.noarch
firewalld-filesystem-0.4.4.4-14.el7.noarch
flac-libs-1.3.0-5.el7_1.x86_64
fontconfig-2.10.95-11.el7.x86_64
fontpackages-filesystem-1.44-8.el7.noarch
freeipmi-1.5.7-2.el7.x86_64
freetype-2.4.11-15.el7.x86_64
freeze-2.5.0-16.el7.x86_64
fuse-2.9.2-10.el7.x86_64
fuse-libs-2.9.2-10.el7.x86_64
fxload-2002_04_11-16.el7.x86_64
gawk-4.0.2-4.el7_3.1.x86_64
GConf2-3.2.6-8.el7.x86_64
gd-2.0.35-26.el7.x86_64
gdb-7.6.1-110.el7.x86_64
gdbm-1.10-8.el7.x86_64
gdbm-devel-1.10-8.el7.x86_64
gdisk-0.8.6-5.el7.x86_64
gdk-pixbuf2-2.36.5-1.el7.x86_64
gd-last-2.2.5-2.el7.remi.x86_64
genisoimage-1.1.11-23.el7.x86_64
GeoIP-1.5.0-11.el7.x86_64
geronimo-jms-1.1.1-19.el7.noarch
geronimo-jta-1.1.1-17.el7.noarch
getmail-5.5-1.el7.noarch
gettext-0.19.8.1-2.el7.x86_64
gettext-libs-0.19.8.1-2.el7.x86_64
giflib-4.1.6-9.el7.x86_64
git-1.8.3.1-13.el7.x86_64
glib2-2.54.2-2.el7.x86_64
glibc-2.17-222.el7.i686
glibc-2.17-222.el7.x86_64
glibc-common-2.17-222.el7.x86_64
glibc-debuginfo-2.17-222.el7.x86_64
glibc-debuginfo-common-2.17-222.el7.x86_64
glibc-devel-2.17-222.el7.x86_64
glibc-headers-2.17-222.el7.x86_64
glib-networking-2.50.0-1.el7.x86_64
glpi-0.90.5-2.el7.noarch
glusterfs-3.8.4-53.el7.centos.x86_64
glusterfs-api-3.8.4-53.el7.centos.x86_64
glusterfs-cli-3.8.4-53.el7.centos.x86_64
glusterfs-client-xlators-3.8.4-53.el7.centos.x86_64
glusterfs-libs-3.8.4-53.el7.centos.x86_64
gmp-6.0.0-15.el7.x86_64
gnu-free-fonts-common-20120503-8.el7.noarch
gnu-free-sans-fonts-20120503-8.el7.noarch
gnupg2-2.0.22-4.el7.x86_64
gnustep-base-1.24.9-1.el7.x86_64
gnustep-base-libs-1.24.9-1.el7.x86_64
gnutls-3.3.26-9.el7.x86_64
gnutls-dane-3.3.26-9.el7.x86_64
gnutls-utils-3.3.26-9.el7.x86_64
gobject-introspection-1.50.0-1.el7.x86_64
gperftools-libs-2.6.1-1.el7.x86_64
gpgme-1.3.2-5.el7.x86_64
gpg-pubkey-00f97f56-467e318a
gpg-pubkey-352c64e5-52ae6884
gpg-pubkey-39baf5c1-56bb3d4a
gpg-pubkey-43504a41-587ff3a3
gpg-pubkey-8fae34bd-538f1e51
gpg-pubkey-b6792c39-53c4fbdd
gpg-pubkey-be1229cf-5631588c
gpg-pubkey-f144e5a3-5a70c78d
gpg-pubkey-f2ee9d55-560cfc0a
gpg-pubkey-f4a80eb5-53a7ff4b
gpg-pubkey-f5194398-527516a9
gpm-libs-1.20.7-5.el7.x86_64
graphite2-1.3.10-1.el7_3.x86_64
grep-2.20-3.el7.x86_64
groff-base-1.22.2-8.el7.x86_64
grub2-2.02-0.65.el7.centos.2.x86_64
grub2-common-2.02-0.65.el7.centos.2.noarch
grub2-pc-2.02-0.65.el7.centos.2.x86_64
grub2-pc-modules-2.02-0.65.el7.centos.2.noarch
grub2-tools-2.02-0.65.el7.centos.2.x86_64
grub2-tools-extra-2.02-0.65.el7.centos.2.x86_64
grub2-tools-minimal-2.02-0.65.el7.centos.2.x86_64
grubby-8.28-23.el7.x86_64
gsettings-desktop-schemas-3.24.1-1.el7.x86_64
gsm-1.0.13-11.el7.x86_64
gssproxy-0.7.0-17.el7.x86_64
gtk2-2.24.31-1.el7.x86_64
gtkglext-libs-1.2.0-21.el7.x86_64
gtk-update-icon-cache-3.22.26-4.el7_5.x86_64
gzip-1.5-10.el7.x86_64
hardlink-1.0-19.el7.x86_64
harfbuzz-1.3.2-1.el7.x86_64
hexedit-1.2.13-5.el7.x86_64
hicolor-icon-theme-0.12-7.el7.noarch
hiredis-0.12.1-1.el7.x86_64
hivex-1.3.10-6.9.el7.x86_64
hostname-3.13-3.el7.x86_64
httpd-2.4.6-80.el7.centos.x86_64
httpd-tools-2.4.6-80.el7.centos.x86_64
http-parser-2.7.1-5.el7_4.x86_64
hunspell-1.3.2-15.el7.x86_64
hunspell-en-US-0.20121024-6.el7.noarch
hwdata-0.252-8.8.el7.x86_64
info-5.1-5.el7.x86_64
initscripts-9.49.41-1.el7.x86_64
iproute-4.11.0-14.el7.x86_64
iprutils-2.4.15.1-1.el7.x86_64
ipset-6.29-1.el7.x86_64
ipset-libs-6.29-1.el7.x86_64
iptables-1.4.21-24.1.el7_5.x86_64
iptables-services-1.4.21-24.1.el7_5.x86_64
iputils-20160308-10.el7.x86_64
ipxe-roms-qemu-20170123-1.git4e85b27.el7_4.1.noarch
irqbalance-1.0.7-11.el7.x86_64
iscsi-initiator-utils-6.2.0.874-7.el7.x86_64
iscsi-initiator-utils-iscsiuio-6.2.0.874-7.el7.x86_64
ivtv-firmware-20080701-26.el7.noarch
iwl1000-firmware-39.31.5.1-62.el7.noarch
iwl100-firmware-39.31.5.1-62.el7.noarch
iwl105-firmware-18.168.6.1-62.el7.noarch
iwl135-firmware-18.168.6.1-62.el7.noarch
iwl2000-firmware-18.168.6.1-62.el7.noarch
iwl2030-firmware-18.168.6.1-62.el7.noarch
iwl3160-firmware-22.0.7.0-62.el7.noarch
iwl3945-firmware-15.32.2.9-62.el7.noarch
iwl4965-firmware-228.61.2.24-62.el7.noarch
iwl5000-firmware-8.83.5.1_1-62.el7.noarch
iwl5150-firmware-8.24.2.2-62.el7.noarch
iwl6000-firmware-9.221.4.1-62.el7.noarch
iwl6000g2a-firmware-17.168.5.3-62.el7.noarch
iwl6000g2b-firmware-17.168.5.2-62.el7.noarch
iwl6050-firmware-41.28.5.1-62.el7.noarch
iwl7260-firmware-22.0.7.0-62.el7.noarch
iwl7265-firmware-22.0.7.0-62.el7.noarch
jansson-2.10-1.el7.x86_64
jasper-libs-1.900.1-31.el7.x86_64
java-1.7.0-openjdk-1.7.0.181-2.6.14.8.el7_5.x86_64
java-1.7.0-openjdk-headless-1.7.0.181-2.6.14.8.el7_5.x86_64
javamail-1.4.6-8.el7.noarch
javapackages-tools-3.4.1-11.el7.noarch
jbigkit-libs-2.0-11.el7.x86_64
jemalloc-3.6.0-1.el7.x86_64
json-c-0.11-4.el7_0.x86_64
kbd-1.15.5-13.el7.x86_64
kbd-legacy-1.15.5-13.el7.noarch
kbd-misc-1.15.5-13.el7.noarch
kernel-3.10.0-693.11.1.el7.x86_64
kernel-3.10.0-693.17.1.el7.x86_64
kernel-3.10.0-693.21.1.el7.x86_64
kernel-3.10.0-693.5.2.el7.x86_64
kernel-3.10.0-862.3.2.el7.x86_64
kernel-headers-3.10.0-862.3.2.el7.x86_64
kernel-tools-3.10.0-862.3.2.el7.x86_64
kernel-tools-libs-3.10.0-862.3.2.el7.x86_64
kexec-tools-2.0.15-13.el7.x86_64
keyutils-1.5.8-3.el7.x86_64
keyutils-libs-1.5.8-3.el7.x86_64
kmod-20-21.el7.x86_64
kmod-libs-20-21.el7.x86_64
kpartx-0.4.9-119.el7.x86_64
krb5-debuginfo-1.15.1-19.el7.x86_64
krb5-libs-1.15.1-19.el7.x86_64
krb5-workstation-1.15.1-19.el7.x86_64
lasso-2.5.1-2.el7.x86_64
ldns-1.6.16-10.el7.x86_64
less-458-9.el7.x86_64
lftp-4.4.8-8.el7_3.2.x86_64
libacl-2.2.51-14.el7.x86_64
libaio-0.3.109-13.el7.x86_64
libarchive-3.1.2-10.el7_2.x86_64
libargon2-20161029-2.el7.x86_64
libassuan-2.1.0-3.el7.x86_64
libasyncns-0.8-7.el7.x86_64
libattr-2.4.46-13.el7.i686
libattr-2.4.46-13.el7.x86_64
libbasicobjects-0.1.1-29.el7.x86_64
libblkid-2.23.2-52.el7.x86_64
libcap-2.22-9.el7.i686
libcap-2.22-9.el7.x86_64
