Some examples:
We reached a consensus, we will develop a beta rpm to evaluate the quarantine inside nethserver…thank @robb, @davidep and @GG_jr
yum install http://packages.nethserver.org/nethserver/7.5.1804/autobuild/x86_64/Packages/nethserver-mail-quarantine-2.3.0-1.12.pr83.g5a4f6f5.ns7.noarch.rpm --enablerepo=nethserver-testing
you will upgrade to 1.8.0
You must set a local email account and enable the quarantine, this email is not checked against spam. If you want to send all spam to external account, make sure this email will accept spam
config setprop rspamd QuarantineAccount user@domain.org QuarantineStatus enabled
you could also enable the email notification to postmaster (root alias) when emails are rejected
config setprop rspamd SpamNotificationStatus enabled
then expand and restart the service
signal-event nethserver-mail-quarantine-save
two templates are expanded, please check them, rspamd is restarted/reloaded
/etc/rspamd/local.d/settings.conf
/etc/rspamd/local.d/metadata_exporter.conf
you could review the email moved to quarantine by using a webmail, all notifications are sent to postmaster (root alias)
Do you have some news on it, bugs , NFR, issues…My spam collection is nice
testers needed here
sorry i forgot to answer (well i forget a lot of things…
) anyway, on my mail server i installed
- rspamd 1.80 5 days ago and is working fine
- quarantine installed and enabled 2 days ago,
not a lot of spam here, but notification and quarantine email seems to work correctly
as always tnx
probably one side effect…I have the feeling that since the spams are accepted and not rejected, I receive more spams…
did you have time to test the implementation @robb ?
Got my first spam mail today, the spam mailbox works and the mail to root works as well. Rspamd history shows the reject and the move to quarantine.
Not yet, didn’t have time yet to implement it. Hopefully I can install it this weekend. Will report back then…
I just installed the update. I created an alias for my own account to send the spam to. In my mailclient I created a rule to move all mails from that alias to a created folder called quarantine. The alias is marked as local only.
Let’s see what will happen…
If you want to speed up the test, I could send you some nice spams, coming from my private collection
Did I configure this wrong or is there something wrong with the package?
After a few days running, I see the following occur:
- about 25K messages with subject “Spam moved to quarantine” (and that a few 100 times in the subject) delivered to postmaster@domain.tld
When I delete those messages, they are delivered AGAIN. (and again, and again) - Messages that were spam before are now not marked as spam and delivered to my personal mailbox. (all sorts of “girls” that would like things that I am not interested in with them… you know the drill)
Is this normal behavior of the quarantine feature? Did I configure it wrong? Should the module change it’s behavior?
You tried an alias, try a real mailbox instead…I would prefer to have a specific account (let’s call it spam@domain.org) because the quarantine is authorised to receive spam so your real account will receive all the spam of the world.
Maybe my documentation is not enough clear of that…thank to confirm it
Then remains the question why are the notifications being sent over and over again?
After I deleted them from my mailclient, they are sent over again. Looks like these notifications are not removed from the source after they have been sent.
let me try to reproduce, I never tested with an alias
Of course it works as expected on my server with an alias, the contrary would be fun ![]()
this let me think the account was not allowed to receive spam, so when the spam comes, it is rejected, since a spam is rejected then it is sent again and again.
this is normal, the account is allowed to receive spam, so unfortunately you cannot sort wanted and unwanted spam…but…but why the notification above :-?
could you post the command:
config show rspamd
cat /etc/rspamd/local.d/settings.conf
cat /etc/rspamd/local.d/metadata_exporter.conf
show me the account used to receive spam (here spam2, do it for the real user please)
db accounts show spam2@domain.com
what I did to enable the quarantine is
config setprop rspamd QuarantineAccount spam2@domain.com QuarantineStatus enabled SpamNotificationStatus enabled
spam2@domain.com is an alias of spam@domain.com
also the rpm is now : yum install http://packages.nethserver.org/nethserver/7.5.1804/autobuild/x86_64/Packages/nethserver-mail-quarantine-2.3.0-1.12.pr83.g5a4f6f5.ns7.noarch.rpm
config show rspamd:
rspamd=service
BlockAttachmentClassList=Exec
BlockAttachmentCustomList=doc,odt
BlockAttachmentCustomStatus=disabled
BlockAttachmentStatus=enabled
Password=hUlsBhcUe4ESUCu3
QuarantineAccount=quarantine@domain.tld
QuarantineSelector=is_reject
QuarantineStatus=enabled
RecipientWhiteList=
SenderBlackList=
SenderWhiteList=
SpamCheckStatus=enabled
SpamGreyLevel=4
SpamKillLevel=20
SpamNotification=disabled
SpamNotificationStatus=enabled
SpamSubjectPrefixStatus=enabled
SpamSubjectPrefixString=SPAM
SpamTag2Level=6
VirusAction=reject
VirusCheckStatus=enabled
VirusScanOnlyAttachment=false
VirusScanSize=20000000
status=enabled
cat /etc/rspamd/local.d/settings.conf:
================= DO NOT MODIFY THIS FILE =================
Manual changes will be lost when this file is regenerated.
Please read the developer’s guide, which is available
at NethServer official site: https://www.nethserver.org
whitelist the spam receiver account
whitelist {
priority = hight;
rcpt = “quarantine@domain.tld”;
want_spam = yes;
Refer to Metadata exporter for information on configuration
rules {
QUARANTINE {
backend = “send_mail”;
smtp = “127.0.0.1”;
mail_to = “quarantine@interlin.nl”;
mail_from = “quarantine@interlin.nl”;
helo = “ns7.interlin.nl”;
selector = “is_reject”; # could be “is_reject” or “is_spam”
formatter = “default”;
SPAM_NOTIFICATION {
smtp = “127.0.0.1”;
mail_to = “postmaster@domain.tld”;
mail_from = “no-reply@domain.tld”;
helo = “server.domain.tld”;
formatter = “email_alert”;
email_template = <<EOL
To: <$mail_to>
Subject: Spam moved to quarantine: $header_subject
Date: $date
MIME-Version: 1.0
Message-ID: <$our_message_id>
Content-type: text/plain; charset=utf-8
Content-Transfer-Encoding: 8bit
Authenticated username: $user
IP: $ip
Queue ID: $qid
SMTP FROM: $from
SMTP RCPT: $rcpt
MIME From: $header_from
MIME To: $header_to
MIME Date: $header_date
Subject: $header_subject
Message-ID: $message_id
Action: $action
Score: $score
EOL
end of rules
db accounts show quarantine@domain.tld:
quarantine@domain.tld=pseudonym
Access=private
Account=myaccount@domain.tld
Description=quarantine address
So basically you suggest to create a new (local?) account with an email address. My question would be: those notifications, would be delivered to that address. I will not receive them in my own mailaddres, but that spam account will be filled quite drastically…
Do I understand correctly that in order to override an email message that is amrked as spam, I have to log into that account and forward (or what else) that to my own mailaddres?
That might be a bit too cumbersome…
yes, the idea is to use a dedicated account for this, notifications are sent to postmaster (root)
I tried to receive the spam on my account…it is simply not possible to open your mailbox with a friend, you son or your wife without hours of explanation ![]()
no an external account is needed here.
Once received to the spam account, yes, if it is not a spam, yes could forward it to the good recipient.
How do you understand it should be ?
