sorry I’m in a hurry … but i want to report my configuration
FW/GW with openvpn server - multiple green - ns6.7
mail/file server - ns6.7
other file server: qnap
my desktop os: fedora23
i can connect with openvpn, mount share on qnap ad on file server on ns67 (after adding my ovpn network in trusted network)
no special config added if i remember correctly…
Thanks! It worked. I did it with the tun0. Are there any disadvantages to this method? I understand that the network tunnell address is just translated into the local network address.
I think that this is a workaround going against the idea that vpn traffic should retain original ip addresses.
You’re hiding all ip addresses connected through vpn.
I’d prefer to discover why samba doesn’t answer to requests from the vpn and fix samba configuration.
I am using Windows 7 Client that connects through OpenVPN with Nethserver. The Nethserver is behind a router (Port 1194 is open). The VPN (routed mode) is established without a problem, but when I try to mount the shared folder I get the connection build up message but after a while it shows an error.
I didn’t change any of the config files - I just added the networks to the hosts and interfaces lines in smb.conf.
If you need more information don’t hestitate to ask.