libcap-ng-0.7.5-4.el7.i686
libcap-ng-0.7.5-4.el7.x86_64
libc-client-2007f-16.el7.x86_64
libcgroup-0.41-15.el7.x86_64
libcollection-0.7.0-29.el7.x86_64
libcom_err-1.42.9-12.el7_5.x86_64
libconfig-1.4.9-5.el7.x86_64
libcroco-0.6.11-1.el7.x86_64
libcurl-7.29.0-46.el7.x86_64
libdaemon-0.14-7.el7.x86_64
libdb-5.3.21-24.el7.i686
libdb-5.3.21-24.el7.x86_64
libdb-devel-5.3.21-24.el7.x86_64
libdb-utils-5.3.21-24.el7.x86_64
libdhash-0.5.0-29.el7.x86_64
libdrm-2.4.83-2.el7.x86_64
libecap-1.0.0-1.el7.x86_64
libedit-3.0-12.20121213cvs.el7.x86_64
liberation-fonts-common-1.07.2-16.el7.noarch
liberation-mono-fonts-1.07.2-16.el7.noarch
libestr-0.1.9-2.el7.x86_64
libevent-2.0.21-4.el7.x86_64
libfastjson-0.99.4-2.el7.x86_64
libffi-3.0.13-18.el7.x86_64
libfontenc-1.1.3-3.el7.x86_64
libgcc-4.8.5-28.el7_5.1.i686
libgcc-4.8.5-28.el7_5.1.x86_64
libgcrypt-1.5.3-14.el7.i686
libgcrypt-1.5.3-14.el7.x86_64
libgnome-keyring-3.12.0-1.el7.x86_64
libgomp-4.8.5-28.el7_5.1.x86_64
libgpg-error-1.12-3.el7.i686
libgpg-error-1.12-3.el7.x86_64
libgudev1-219-57.el7.x86_64
libguestfs-1.36.10-6.el7_5.2.x86_64
libguestfs-tools-1.36.10-6.el7_5.2.noarch
libguestfs-tools-c-1.36.10-6.el7_5.2.x86_64
libguestfs-winsupport-7.2-2.el7.x86_64
libibverbs-15-7.el7_5.x86_64
libICE-1.0.9-9.el7.x86_64
libicu-50.1.2-15.el7.x86_64
libidn-1.28-4.el7.x86_64
libini_config-1.3.1-29.el7.x86_64
libipa_hbac-1.16.0-19.el7.x86_64
libiscsi-1.9.0-7.el7.x86_64
libjpeg-turbo-1.2.90-5.el7.x86_64
libkadm5-1.15.1-19.el7.x86_64
libldb-1.2.2-1.el7.x86_64
liblzf-3.6-7.el7.x86_64
libmcrypt-2.5.8-13.el7.x86_64
libmemcached-1.0.16-5.el7.x86_64
libmnl-1.0.3-7.el7.x86_64
libmodman-2.0.1-8.el7.x86_64
libmount-2.23.2-52.el7.x86_64
libmspack-0.5-0.5.alpha.el7.x86_64
libndp-1.2-7.el7.x86_64
libnetfilter_conntrack-1.0.6-1.el7_3.x86_64
libnetfilter_queue-1.0.2-2.el7_2.x86_64
libnfnetlink-1.0.1-4.el7.x86_64
libnfsidmap-0.25-19.el7.x86_64
libnl3-3.2.28-4.el7.x86_64
libnl3-cli-3.2.28-4.el7.x86_64
libobjc-4.8.5-28.el7_5.1.x86_64
libogg-1.3.0-7.el7.x86_64
libosinfo-1.0.0-1.el7.x86_64
libpath_utils-0.2.1-29.el7.x86_64
libpcap-1.5.3-11.el7.x86_64
libpciaccess-0.14-1.el7.x86_64
libpipeline-1.2.3-3.el7.x86_64
libpng-1.5.13-7.el7_2.x86_64
libproxy-0.4.11-11.el7.x86_64
libpwquality-1.2.3-5.el7.x86_64
librabbitmq-0.5.2-1.el7.x86_64
librabbitmq-tools-0.5.2-1.el7.x86_64
librados2-0.94.5-2.el7.x86_64
librbd1-0.94.5-2.el7.x86_64
librdmacm-15-7.el7_5.x86_64
libref_array-0.1.5-29.el7.x86_64
libreport-filesystem-2.1.11-40.el7.centos.x86_64
librsync-1.0.0-1.el7.x86_64
libseccomp-2.3.1-3.el7.x86_64
libselinux-2.5-12.el7.i686
libselinux-2.5-12.el7.x86_64
libselinux-python-2.5-12.el7.x86_64
libselinux-utils-2.5-12.el7.x86_64
libsemanage-2.5-11.el7.x86_64
libsemanage-python-2.5-11.el7.x86_64
libsepol-2.5-8.1.el7.i686
libsepol-2.5-8.1.el7.x86_64
libSM-1.2.2-2.el7.x86_64
libsmbclient-4.7.1-6.el7.x86_64
libsndfile-1.0.25-10.el7.x86_64
libsodium-1.0.16-1.el7.x86_64
libsodium13-1.0.5-1.el7.x86_64
libsoup-2.56.0-6.el7.x86_64
libss-1.42.9-12.el7_5.x86_64
libssh2-1.4.3-10.el7_2.1.x86_64
libsss_autofs-1.16.0-19.el7.x86_64
libsss_certmap-1.16.0-19.el7.x86_64
libsss_idmap-1.16.0-19.el7.x86_64
libsss_nss_idmap-1.16.0-19.el7.x86_64
libsss_sudo-1.16.0-19.el7.x86_64
libstdc++-4.8.5-28.el7_5.1.i686
libstdc++-4.8.5-28.el7_5.1.x86_64
libsysfs-2.1.0-16.el7.x86_64
libtalloc-2.1.10-1.el7.x86_64
libtasn1-4.10-1.el7.x86_64
libtdb-1.3.15-1.el7.x86_64
libteam-1.27-4.el7.x86_64
libtevent-0.9.33-2.el7.x86_64
libthai-0.1.14-9.el7.x86_64
libtidy-5.4.0-1.el7.x86_64
libtiff-4.0.3-27.el7_3.x86_64
libtirpc-0.2.4-0.10.el7.x86_64
libtomcrypt-1.17-26.el7.x86_64
libtommath-0.42.0-6.el7.x86_64
libtool-ltdl-2.4.2-22.el7_3.x86_64
libunistring-0.9.3-9.el7.x86_64
libunwind-1.2-2.el7.x86_64
libusal-1.1.11-23.el7.x86_64
libusb-0.1.4-3.el7.x86_64
libusbx-1.0.21-1.el7.x86_64
libuser-0.60-9.el7.x86_64
libutempter-1.1.6-4.el7.x86_64
libuuid-2.23.2-52.el7.x86_64
libuv-1.19.2-1.el7.x86_64
libverto-0.2.5-4.el7.x86_64
libverto-tevent-0.2.5-4.el7.x86_64
libvirt-3.9.0-14.el7_5.5.x86_64
libvirt-client-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-config-network-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-config-nwfilter-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-interface-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-lxc-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-network-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-nodedev-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-nwfilter-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-qemu-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-secret-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-storage-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-storage-core-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-storage-disk-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-storage-gluster-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-storage-iscsi-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-storage-logical-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-storage-mpath-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-storage-rbd-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-driver-storage-scsi-3.9.0-14.el7_5.5.x86_64
libvirt-daemon-kvm-3.9.0-14.el7_5.5.x86_64
libvirt-libs-3.9.0-14.el7_5.5.x86_64
libvirt-python-3.9.0-1.el7.x86_64
libvorbis-1.3.3-8.el7.1.x86_64
libvpx-1.3.0-5.el7_0.x86_64
libwayland-client-1.14.0-2.el7.x86_64
libwayland-server-1.14.0-2.el7.x86_64
libwbclient-4.7.1-6.el7.x86_64
libwbxml-0.11.2-4.el7.centos.x86_64
libwebp-0.3.0-7.el7.x86_64
libX11-1.6.5-1.el7.x86_64
libX11-common-1.6.5-1.el7.noarch
libXau-1.0.8-2.1.el7.x86_64
libxcb-1.12-1.el7.x86_64
libXcomposite-0.4.4-4.1.el7.x86_64
libXcursor-1.1.14-8.el7.x86_64
libXdamage-1.1.4-4.1.el7.x86_64
libXdmcp-1.1.2-6.el7.x86_64
libXext-1.3.3-3.el7.x86_64
libXfixes-5.0.3-1.el7.x86_64
libXfont-1.5.2-1.el7.x86_64
libXfont2-2.0.1-2.el7.x86_64
libXft-2.3.2-2.el7.x86_64
libXi-1.7.9-1.el7.x86_64
libXinerama-1.1.3-2.1.el7.x86_64
libxkbfile-1.0.9-3.el7.x86_64
libxml2-2.9.1-6.el7_2.3.x86_64
libxml2-python-2.9.1-6.el7_2.3.x86_64
libXmu-1.1.2-2.el7.x86_64
libXpm-3.5.12-1.el7.x86_64
libXrandr-1.5.1-2.el7.x86_64
libXrender-0.9.10-1.el7.x86_64
libXScrnSaver-1.2.2-6.1.el7.x86_64
libxshmfence-1.2-1.el7.x86_64
libxslt-1.1.28-5.el7.x86_64
libXt-1.1.5-3.el7.x86_64
libXtst-1.2.3-1.el7.x86_64
libXxf86vm-1.1.4-1.el7.x86_64
libyaml-0.1.4-11.el7_0.x86_64
libzip-0.10.1-8.el7.x86_64
libzip5-1.5.1-1.el7.remi.x86_64
lightsquid-1.8-18.el7.lux.noarch
lightsquid-apache-1.8-18.el7.lux.noarch
linux-firmware-20180220-62.git6d51311.el7.noarch
lksctp-tools-1.0.17-2.el7.x86_64
log4j-1.2.17-16.el7_4.noarch
logrotate-3.8.6-15.el7.x86_64
lrzip-0.616-5.el7.x86_64
lsm-1.0.5-1.el7.lux.x86_64
lsof-4.87-5.el7.x86_64
lsscsi-0.27-6.el7.x86_64
lua-5.1.4-15.el7.x86_64
lvm2-2.02.177-4.el7.x86_64
lvm2-libs-2.02.177-4.el7.x86_64
lz4-1.7.5-2.el7.i686
lz4-1.7.5-2.el7.x86_64
lzo-2.06-8.el7.x86_64
lzop-1.03-10.el7.x86_64
mailcap-2.1.41-2.el7.noarch
mailx-12.5-19.el7.x86_64
make-3.82-23.el7.x86_64
man-db-2.6.3-9.el7.x86_64
mariadb-5.5.56-2.el7.x86_64
mariadb-libs-5.5.56-2.el7.x86_64
mariadb-server-5.5.56-2.el7.x86_64
mc-4.8.7-11.el7.x86_64
mdadm-4.0-13.el7.x86_64
memcached-1.4.15-10.el7_3.1.x86_64
mesa-libEGL-17.2.3-8.20171019.el7.x86_64
mesa-libgbm-17.2.3-8.20171019.el7.x86_64
mesa-libGL-17.2.3-8.20171019.el7.x86_64
mesa-libglapi-17.2.3-8.20171019.el7.x86_64
mesa-libGLU-9.0.0-4.el7.x86_64
microcode_ctl-2.1-29.2.el7_5.x86_64
mod_perl-2.0.10-2.el7.x86_64
mod_ssl-2.4.6-80.el7.centos.x86_64
mozjs17-17.0.0-20.el7.x86_64
msodbcsql-13.1.9.2-1.x86_64
msodbcsql17-17.1.0.1-1.x86_64
mssql-server-14.0.3026.27-2.x86_64
mssql-tools-17.1.0.1-1.x86_64
msttcore-fonts-installer-2.6-1.noarch
mtools-4.0.18-5.el7.x86_64
nano-2.3.1-10.el7.x86_64
ncftp-3.2.5-7.el7.x86_64
ncurses-5.9-14.20130511.el7_4.x86_64
ncurses-base-5.9-14.20130511.el7_4.noarch
ncurses-libs-5.9-14.20130511.el7_4.x86_64
neon-0.30.0-3.el7.x86_64
netcf-libs-0.2.8-4.el7.x86_64
nethserver-antivirus-1.2.1-1.ns7.noarch
nethserver-automysqlbackup-3.0.RC6-9.ns7.sdl.noarch
nethserver-backup-config-2.1.0-1.ns7.noarch
nethserver-backup-data-1.3.4-1.ns7.noarch
nethserver-base-3.3.0-1.ns7.noarch
nethserver-c-icap-1.1.0-1.ns7.noarch
nethserver-crontabmanager-0.1.1-1.ns7.sdl.noarch
nethserver-dc-1.5.1-1.ns7.x86_64
nethserver-delegation-0.1.8-1.ns7.sdl.noarch
nethserver-diagtools-1.0.2-1.ns7.noarch
nethserver-dnsmasq-1.6.6-1.ns7.noarch
nethserver-duc-1.4.3-1.ns7.noarch
nethserver-ejabberd-1.1.5-1.ns7.noarch
nethserver-firewall-base-3.4.0-1.ns7.noarch
nethserver-firewall-base-ui-3.4.0-1.ns7.noarch
nethserver-getmail-1.0.3-1.ns7.noarch
nethserver-glpi-0.1.4-1.ns7.sdl.noarch
nethserver-hosts-1.2.2-1.ns7.noarch
nethserver-httpd-3.2.3-1.ns7.noarch
nethserver-httpd-admin-2.3.1-1.ns7.noarch
nethserver-httpd-virtualhosts-3.2.3-1.ns7.noarch
nethserver-lang-en-1.2.11-1.ns7.noarch
nethserver-lang-es-1.2.11-1.ns7.noarch
nethserver-letsencrypt-1.1.6-1.ns7.noarch
nethserver-lib-2.2.7-1.ns7.noarch
nethserver-libvirt-1.1.0-1.ns7.noarch
nethserver-lightsquid-1.1.2-1.ns7.noarch
nethserver-lsm-1.2.3-1.ns7.noarch
nethserver-mail-common-1.6.7-1.ns7.noarch
nethserver-mail-disclaimer-1.6.7-1.ns7.noarch
nethserver-mail-filter-1.4.4-1.ns7.noarch
nethserver-mail-server-1.12.1-1.ns7.noarch
nethserver-mail-smarthost-1.0.1-1.ns7.noarch
nethserver-memcached-1.1.0-1.ns7.noarch
nethserver-mrmarkuz-0.0.1-1.ns7.noarch
nethserver-mysql-1.1.3-1.ns7.noarch
nethserver-nethforge-release-7-2.ns7.noarch
nethserver-nextcloud-1.2.1-1.ns7.noarch
nethserver-nginx-0.0.1-1.ns7.noarch
nethserver-ntopng-2.1.1-1.ns7.noarch
nethserver-ntp-1.1.3-1.ns7.noarch
nethserver-ocsinventory-1.1.6-1.ns7.sdl.noarch
nethserver-onlyoffice-0.0.1-3.ns7.noarch
nethserver-openssh-1.2.2-1.ns7.noarch
nethserver-openvpn-1.6.10-1.ns7.noarch
nethserver-phonehome-1.3.0-1.ns7.noarch
nethserver-php-1.2.0-1.ns7.noarch
nethserver-phpmyadmin-1.2.2-1.ns7.sdl.noarch
nethserver-php-scl-1.2.3-1.ns7.sdl.x86_64
nethserver-phpsettings-1.1.2-1.ns7.sdl.noarch
nethserver-postgresql-1.1.0-1.ns7.noarch
nethserver-redis-1.1.0-1.ns7.noarch
nethserver-release-7-7.ns7.noarch
nethserver-restore-data-1.2.4-1.ns7.noarch
nethserver-rh-php71-php-fpm-1.0.0-1.ns7.noarch
nethserver-samba-4.1.0-1.ns7.noarch
nethserver-samba-audit-1.1.3-1.ns7.noarch
nethserver-smartd-1.1.0-1.ns7.noarch
nethserver-spamd-1.0.1-1.ns7.noarch
nethserver-squid-1.7.0-1.ns7.noarch
nethserver-squidclamav-3.0.0-1.ns7.noarch
nethserver-squidguard-1.8.0-1.ns7.noarch
nethserver-sssd-1.3.8-1.ns7.noarch
nethserver-stephdl-1.0.6-1.ns7.sdl.noarch
nethserver-unbound-1.1.0-1.ns7.noarch
nethserver-vsftpd-1.1.0-1.ns7.noarch
nethserver-webtop5-1.2.3-1.ns7.noarch
nethserver-webvirtmgr-1.1.1-1.ns7.noarch
nethserver-yum-1.4.1-1.ns7.noarch
net-snmp-libs-5.7.2-33.el7_5.2.x86_64
nettle-2.7.1-8.el7.x86_64
net-tools-2.0-0.22.20131004git.el7.x86_64
NetworkManager-1.10.2-14.el7_5.x86_64
NetworkManager-libnm-1.10.2-14.el7_5.x86_64
NetworkManager-ppp-1.10.2-14.el7_5.x86_64
NetworkManager-team-1.10.2-14.el7_5.x86_64
NetworkManager-tui-1.10.2-14.el7_5.x86_64
NetworkManager-wifi-1.10.2-14.el7_5.x86_64
newt-0.52.15-4.el7.x86_64
newt-python-0.52.15-4.el7.x86_64
nextcloud-13.0.2-1.el7.noarch
nfs-utils-1.3.0-0.54.el7.x86_64
nginx-1.12.2-2.el7.x86_64
nginx-all-modules-1.12.2-2.el7.noarch
nginx-filesystem-1.12.2-2.el7.noarch
nginx-mod-http-geoip-1.12.2-2.el7.x86_64
nginx-mod-http-image-filter-1.12.2-2.el7.x86_64
nginx-mod-http-perl-1.12.2-2.el7.x86_64
nginx-mod-http-xslt-filter-1.12.2-2.el7.x86_64
nginx-mod-mail-1.12.2-2.el7.x86_64
nginx-mod-stream-1.12.2-2.el7.x86_64
nmap-6.40-13.el7.x86_64
nmap-ncat-6.40-13.el7.x86_64
nodejs-6.14.2-1.el7.x86_64
nomarch-1.4-11.el7.x86_64
npm-3.10.10-1.6.14.2.1.el7.x86_64
nspr-4.19.0-1.el7_5.x86_64
nss-3.36.0-5.el7_5.x86_64
nss-pem-1.0.3-4.el7.x86_64
nss-softokn-3.36.0-5.el7_5.x86_64
nss-softokn-debuginfo-3.36.0-5.el7_5.x86_64
nss-softokn-freebl-3.36.0-5.el7_5.i686
nss-softokn-freebl-3.36.0-5.el7_5.x86_64
nss-sysinit-3.36.0-5.el7_5.x86_64
nss-tools-3.36.0-5.el7_5.x86_64
nss-util-3.36.0-1.el7_5.x86_64
ntopng-3.3.180109-3804.x86_64
ntopng-data-3.3.180109-3804.noarch
numactl-2.0.9-7.el7.x86_64
numactl-libs-2.0.9-7.el7.x86_64
numad-0.5-18.20150602git.el7.x86_64
nut-2.7.2-4.el7.x86_64
nut-client-2.7.2-4.el7.x86_64
ocsinventory-2.4.1-1.el7.ocs.noarch
ocsinventory-release-7-4.el7.ocs.noarch
ocsinventory-reports-2.4.1-1.el7.ocs.noarch
ocsinventory-server-2.4.1-1.el7.ocs.noarch
oddjob-0.31.5-4.el7.x86_64
oddjob-mkhomedir-0.31.5-4.el7.x86_64
onlyoffice-documentserver-5.1.1-23.x86_64
openldap-2.4.44-15.el7_5.x86_64
openldap-clients-2.4.44-15.el7_5.x86_64
openpgm-5.2.122-2.el7.x86_64
openssh-7.4p1-16.el7.x86_64
openssh-clients-7.4p1-16.el7.x86_64
openssh-server-7.4p1-16.el7.x86_64
openssl-1.0.2k-12.el7.x86_64
openssl-debuginfo-1.0.2k-12.el7.x86_64
openssl-libs-1.0.2k-12.el7.x86_64
openvpn-2.4.6-1.el7.x86_64
opus-1.0.2-6.el7.x86_64
osinfo-db-20170813-6.el7.noarch
osinfo-db-tools-1.1.0-1.el7.x86_64
os-prober-1.58-9.el7.x86_64
p11-kit-0.23.5-3.el7.x86_64
p11-kit-trust-0.23.5-3.el7.x86_64
p7zip-16.02-10.el7.x86_64
p7zip-plugins-16.02-10.el7.x86_64
pakchois-0.4-10.el7.x86_64
pam-1.1.8-22.el7.i686
pam-1.1.8-22.el7.x86_64
pango-1.40.4-1.el7.x86_64
pangox-compat-0.0.2-2.el7.x86_64
parted-3.1-29.el7.x86_64
passwd-0.79-4.el7.x86_64
patch-2.7.1-10.el7_5.x86_64
pax-3.4-19.el7.x86_64
pciutils-3.5.1-3.el7.x86_64
pciutils-libs-3.5.1-3.el7.x86_64
pcre-8.32-17.el7.i686
pcre-8.32-17.el7.x86_64
pcsc-lite-libs-1.8.8-7.el7.x86_64
perl-5.16.3-292.el7.x86_64
perl-Apache2-SOAP-0.73-14.el7.ocs.noarch
perl-Apache-DBI-1.12-2.el7.ocs.noarch
perl-Apache-LogFormat-Compiler-0.23-1.el7.noarch
perl-Archive-Tar-1.92-2.el7.noarch
perl-Archive-Zip-1.30-11.el7.noarch
perl-Authen-Krb5-1.9-1.ns7.x86_64
perl-Authen-PAM-0.16-16.el7.x86_64
perl-Authen-SASL-2.15-10.el7.noarch
perl-autodie-2.16-2.el7.noarch
perl-BerkeleyDB-0.51-4.el7.x86_64
perl-BSD-Resource-1.29.07-1.el7.x86_64
perl-Business-ISBN-2.06-2.el7.noarch
perl-Business-ISBN-Data-20120719.001-2.el7.noarch
perl-Carp-1.26-244.el7.noarch
perl-CGI-3.63-4.el7.noarch
perl-CGI-Compile-0.15-6.el7.noarch
perl-CGI-Emulate-PSGI-0.15-4.el7.noarch
perl-Class-Inspector-1.28-2.el7.noarch
perl-Compress-Raw-Bzip2-2.061-3.el7.x86_64
perl-Compress-Raw-Zlib-2.061-4.el7.x86_64
perl-constant-1.27-2.el7.noarch
perl-Convert-ASN1-0.26-4.el7.noarch
perl-Convert-BinHex-1.119-20.el7.noarch
perl-Convert-TNEF-0.18-2.el7.noarch
perl-Convert-UUlib-1.5-1.el7.x86_64
perl-Crypt-OpenSSL-Bignum-0.04-18.el7.x86_64
perl-Crypt-OpenSSL-Random-0.04-21.el7.x86_64
perl-Crypt-OpenSSL-RSA-0.28-7.el7.x86_64
perl-Data-Dumper-2.145-3.el7.x86_64
perl-DBD-MySQL-4.023-6.el7.x86_64
perl-DBD-Pg-2.19.3-4.el7.x86_64
perl-DBD-SQLite-1.39-3.el7.x86_64
perl-DB_File-1.830-6.el7.x86_64
perl-DBI-1.627-4.el7.x86_64
perl-devel-5.16.3-292.el7.x86_64
perl-Devel-StackTrace-1.30-2.el7.noarch
perl-Devel-StackTrace-AsHTML-0.15-1.el7.noarch
perl-Digest-1.17-245.el7.noarch
perl-Digest-HMAC-1.03-5.el7.noarch
perl-Digest-MD5-2.52-3.el7.x86_64
perl-Digest-SHA1-2.13-9.el7.x86_64
perl-Digest-SHA-5.85-4.el7.x86_64
perl-Email-Date-Format-1.002-15.el7.noarch
perl-Email-Valid-1.198-1.el7.noarch
perl-Encode-2.51-7.el7.x86_64
perl-Encode-Detect-1.01-13.el7.x86_64
perl-Encode-Locale-1.03-5.el7.noarch
perl-Env-1.04-2.el7.noarch
perl-Error-0.17020-2.el7.noarch
perl-Expect-1.21-14.el7.noarch
perl-Exporter-5.68-3.el7.noarch
perl-ExtUtils-Install-1.58-292.el7.noarch
perl-ExtUtils-MakeMaker-6.68-3.el7.noarch
perl-ExtUtils-Manifest-1.61-244.el7.noarch
perl-ExtUtils-ParseXS-3.18-3.el7.noarch
perl-FCGI-0.74-8.el7.x86_64
perl-File-Listing-6.04-7.el7.noarch
perl-File-Path-2.09-2.el7.noarch
perl-File-pushd-1.005-2.el7.noarch
perl-File-Temp-0.23.01-3.el7.noarch
perl-Filter-1.49-3.el7.x86_64
perl-Font-AFM-1.20-13.el7.noarch
perl-GD-2.49-3.el7.x86_64
perl-GDGraph-1.44-15.el7.noarch
perl-GDGraph3d-0.63-23.el7.noarch
perl-GDTextUtil-0.86-23.el7.noarch
perl-Getopt-Long-2.40-3.el7.noarch
perl-gettext-1.05-28.el7.x86_64
perl-Git-1.8.3.1-13.el7.noarch
perl-GSSAPI-0.28-9.el7.x86_64
perl-Hash-MultiValue-0.15-2.el7.noarch
perl-hivex-1.3.10-6.9.el7.x86_64
perl-HTML-Format-2.10-7.el7.noarch
perl-HTML-Parser-3.71-4.el7.x86_64
perl-HTML-Tagset-3.20-15.el7.noarch
perl-HTML-Tree-5.03-2.el7.noarch
perl-HTTP-Body-1.07-10.el7.noarch
perl-HTTP-Cookies-6.01-5.el7.noarch
perl-HTTP-Daemon-6.01-7.el7.noarch
perl-HTTP-Date-6.02-8.el7.noarch
perl-HTTP-Message-6.06-6.el7.noarch
perl-HTTP-Negotiate-6.01-5.el7.noarch
perl-HTTP-Tiny-0.033-3.el7.noarch
perl-IO-Compress-2.061-2.el7.noarch
perl-IO-HTML-1.00-2.el7.noarch
perl-IO-Multiplex-1.13-6.el7.noarch
perl-IO-SessionData-1.03-1.el7.noarch
perl-IO-Socket-INET6-2.69-5.el7.noarch
perl-IO-Socket-IP-0.21-5.el7.noarch
perl-IO-Socket-SSL-1.94-7.el7.noarch
perl-IO-stringy-2.110-22.el7.noarch
perl-IO-Tty-1.10-11.el7.x86_64
perl-IO-Zlib-1.10-292.el7.noarch
perl-JSON-2.59-2.el7.noarch
perl-JSON-PP-2.27202-2.el7.noarch
perl-LDAP-0.56-5.el7.noarch
perl-libintl-1.20-12.el7.x86_64
perl-libs-5.16.3-292.el7.x86_64
perl-libwww-perl-6.05-2.el7.noarch
perl-Linux-Pid-0.04-18.el7.x86_64
perl-LWP-MediaTypes-6.02-2.el7.noarch
perl-macros-5.16.3-292.el7.x86_64
perl-Mail-DKIM-0.39-8.el7.noarch
perl-Mail-RFC822-Address-0.3-1.ns7.noarch
perl-Mail-SPF-2.8.0-4.el7.noarch
perl-MailTools-2.12-2.el7.noarch
perl-MIME-Lite-3.030-1.el7.noarch
perl-MIME-tools-5.505-1.el7.noarch
perl-MIME-Types-1.38-2.el7.noarch
perl-Module-Refresh-0.17-6.el7.noarch
perl-Mojolicious-7.67-1.el7.noarch
perl-Mozilla-CA-20130114-5.el7.noarch
perl-NetAddr-IP-4.069-3.el7.x86_64
perl-Net-Daemon-0.48-5.el7.noarch
perl-Net-DBus-1.1.0-4.ns7.x86_64
perl-Net-DNS-0.72-6.el7.x86_64
perl-Net-HTTP-6.06-2.el7.noarch
perl-Net-IP-1.26-4.el7.noarch
perl-Net-IPv4Addr-0.10-19.el7.noarch
perl-Net-LibIDN-0.12-15.el7.x86_64
perl-Net-Server-2.007-2.el7.noarch
perl-Net-SMTP-SSL-1.01-13.el7.noarch
perl-Net-SSLeay-1.55-6.el7.x86_64
perl-Package-Constants-0.02-292.el7.noarch
perl-parent-0.225-244.el7.noarch
perl-PathTools-3.40-5.el7.x86_64
perl-Plack-1.0033-1.el7.noarch
perl-PlRPC-0.2020-14.el7.noarch
perl-Pod-Escapes-1.04-292.el7.noarch
perl-podlators-2.5.1-3.el7.noarch
perl-Pod-Perldoc-3.20-4.el7.noarch
perl-Pod-Simple-3.28-4.el7.noarch
perl-Pod-Usage-1.63-3.el7.noarch
perl-Razor-Agent-2.85-15.el7.x86_64
perl-Scalar-List-Utils-1.27-248.el7.x86_64
perl-SOAP-Lite-1.10-1.el7.noarch
perl-Socket-2.010-4.el7.x86_64
perl-Socket6-0.23-15.el7.x86_64
perl-Storable-2.45-3.el7.x86_64
perl-Stream-Buffered-0.02-1.el7.noarch
perl-Switch-2.16-7.el7.noarch
perl-Sys-Guestfs-1.36.10-6.el7_5.2.x86_64
perl-Sys-Hostname-Long-1.5-1.el7.noarch
perl-Sys-Syslog-0.33-3.el7.x86_64
perl-Sys-Virt-3.9.0-2.el7.x86_64
perl-TermReadKey-2.30-20.el7.x86_64
perl-Test-Harness-3.28-3.el7.noarch
perl-Text-ParseWords-3.29-4.el7.noarch
perl-Text-Soundex-3.04-4.el7.x86_64
perl-Text-Template-1.45-12.el7.noarch
perl-Text-Unidecode-0.04-20.el7.noarch
perl-threads-1.87-4.el7.x86_64
perl-threads-shared-1.43-6.el7.x86_64
perl-TimeDate-2.30-2.el7.noarch
perl-Time-HiRes-1.9725-3.el7.x86_64
perl-Time-Local-1.2300-2.el7.noarch
perl-Try-Tiny-0.12-2.el7.noarch
perl-Unix-Syslog-1.1-17.el7.x86_64
perl-URI-1.60-9.el7.noarch
perl-version-0.99.07-3.el7.x86_64
perl-WWW-RobotRules-6.02-5.el7.noarch
perl-XML-Entities-1.0002-2.el7.noarch
perl-XML-Filter-BufferText-1.01-17.el7.noarch
perl-XML-NamespaceSupport-1.11-10.el7.noarch
perl-XML-Parser-2.41-10.el7.x86_64
perl-XML-SAX-0.99-9.el7.noarch
perl-XML-SAX-Base-1.08-7.el7.noarch
perl-XML-SAX-Writer-0.53-4.el7.noarch
perl-XML-Simple-2.20-5.el7.noarch
perl-XML-Twig-3.44-2.el7.noarch
pexpect-2.3-11.el7.noarch
pfring-7.1.0-1681.x86_64
php-5.4.16-45.el7.x86_64
php56-2.3-1.el7.remi.x86_64
php56-php-5.6.36-1.el7.remi.x86_64
php56-php-bcmath-5.6.36-1.el7.remi.x86_64
php56-php-cli-5.6.36-1.el7.remi.x86_64
php56-php-common-5.6.36-1.el7.remi.x86_64
php56-php-dba-5.6.36-1.el7.remi.x86_64
php56-php-enchant-5.6.36-1.el7.remi.x86_64
php56-php-fpm-5.6.36-1.el7.remi.x86_64
php56-php-gd-5.6.36-1.el7.remi.x86_64
php56-php-imap-5.6.36-1.el7.remi.x86_64
php56-php-ldap-5.6.36-1.el7.remi.x86_64
php56-php-mbstring-5.6.36-1.el7.remi.x86_64
php56-php-mcrypt-5.6.36-1.el7.remi.x86_64
php56-php-mysqlnd-5.6.36-1.el7.remi.x86_64
php56-php-pdo-5.6.36-1.el7.remi.x86_64
php56-php-pear-1.10.5-5.el7.remi.noarch
php56-php-pecl-jsonc-1.3.10-1.el7.remi.x86_64
php56-php-pecl-zip-1.15.2-1.el7.remi.x86_64
php56-php-pgsql-5.6.36-1.el7.remi.x86_64
php56-php-process-5.6.36-1.el7.remi.x86_64
php56-php-soap-5.6.36-1.el7.remi.x86_64
php56-php-tidy-5.6.36-1.el7.remi.x86_64
php56-php-xml-5.6.36-1.el7.remi.x86_64
php56-runtime-2.3-1.el7.remi.x86_64
php70-1.0-5.el7.remi.x86_64
php70-php-7.0.30-1.el7.remi.x86_64
php70-php-bcmath-7.0.30-1.el7.remi.x86_64
php70-php-cli-7.0.30-1.el7.remi.x86_64
php70-php-common-7.0.30-1.el7.remi.x86_64
php70-php-dba-7.0.30-1.el7.remi.x86_64
php70-php-enchant-7.0.30-1.el7.remi.x86_64
php70-php-fpm-7.0.30-1.el7.remi.x86_64
php70-php-gd-7.0.30-1.el7.remi.x86_64
php70-php-imap-7.0.30-1.el7.remi.x86_64
php70-php-json-7.0.30-1.el7.remi.x86_64
php70-php-ldap-7.0.30-1.el7.remi.x86_64
php70-php-mbstring-7.0.30-1.el7.remi.x86_64
php70-php-mcrypt-7.0.30-1.el7.remi.x86_64
php70-php-mysqlnd-7.0.30-1.el7.remi.x86_64
php70-php-pdo-7.0.30-1.el7.remi.x86_64
php70-php-pear-1.10.5-5.el7.remi.noarch
php70-php-pecl-zip-1.15.2-1.el7.remi.x86_64
php70-php-pgsql-7.0.30-1.el7.remi.x86_64
php70-php-process-7.0.30-1.el7.remi.x86_64
php70-php-soap-7.0.30-1.el7.remi.x86_64
php70-php-tidy-7.0.30-1.el7.remi.x86_64
php70-php-xml-7.0.30-1.el7.remi.x86_64
php70-runtime-1.0-5.el7.remi.x86_64
php71-1.0-1.el7.remi.x86_64
php71-php-7.1.18-1.el7.remi.x86_64
php71-php-bcmath-7.1.18-1.el7.remi.x86_64
php71-php-cli-7.1.18-1.el7.remi.x86_64
php71-php-common-7.1.18-1.el7.remi.x86_64
php71-php-dba-7.1.18-1.el7.remi.x86_64
php71-php-enchant-7.1.18-1.el7.remi.x86_64
php71-php-fpm-7.1.18-1.el7.remi.x86_64
php71-php-gd-7.1.18-1.el7.remi.x86_64
php71-php-imap-7.1.18-1.el7.remi.x86_64
php71-php-json-7.1.18-1.el7.remi.x86_64
php71-php-ldap-7.1.18-1.el7.remi.x86_64
php71-php-mbstring-7.1.18-1.el7.remi.x86_64
php71-php-mcrypt-7.1.18-1.el7.remi.x86_64
php71-php-mysqlnd-7.1.18-1.el7.remi.x86_64
php71-php-pdo-7.1.18-1.el7.remi.x86_64
php71-php-pear-1.10.5-5.el7.remi.noarch
php71-php-pecl-zip-1.15.2-1.el7.remi.x86_64
php71-php-pgsql-7.1.18-1.el7.remi.x86_64
php71-php-process-7.1.18-1.el7.remi.x86_64
php71-php-soap-7.1.18-1.el7.remi.x86_64
php71-php-tidy-7.1.18-1.el7.remi.x86_64
php71-php-xml-7.1.18-1.el7.remi.x86_64
php71-runtime-1.0-1.el7.remi.x86_64
php72-1.0-1.el7.remi.x86_64
php72-php-bcmath-7.2.6-1.el7.remi.x86_64
php72-php-cli-7.2.6-1.el7.remi.x86_64
php72-php-common-7.2.6-1.el7.remi.x86_64
php72-php-enchant-7.2.6-1.el7.remi.x86_64
php72-php-fpm-7.2.6-1.el7.remi.x86_64
php72-php-gd-7.2.6-1.el7.remi.x86_64
php72-php-imap-7.2.6-1.el7.remi.x86_64
php72-php-json-7.2.6-1.el7.remi.x86_64
php72-php-ldap-7.2.6-1.el7.remi.x86_64
php72-php-mbstring-7.2.6-1.el7.remi.x86_64
php72-php-mysqlnd-7.2.6-1.el7.remi.x86_64
php72-php-pdo-7.2.6-1.el7.remi.x86_64
php72-php-pear-1.10.5-6.el7.remi.noarch
php72-php-pecl-mcrypt-1.0.1-4.el7.remi.x86_64
php72-php-pecl-zip-1.15.2-1.el7.remi.x86_64
php72-php-pgsql-7.2.6-1.el7.remi.x86_64
php72-php-process-7.2.6-1.el7.remi.x86_64
php72-php-soap-7.2.6-1.el7.remi.x86_64
php72-php-tidy-7.2.6-1.el7.remi.x86_64
php72-php-xml-7.2.6-1.el7.remi.x86_64
php72-runtime-1.0-1.el7.remi.x86_64
php-bcmath-5.4.16-45.el7.x86_64
php-cli-5.4.16-45.el7.x86_64
php-common-5.4.16-45.el7.x86_64
php-composer-ca-bundle-1.0.2-1.el7.noarch
php-composer-semver-1.4.2-1.el7.noarch
php-composer-spdx-licenses-1.4.0-1.el7.noarch
php-doctrine-annotations-1.2.7-4.el7.noarch
php-doctrine-cache-1.5.4-1.el7.noarch
php-doctrine-collections-1.3.0-2.el7.noarch
php-doctrine-common-2.5.3-3.el7.noarch
php-doctrine-inflector-1.1.0-4.el7.noarch
php-doctrine-lexer-1.0.1-8.el7.noarch
php-fedora-autoloader-1.0.0-1.el7.noarch
php-gd-5.4.16-45.el7.x86_64
php-htmLawed-1.1.21-1.el7.noarch
php-IDNA_Convert-0.8.0-2.el7.noarch
php-imap-5.4.16-7.el7.x86_64
php-intl-5.4.16-45.el7.x86_64
php-ircmaxell-random-lib-1.2.0-1.el7.noarch
php-ircmaxell-security-lib-1.1.0-4.el7.noarch
php-jsonlint-1.6.1-1.el7.noarch
php-justinrainbow-json-schema5-5.2.7-1.el7.noarch
php-ldap-5.4.16-45.el7.x86_64
php-mbstring-5.4.16-45.el7.x86_64
php-mcrypt-5.4.16-7.el7.x86_64
phpMyAdmin-4.4.15.10-2.el7.noarch
php-mysql-5.4.16-45.el7.x86_64
php-paragonie-random-compat-2.0.12-1.el7.noarch
php-password-compat-1.0.4-1.el7.noarch
php-pdo-5.4.16-45.el7.x86_64
php-pear-1.9.4-21.el7.noarch
php-pear-CAS-1.3.5-1.el7.noarch
php-pecl-igbinary-1.2.1-1.el7.x86_64
php-pecl-lzf-1.6.2-4.el7.x86_64
php-pgsql-5.4.16-45.el7.x86_64
php-php-gettext-1.0.12-1.el7.noarch
php-PHPMailer-5.2.26-1.el7.noarch
php-process-5.4.16-45.el7.x86_64
php-PsrLog-1.0.2-2.el7.noarch
php-seld-cli-prompt-1.0.3-1.el7.noarch
php-seld-phar-utils-1.0.1-1.el7.noarch
php-simplepie-1.3.1-4.el7.noarch
php-soap-5.4.16-45.el7.x86_64
php-symfony-browser-kit-2.8.12-2.el7.noarch
php-symfony-class-loader-2.8.12-2.el7.noarch
php-symfony-common-2.8.12-2.el7.noarch
php-symfony-config-2.8.12-2.el7.noarch
php-symfony-console-2.8.12-2.el7.noarch
php-symfony-css-selector-2.8.12-2.el7.noarch
php-symfony-debug-2.8.12-2.el7.noarch
php-symfony-dependency-injection-2.8.12-2.el7.noarch
php-symfony-dom-crawler-2.8.12-2.el7.noarch
php-symfony-event-dispatcher-2.8.12-2.el7.noarch
php-symfony-expression-language-2.8.12-2.el7.noarch
php-symfony-filesystem-2.8.12-2.el7.noarch
php-symfony-finder-2.8.12-2.el7.noarch
php-symfony-http-foundation-2.8.12-2.el7.noarch
php-symfony-http-kernel-2.8.12-2.el7.noarch
php-symfony-polyfill-1.5.0-1.el7.noarch
php-symfony-process-2.8.12-2.el7.noarch
php-symfony-var-dumper-2.8.12-2.el7.noarch
php-symfony-yaml-2.8.12-2.el7.noarch
php-tcpdf-6.2.13-1.el7.noarch
php-tcpdf-dejavu-sans-fonts-6.2.13-1.el7.noarch
php-tidy-5.4.16-7.el7.x86_64
php-xml-5.4.16-45.el7.x86_64
php-ZendFramework2-Authentication-2.4.11-1.el7.noarch
php-ZendFramework2-Cache-2.4.11-1.el7.noarch
php-ZendFramework2-Captcha-2.4.11-1.el7.noarch
php-ZendFramework2-Code-2.4.11-1.el7.noarch
php-ZendFramework2-common-2.4.11-1.el7.noarch
php-ZendFramework2-Config-2.4.11-1.el7.noarch
php-ZendFramework2-Console-2.4.11-1.el7.noarch
php-ZendFramework2-Crypt-2.4.11-1.el7.noarch
php-ZendFramework2-Db-2.4.11-1.el7.noarch
php-ZendFramework2-Di-2.4.11-1.el7.noarch
php-ZendFramework2-Escaper-2.4.11-1.el7.noarch
php-ZendFramework2-EventManager-2.4.11-1.el7.noarch
php-ZendFramework2-Feed-2.4.11-1.el7.noarch
php-ZendFramework2-Filter-2.4.11-1.el7.noarch
php-ZendFramework2-Form-2.4.11-1.el7.noarch
php-ZendFramework2-Http-2.4.11-1.el7.noarch
php-ZendFramework2-I18n-2.4.11-1.el7.noarch
php-ZendFramework2-InputFilter-2.4.11-1.el7.noarch
php-ZendFramework2-Json-2.4.11-1.el7.noarch
php-ZendFramework2-Ldap-2.4.11-1.el7.noarch
php-ZendFramework2-Loader-2.4.11-1.el7.noarch
php-ZendFramework2-Log-2.4.11-1.el7.noarch
php-ZendFramework2-Mail-2.4.11-1.el7.noarch
php-ZendFramework2-Math-2.4.11-1.el7.noarch
php-ZendFramework2-Mime-2.4.11-1.el7.noarch
php-ZendFramework2-ModuleManager-2.4.11-1.el7.noarch
php-ZendFramework2-Mvc-2.4.11-1.el7.noarch
php-ZendFramework2-Navigation-2.4.11-1.el7.noarch
php-ZendFramework2-Paginator-2.4.11-1.el7.noarch
php-ZendFramework2-Permissions-Acl-2.4.11-1.el7.noarch
php-ZendFramework2-Serializer-2.4.11-1.el7.noarch
php-ZendFramework2-Server-2.4.11-1.el7.noarch
php-ZendFramework2-ServiceManager-2.4.11-1.el7.noarch
php-ZendFramework2-Session-2.4.11-1.el7.noarch
php-ZendFramework2-Stdlib-2.4.11-1.el7.noarch
php-ZendFramework2-Text-2.4.11-1.el7.noarch
php-ZendFramework2-Uri-2.4.11-1.el7.noarch
php-ZendFramework2-Validator-2.4.11-1.el7.noarch
php-ZendFramework2-Version-2.4.11-1.el7.noarch
php-ZendFramework2-View-2.4.11-1.el7.noarch
php-zendframework-zendxml-1.0.2-2.el7.noarch
php-zetacomponents-base-1.9-2.el7.noarch
php-zetacomponents-graph-1.5.2-3.el7.noarch
pigz-2.3.4-1.el7.x86_64
pinentry-0.8.1-17.el7.x86_64
pixman-0.34.0-1.el7.x86_64
pkcs11-helper-1.11-3.el7.x86_64
pkgconfig-0.27.1-4.el7.x86_64
plymouth-0.8.9-0.31.20140113.el7.centos.x86_64
plymouth-core-libs-0.8.9-0.31.20140113.el7.centos.x86_64
plymouth-scripts-0.8.9-0.31.20140113.el7.centos.x86_64
policycoreutils-2.5-22.el7.x86_64
policycoreutils-python-2.5-22.el7.x86_64
polkit-0.112-14.el7.x86_64
polkit-pkla-compat-0.1-4.el7.x86_64
popt-1.13-16.el7.x86_64
portreserve-0.0.5-11.el7.x86_64
postfix-2.10.1-6.el7.x86_64
postgresql-9.2.23-3.el7_4.x86_64
postgresql-libs-9.2.23-3.el7_4.x86_64
postgresql-server-9.2.23-3.el7_4.x86_64
ppp-2.4.5-33.el7.x86_64
procmail-3.22-36.el7_4.1.x86_64
procps-ng-3.3.10-17.el7_5.2.x86_64
psmisc-22.20-15.el7.x86_64
pth-2.0.7-23.el7.x86_64
pulseaudio-libs-10.0-5.el7.x86_64
pwgen-2.07-1.el7.x86_64
pygpgme-0.3-9.el7.x86_64
pyliblzma-0.5.3-11.el7.x86_64
pyOpenSSL-0.13.1-3.el7.x86_64
pyparsing-1.5.6-9.el7.noarch
pytalloc-2.1.10-1.el7.x86_64
python-2.7.5-68.el7.x86_64
python2-acme-0.24.0-1.el7.noarch
python2-boto-2.45.0-3.el7.noarch
python2-certbot-0.24.0-1.el7.noarch
python2-configargparse-0.11.0-1.el7.noarch
python2-crypto-2.6.1-15.el7.x86_64
python2-cryptography-1.7.2-2.el7.x86_64
python2-dialog-3.3.0-6.el7.noarch
python2-django-1.6.11.7-1.el7.noarch
python2-ecdsa-0.13-4.el7.noarch
python2-future-0.16.0-6.el7.noarch
python2-gflags-2.0-5.el7.noarch
python2-google-api-client-1.6.3-1.el7.noarch
python2-josepy-1.1.0-1.el7.noarch
python2-keyring-5.0-3.el7.noarch
python2-mock-1.0.1-9.el7.noarch
python2-oauth2client-4.0.0-2.el7.noarch
python2-paramiko-1.16.1-2.el7.noarch
python2-parsedatetime-2.4-5.el7.noarch
python2-psutil-2.2.1-3.el7.x86_64
python2-pyasn1-0.1.9-7.el7.noarch
python2-pyasn1-modules-0.1.9-7.el7.noarch
python2-PyDrive-1.3.1-3.el7.noarch
python2-pyrfc3339-1.0-2.el7.noarch
python2-requests-2.6.0-0.el7.noarch
python2-rsa-3.4.1-1.el7.noarch
python2-simplejson-3.10.0-1.el7.x86_64
python2-six-1.9.0-0.el7.noarch
python2-uritemplate-3.0.0-1.el7.noarch
python-backports-1.0-8.el7.x86_64
python-backports-ssl_match_hostname-3.5.0.1-1.el7.noarch
python-cffi-1.6.0-5.el7.x86_64
python-chardet-2.2.1-1.el7_1.noarch
python-configobj-4.7.2-7.el7.noarch
python-dateutil-1.5-7.el7.noarch
python-decorator-3.4.0-3.el7.noarch
python-django-bash-completion-1.6.11.7-1.el7.noarch
python-enum34-1.0.4-1.el7.noarch
python-fasteners-0.9.0-2.el7.noarch
python-firewall-0.4.4.4-14.el7.noarch
python-GnuPGInterface-0.3.2-11.el7.noarch
python-gobject-base-3.22.0-1.el7_4.1.x86_64
python-gunicorn-18.0-2.el7.noarch
python-httplib2-0.9.2-1.el7.noarch
python-idna-2.4-1.el7.noarch
python-iniparse-0.4-9.el7.noarch
python-ipaddress-1.0.16-2.el7.noarch
python-IPy-0.75-6.el7.noarch
python-javapackages-3.4.1-11.el7.noarch
python-kitchen-1.1.1-5.el7.noarch
python-libs-2.7.5-68.el7.x86_64
python-linux-procfs-0.4.9-3.el7.noarch
python-lockfile-0.9.1-4.el7.centos.noarch
python-lxml-3.2.1-4.el7.x86_64
python-meld3-0.6.10-1.el7.x86_64
python-ndg_httpsclient-0.3.2-1.el7.noarch
python-perf-3.10.0-862.3.2.el7.x86_64
python-ply-3.4-11.el7.noarch
python-pycparser-2.14-1.el7.noarch
python-pycurl-7.19.0-19.el7.x86_64
python-pyudev-0.15-9.el7.noarch
python-requests-2.6.0-1.el7_1.noarch
python-schedutils-0.4-6.el7.x86_64
python-setuptools-0.9.8-7.el7.noarch
python-six-1.9.0-2.el7.noarch
python-slip-0.4.0-4.el7.noarch
python-slip-dbus-0.4.0-4.el7.noarch
python-sssdconfig-1.16.0-19.el7.noarch
python-tdb-1.3.15-1.el7.x86_64
python-urlgrabber-3.10-8.el7.noarch
python-urllib3-1.10.2-5.el7.noarch
python-websockify-0.6.0-2.el7.noarch
python-zope-component-4.1.0-3.el7.noarch
python-zope-event-4.0.3-2.el7.noarch
python-zope-interface-4.0.5-4.el7.x86_64
pytz-2016.10-2.el7.noarch
pyxattr-0.5.1-5.el7.x86_64
PyYAML-3.10-11.el7.x86_64
qemu-img-1.5.3-156.el7_5.2.x86_64
qemu-kvm-1.5.3-156.el7_5.2.x86_64
qemu-kvm-common-1.5.3-156.el7_5.2.x86_64
qrencode-libs-3.4.1-3.el7.x86_64
quota-4.01-17.el7.x86_64
quota-nls-4.01-17.el7.noarch
rabbitmq-server-3.3.5-34.el7.noarch
radvd-1.9.2-9.el7_5.4.x86_64
rdma-core-15-7.el7_5.i686
rdma-core-15-7.el7_5.x86_64
readline-6.2-10.el7.x86_64
realmd-0.16.1-9.el7.x86_64
redis-3.2.10-2.el7.x86_64
remi-release-7.4-2.el7.remi.noarch
rh-php56-2.3-1.el7.x86_64
rh-php56-php-cli-5.6.25-1.el7.x86_64
rh-php56-php-common-5.6.25-1.el7.x86_64
rh-php56-php-gd-5.6.25-1.el7.x86_64
rh-php56-php-intl-5.6.25-1.el7.x86_64
rh-php56-php-ldap-5.6.25-1.el7.x86_64
rh-php56-php-mbstring-5.6.25-1.el7.x86_64
rh-php56-php-mysqlnd-5.6.25-1.el7.x86_64
rh-php56-php-pdo-5.6.25-1.el7.x86_64
rh-php56-php-pear-1.9.5-4.el7.noarch
rh-php56-php-pecl-jsonc-1.3.6-3.el7.x86_64
rh-php56-php-process-5.6.25-1.el7.x86_64
rh-php56-php-xml-5.6.25-1.el7.x86_64
rh-php56-runtime-2.3-1.el7.x86_64
rh-php71-1-1.el7.x86_64
rh-php71-php-cli-7.1.8-1.el7.x86_64
rh-php71-php-common-7.1.8-1.el7.x86_64
rh-php71-php-fpm-7.1.8-1.el7.x86_64
rh-php71-php-gd-7.1.8-1.el7.x86_64
rh-php71-php-intl-7.1.8-1.el7.x86_64
rh-php71-php-json-7.1.8-1.el7.x86_64
rh-php71-php-ldap-7.1.8-1.el7.x86_64
rh-php71-php-mbstring-7.1.8-1.el7.x86_64
rh-php71-php-mysqlnd-7.1.8-1.el7.x86_64
rh-php71-php-opcache-7.1.8-1.el7.x86_64
rh-php71-php-pdo-7.1.8-1.el7.x86_64
rh-php71-php-pear-1.10.4-1.el7.noarch
rh-php71-php-pecl-apcu-5.1.8-1.el7.x86_64
rh-php71-php-process-7.1.8-1.el7.x86_64
rh-php71-php-xml-7.1.8-1.el7.x86_64
rh-php71-php-zip-7.1.8-1.el7.x86_64
rh-php71-runtime-1-1.el7.x86_64
rootfiles-8.1-11.el7.noarch
rpcbind-0.2.0-44.el7.x86_64
rpm-4.11.3-32.el7.x86_64
rpm-build-libs-4.11.3-32.el7.x86_64
rpm-libs-4.11.3-32.el7.x86_64
rpm-python-4.11.3-32.el7.x86_64
rp-pppoe-3.11-7.el7.x86_64
rrdtool-1.4.8-9.el7.x86_64
rsync-3.1.2-4.el7.x86_64
rsyslog-8.24.0-16.el7_5.4.x86_64
samba-4.7.1-6.el7.x86_64
samba-client-4.7.1-6.el7.x86_64
samba-client-libs-4.7.1-6.el7.x86_64
samba-common-4.7.1-6.el7.noarch
samba-common-libs-4.7.1-6.el7.x86_64
samba-common-tools-4.7.1-6.el7.x86_64
samba-libs-4.7.1-6.el7.x86_64
sclo-php56-php-smbclient-0.9.0-1.el7.x86_64
sclo-php71-php-mcrypt-7.1.11-1.el7.x86_64
sclo-php71-php-smbclient-0.9.0-2.el7.x86_64
scl-utils-20130529-18.el7_4.x86_64
screen-4.1.0-0.25.20120314git3c2946.el7.x86_64
scrub-2.5.2-7.el7.x86_64
seabios-bin-1.11.0-2.el7.noarch
seavgabios-bin-1.11.0-2.el7.noarch
sed-4.2.2-5.el7.x86_64
selinux-policy-3.13.1-192.el7_5.3.noarch
selinux-policy-targeted-3.13.1-192.el7_5.3.noarch
setools-libs-3.3.8-2.el7.x86_64
setup-2.8.71-9.el7.noarch
sgabios-bin-0.20110622svn-4.el7.noarch
shadow-utils-4.1.5.1-24.el7.x86_64
shared-mime-info-1.8-4.el7.x86_64
shorewall-5.1.10.2-1.el7.noarch
shorewall-core-5.1.10.2-1.el7.noarch
slang-2.2.4-11.el7.x86_64
smartmontools-6.5-1.el7.x86_64
snappy-1.1.0-3.el7.x86_64
sogo-4.0.0-1.ns7.x86_64
sogo-activesync-4.0.0-1.ns7.x86_64
sogo-ealarms-notify-4.0.0-1.ns7.x86_64
sogo-tool-4.0.0-1.ns7.x86_64
sope49-appserver-4.9-20180318_1600.ns7.x86_64
sope49-cards-4.0.0-1.ns7.x86_64
sope49-core-4.9-20180318_1600.ns7.x86_64
sope49-gdl1-4.9-20180318_1600.ns7.x86_64
sope49-gdl1-contentstore-4.0.0-1.ns7.x86_64
sope49-gdl1-mysql-4.9-20180318_1600.ns7.x86_64
sope49-ldap-4.9-20180318_1600.ns7.x86_64
sope49-mime-4.9-20180318_1600.ns7.x86_64
sope49-sbjson-2.3.1-20180318_1600.ns7.x86_64
sope49-xml-4.9-20180318_1600.ns7.x86_64
spamassassin-3.4.0-2.el7.x86_64
speedtest-cli-1.0.2-1.el7.noarch
spice-server-0.14.0-2.el7_5.3.x86_64
sqlite-3.7.17-8.el7.x86_64
squashfs-tools-4.3-0.21.gitaae0aff4.el7.x86_64
squid-3.5.20-999.ns7.x86_64
squidclamav-6.16-1.ns7.x86_64
squid-migration-script-3.5.20-999.ns7.x86_64
sssd-1.16.0-19.el7.x86_64
sssd-ad-1.16.0-19.el7.x86_64
sssd-client-1.16.0-19.el7.x86_64
sssd-common-1.16.0-19.el7.x86_64
sssd-common-pac-1.16.0-19.el7.x86_64
sssd-ipa-1.16.0-19.el7.x86_64
sssd-krb5-1.16.0-19.el7.x86_64
sssd-krb5-common-1.16.0-19.el7.x86_64
sssd-ldap-1.16.0-19.el7.x86_64
sssd-libwbclient-1.16.0-19.el7.x86_64
sssd-proxy-1.16.0-19.el7.x86_64
strace-4.12-6.el7.x86_64
sudo-1.8.19p2-13.el7.x86_64
supermin5-5.1.19-1.el7.x86_64
supervisor-3.1.4-1.el7.noarch
syslinux-4.05-13.el7.x86_64
syslinux-extlinux-4.05-13.el7.x86_64
systemd-219-57.el7.x86_64
systemd-libs-219-57.el7.i686
systemd-libs-219-57.el7.x86_64
systemd-sysv-219-57.el7.x86_64
systemtap-sdt-devel-3.2-4.el7.x86_64
sysvinit-tools-2.88-14.dsf.el7.x86_64
t1lib-5.1.2-14.el7.x86_64
tar-1.26-34.el7.x86_64
tcl-8.5.13-8.el7.x86_64
tcpdump-4.9.2-3.el7.x86_64
tcp_wrappers-7.6-77.el7.x86_64
tcp_wrappers-libs-7.6-77.el7.x86_64
tdb-tools-1.3.15-1.el7.x86_64
teamd-1.27-4.el7.x86_64
tmpwatch-2.11-5.el7.x86_64
tokyocabinet-1.4.48-3.el7.x86_64
tomcat-7.0.76-6.el7.noarch
tomcat-el-2.2-api-7.0.76-6.el7.noarch
tomcat-jsp-2.2-api-7.0.76-6.el7.noarch
tomcat-lib-7.0.76-6.el7.noarch
tomcat-servlet-3.0-api-7.0.76-6.el7.noarch
traceroute-2.0.22-2.el7.x86_64
trousers-0.3.14-2.el7.x86_64
ttmkfdir-3.0.9-42.el7.x86_64
tuned-2.9.0-1.el7.noarch
tzdata-2018e-3.el7.noarch
tzdata-java-2018e-3.el7.noarch
ufdbGuard-1.33.4-CentOS7.x86_64
unbound-1.6.6-1.el7.x86_64
unbound-libs-1.6.6-1.el7.x86_64
unixODBC-2.3.1-11.el7.x86_64
unixODBC-devel-2.3.1-11.el7.x86_64
unzoo-4.4-16.el7.x86_64
usbredir-0.7.1-3.el7.x86_64
usbutils-007-5.el7.x86_64
ustr-1.0.4-16.el7.x86_64
util-linux-2.23.2-52.el7.x86_64
vim-minimal-7.4.160-4.el7.x86_64
virt-what-1.18-4.el7.x86_64
vsftpd-3.0.2-22.el7.x86_64
webtop5-zpush-1.1.3-1.ns7.noarch
webvirtmgr-4.8.9-1.192.ge1c7abb.ns7.noarch
wget-1.14-15.el7_4.1.x86_64
which-2.20-7.el7.x86_64
wpa_supplicant-2.6-9.el7.x86_64
xalan-j2-2.7.1-23.el7.noarch
xerces-j2-2.11.0-17.el7_0.noarch
xfsprogs-4.5.0-15.el7.x86_64
xkeyboard-config-2.20-1.el7.noarch
xml-commons-apis-1.4.01-16.el7.noarch
xml-commons-resolver-1.2-15.el7.noarch
xmlsec1-1.2.20-7.el7_4.x86_64
xmlsec1-openssl-1.2.20-7.el7_4.x86_64
xorg-x11-fonts-Type1-7.5-9.el7.noarch
xorg-x11-font-utils-7.5-20.el7.x86_64
xorg-x11-server-common-1.19.5-5.el7.x86_64
xorg-x11-server-Xvfb-1.19.5-5.el7.x86_64
xorg-x11-xauth-1.0.9-1.el7.x86_64
xorg-x11-xkb-utils-7.7-12.el7.x86_64
xz-5.2.2-1.el7.x86_64
xz-libs-5.2.2-1.el7.i686
xz-libs-5.2.2-1.el7.x86_64
yajl-2.0.4-4.el7.x86_64
yum-3.4.3-158.el7.centos.noarch
yum-cron-3.4.3-158.el7.centos.noarch
yum-metadata-parser-1.1.4-10.el7.x86_64
yum-plugin-auto-update-debug-info-1.1.31-45.el7.noarch
yum-plugin-changelog-1.1.31-45.el7.noarch
yum-plugin-fastestmirror-1.1.31-45.el7.noarch
yum-utils-1.1.31-45.el7.noarch
zeromq-4.1.4-5.el7.x86_64
zip-3.0-11.el7.x86_64
zlib-1.2.7-17.el7.i686
zlib-1.2.7-17.el7.x86_64
zlib-debuginfo-1.2.7-17.el7.x86_64
:crazy_face: I can see a lot of fun stuff installed!
Just to recap the issue: DNS queries return time out. The error in server-manager can be caused by it.
As you exclude 100% an issue with the configured DNS forwarder or with the LAN firewall, let’s try to understand what’s wrong in that NethServer installation.
This is OK (if that works…)
This is OK.
dnsmasq daemon is running. I’m assuming from above that dnsmasq.conf has not been tweaked.
It runs its own instances of dnsmasq. Maybe for some unknown reasons they interfere. You could try to stop it
  systemctl stop libvirtd
  systemctl start libvirtd
But…
…make me still think of a firewall issue. Maybe an upstream firewall, or ISP firewall… What’s between you and google?
 tracepath 8.8.8.8
[root@nethserver ~]#  tracepath 8.8.8.8
 1?: [LOCALHOST]                                         pmtu 1500
 1:  gateway                                               0.742ms
 1:  gateway                                               0.648ms
 2:  186.28.228.241                                        1.312ms asymm  3
 3:  10.244.1.5                                            1.796ms
 4:  10.5.4.42                                             2.949ms asymm  5
 5:  no reply
 6:  no reply
 7:  no reply
 8:  no reply
 9:  no reply
10:  no reply
11:  no reply
12:  no reply
13:  no reply
14:  no reply
15:  no reply
16:  no reply
17:  no reply
18:  no reply
19:  no reply
20:  no reply
21:  no reply
22:  no reply
23:  no reply
24:  no reply
25:  no reply
26:  no reply
27:  no reply
28:  no reply
29:  no reply
30:  no reply
     Too many hops: pmtu 1500
     Resume: pmtu 1500
I can Ping it, as showed above; the firewall is opened for “any” protocol.
I’m excited with your knoweleged, I’m learning a lot.
Can you repeat the test on another host of your LAN? On Windows machines a “dig” command equivalent is “nslookup”.
Yes every body is working, you can see the machine here: https://info2.unicentrobogota.com:888/
Ok, I’m playing the last cards… :slight_smile:
shorewall status
shorewall clear
And repeat dig check
Then
shorewall start
It Works!!! :heart_eyes:
Accounts came back!!! Didnt have to forma,t but well now is to check from where come the : Ntop misterious traffic
Try to run
yum clean all
yum update
signal-event firewall-adjust && echo OK
Last command must print OK!
